Astro Binding ----- Civil Dawn Event does not trigger
openHAB5 UI: The Sunset Event binding is working fine to turn ON my yard light in the evening, however in the morning, the Civil Dawn Event does not turn OFF my yard light.. I also tired Nautical Dawn Event which did not work either. These are all under the same Astro Sun Data binding (pull down menu). As a test I tried the fixed time of day set to 6:00 AM in the morning which works OK. I get the same results using other Things (yard lights). Furthermore, the UI Log shows nothing. Any Ideas?
There is a long running java timezone issue that caused me issues with triggers from this binding. Check out OH 4.3 to 5 + fresh openhabian install: timezone keeps resetting
… see here: Astro trigger after update 5.0 => 5.1.1 not working any more - #8 by ollo
