Astro Binding Events on OH3
Hi everyone,
I have the following issue with the Astro binding:
I’m getting this exception for events (sunset, sunrise…):
    `2020-12-27 19:22:08.887 [ERROR] [o.internal.handler.AstroThingHandler] - Can't update state for channel astro:sun:local:nauticDusk#event : org.openhab.binding.astro.internal.model.Range.getEvent()
java.lang.NoSuchMethodException: org.openhab.binding.astro.internal.model.Range.getEvent()
	at java.lang.Class.getMethod(Class.java:2108) ~[?:?]
	at org.openhab.binding.astro.internal.util.PropertyUtils.getPropertyValue(PropertyUtils.java:92) ~[bundleFile:?]
	at org.openhab.binding.astro.internal.util.PropertyUtils.getPropertyValue(PropertyUtils.java:96) ~[bundleFile:?]
	at org.openhab.binding.astro.internal.util.PropertyUtils.getPropertyValue(PropertyUtils.java:82) ~[bundleFile:?]
	at org.openhab.binding.astro.internal.util.PropertyUtils.getState(PropertyUtils.java:55) ~[bundleFile:?]
	at org.openhab.binding.astro.internal.handler.AstroThingHandler.publishChannelIfLinked(AstroThingHandler.java:180) [bundleFile:?]
	at org.openhab.binding.astro.internal.handler.AstroThingHandler.channelLinked(AstroThingHandler.java:249) [bundleFile:?]
	at org.openhab.core.thing.internal.ChannelLinkNotifier.lambda$3(ChannelLinkNotifier.java:72) [bundleFile:?]
	at org.openhab.core.thing.internal.ChannelLinkNotifier.call(ChannelLinkNotifier.java:96) [bundleFile:?]
	at org.openhab.core.thing.internal.ChannelLinkNotifier.added(ChannelLinkNotifier.java:72) [bundleFile:?]
	at org.openhab.core.thing.internal.ChannelLinkNotifier.updated(ChannelLinkNotifier.java:88) [bundleFile:?]
	at org.openhab.core.thing.internal.ChannelLinkNotifier.updated(ChannelLinkNotifier.java:1) [bundleFile:?]
	at org.openhab.core.common.registry.AbstractRegistry.notifyListeners(AbstractRegistry.java:387) [bundleFile:?]
	at org.openhab.core.common.registry.AbstractRegistry.notifyListenersAboutUpdatedElement(AbstractRegistry.java:408) [bundleFile:?]
	at org.openhab.core.thing.link.ItemChannelLinkRegistry.notifyListenersAboutUpdatedElement(ItemChannelLinkRegistry.java:150) [bundleFile:?]
	at org.openhab.core.thing.link.ItemChannelLinkRegistry.notifyListenersAboutUpdatedElement(ItemChannelLinkRegistry.java:1) [bundleFile:?]
	at org.openhab.core.common.registry.AbstractRegistry.updated(AbstractRegistry.java:314) [bundleFile:?]
	at org.openhab.core.common.registry.AbstractRegistry.updated(AbstractRegistry.java:1) [bundleFile:?]
	at org.openhab.core.common.registry.AbstractProvider.notifyListeners(AbstractProvider.java:66) [bundleFile:?]
	at org.openhab.core.common.registry.AbstractProvider.notifyListenersAboutUpdatedElement(AbstractProvider.java:91) [bundleFile:?]
	at org.openhab.core.model.thing.internal.GenericItemChannelLinkProvider.createItemChannelLink(GenericItemChannelLinkProvider.java:108) [bundleFile:?]
	at org.openhab.core.model.thing.internal.GenericItemChannelLinkProvider.processBindingConfiguration(GenericItemChannelLinkProvider.java:76) [bundleFile:?]
	at org.openhab.core.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:372) [bundleFile:?]
	at org.openhab.core.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:341) [bundleFile:?]
	at org.openhab.core.model.item.internal.GenericItemProvider.processBindingConfigsFromModel(GenericItemProvider.java:212) [bundleFile:?]
	at org.openhab.core.model.item.internal.GenericItemProvider.modelChanged(GenericItemProvider.java:407) [bundleFile:?]
	at org.openhab.core.model.core.internal.ModelRepositoryImpl.notifyListeners(ModelRepositoryImpl.java:301) [bundleFile:?]
	at org.openhab.core.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:139) [bundleFile:?]
	at org.openhab.core.model.core.internal.folder.FolderObserver.checkFile(FolderObserver.java:249) [bundleFile:?]
	at org.openhab.core.model.core.internal.folder.FolderObserver.processWatchEvent(FolderObserver.java:312) [bundleFile:?]
	at org.openhab.core.service.WatchQueueReader.lambda$3(WatchQueueReader.java:322) [bundleFile:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
	at java.lang.Thread.run(Thread.java:834) [?:?]`
I did not change the binding configuration since migrating from OH2 → OH3 …
Any Idea?
thanks
MM
