My time of day rule suddenly fails to register BED time because of slower astro triggering at midnight.
Instead of BED ie after 00:00 it becomes EVENING.
There was a recent change in ESH, the 30s delay was added to make really sure jobs are scheduled for the coming day and not the old one.
Not sure why this is a problem for you ( if you want things to happen right at 00:00, why not use cron).
No biggie, but it breaks @rlkoshak 's TimeOfDay âDesign Patternâ and even worse, my bedroom light turns on when I enter after midnight waking up the missus
@sihui, did the issue for having multiple cron triggers on the same rule ever get fixed?
If it has, @OMR change the triggers to the âGet time period for right nowâ rule to:
Channel 'astro:sun:home:rise#event' triggered START or
Channel 'astro:sun:home:set#event' triggered START or
Channel 'astro:sun:minus90:set#event' triggered START or
Time cron "0 0 6,23 * * ? *" or
Time cron "0 1 0 * * ? *"
Which will put the midnight run at 00:01 instead of midnight. You can remove the Thread::sleep from the rule in this case as well.
**EDIT: The cron trigger problem has been fixed, do not use the code below. **
If we still canât have cron triggers then change the rules as follows:
import org.eclipse.xtext.xbase.lib.Functions
val Functions$Function0<Boolean> calcTOD = [ |
val long morning_start = now.withTimeAtStartOfDay.plusHours(6).millis
val long day_start = (vSunrise_Time.state as DateTimeType).calendar.timeInMillis
val long afternoon_start = (vEvening_Time.state as DateTimeType).calendar.timeInMillis
val long evening_start = (vSunset_Time.state as DateTimeType).calendar.timeInMillis
val long night_start = now.withTimeAtStartOfDay.plusHours(23).millis
val long bed_start = now.withTimeAtStartOfDay.millis
var curr = "UNKNOWN"
switch now {
case now.isAfter(morning_start) && now.isBefore(day_start): curr = "MORNING"
case now.isAfter(day_start) && now.isBefore(afternoon_start): curr = "DAY"
case now.isAfter(afternoon_start) && now.isBefore(evening_start): curr = "AFTERNOON"
case now.isAfter(evening_start) && now.isBefore(night_start): curr = "EVENING"
case now.isAfter(night_start): curr = "NIGHT"
case now.isAfter(bed_start) && now.isBefore(morning_start): curr = "BED"
if(vTimeOfDay.state.toString != curr) {
logInfo(logName, "Current time of day is now " + curr)
vTimeOfDay.sendCommand(curr)
true
rule "Calculate time of day state"
System started or
Time cron "0 0 6,23,0 * * ? *" // there is currently a bug where only one cron is triggered per rule so I've combined all three into one
if(now.isBefore(now.withTimeAtStartOfDay.plusSeconds(1)) {
createTimer(now.plusSeconds(45), [| calcTOD .apply() ]
else {
calsTOD.apply()
This is only a workaround pending the issue above being fixed at which point you can revert to the DP as written.
Until a very recent change (merged today) makes it into the SNAPSHOT, that is a bad solution because a Thread::sleep in a System started rule will cause all other Rules to be ignored. Thus, for example, any rules you have that trigger on changes to vTimeOfDay may be missed if the System started rule doesnât exit fast enough.
