I use OH3-UI configuration for that - I can’t add a channel for Astro-Binding. Is there a way I can utilize this undocumented channel nevertheless? or does anyone with knowledge try and add those channels (could be using the “show advanced” feature) to the official binding rollout?
UseCase:
know, when the sunrise is next day, so I can use this for calculations
Have a look into the thing actions.
You could create a rule that will get the information you want via the thing action.
An example is included in the official documentation
I tried the example from the docs (with JS Scripting):
var sunActions = actions.Things.getActions("astro","astro:sun:local")
if(null === sunActions) {
console.log("actions: sunActions not found, check thing ID");
} else {
var sunEvent = "SUN_SET"
var today = time.ZonedDateTime.now();
var sunEventTime = sunActions.getEventTime(sunEvent,today,"START");
console.log("AstroActions: "+sunEvent+" will happen at ", sunEventTime.toString());
and it works with “today”:
2022-11-02 11:33:57.839 [INFO ] [omation.script.ui.EMS_CalcDunkelzeit] - AstroActions: SUN_SET will happen at 2022-11-02T16:54+01:00
so, where can I change that to “tomorrow”?
var sunEventTime = sunActions.getEventTime(sunEvent,tomorrow,"START");
has errors:
2022-11-02 11:35:03.835 [ERROR] [b.automation.script.javascript.stack] - Failed to execute script:
org.graalvm.polyglot.PolyglotException: ReferenceError: "tomorrow" is not defined
and
var sunEventTime = sunActions.getEventTime(sunTomorrow,today,"START");
has errors:
2022-11-02 11:36:09.891 [ERROR] [b.automation.script.javascript.stack] - Failed to execute script:
org.graalvm.polyglot.PolyglotException: ReferenceError: "sunTomorrow" is not defined
oh. yeah. sorry - of course today references a variable - not some attribut-value.
I somehow thought from the “sunTomorrow”-code entry, that I’ll somehow had to do something with that. but makes perfectly sense to use a DateTime variable for “tomorrow” → and it works:
for those struggling with it also, here’s the complete code JS Scripting style:
} else {
var sunEvent = "SUN_RISE"
var sunEventTime = sunActions.getEventTime(sunEvent,today.plusDays(1),"START");
2022-11-02 11:46:27.800 [INFO ] [omation.script.ui.EMS_CalcDunkelzeit] - AstroActions: SUN_RISE will happen at 2022-11-03T07:06+01:00
