a few days ago I installed openhab2 on raspbian. I´m trying to turn a switch ON at sunset. I installed astro bindung using Paper UI, things (astro:sun:local) and channels (astro:sun:local:rise#start etc.) were created.
The Rule looks right and the Thing looks healthy. It is updating or else you wouldn’t see the DateTime Item’s with valid times.
I just looked at my events.log and there doesn’t appear to be anything logged by default when the sunrise/sunset events occur.
Just to verify the problem is with the Astro binding, add a logInfo to that Rule so you can see in openhab.log whether or not the Rule is firing and the problem is actually with the sendCommand, or not.
rule "Lichtan"
Channel 'astro:sun:local:set#event' triggered START
logInfo("Lichtan.rules", "This is a log entry of type Info!")
TP_L_Switch.sendCommand("ON")
but nothing happend in openhab.log. I´ve used an offset for testing and in paperui and sitemap I can see that the time of sunset has changed correctly according to the offset.
@ Udo-Hartmann: I only have this rule and a default.rules.
I´ve used the package repository and followed the linux installation guide. But in fact I can´t tell you what version I installed. It seems to me that my sd-card crashed after a reebot and now it´s dead. So I will have to set it up again…
Thanks for your help. I will get back to this within the next days.
OK. This could have been a symptom of a wearing out SD card, though it is more likely that the file system became corrupted during a power failure. Avoid at all costs from yanking the power from an RPi without properly shutting it down. It can result in corruption.
I would recommend giving openHABian a look. It might be less work for you to get back up and running.
