No, itās not.
You have two or even more bindings started, but not one of them is active.
You screwed up your setup!
Delete any astro bindings you may have in your addons folder, then install the astro binding through PaperUI and make sure it is āactiveā, not started.
Also make sure you donāt have any bindings loaded in your addons.cfg.
Edit: okay, did not see the last couple of lines (too much beer this evening ).
If only ONE binding is active it should be fine. But why do you have so many astro bindings installed?
Clean up your installation, then it should work ā¦
The only way I installed the Astro binding was via PaperUI. I donāt have any custom .JARs in the /addons folder. So I donāt know why I have multiple entries.
Anyway, this is what I have done now:
I uninstalled the Astro binding via PaperUI;
I remove the ālocal sunā and ālocal moonā things via PaperUI;
I stopped OH;
I uninstalled the offline add-ons (apt-get purge openhab2-addons). Not sure why I installed them in the first place.
I deleted the /tmp and /cache folder;
I started OpenHab;
Somehow I notice the local sun/moon where back (status Uninitialized). I tried to remove them again, but they remain in status āRemovingā;
I installed the Astro binding via PaperUI;
My things are now in status āonlineā (despite removal attempts);
I was now able to remove them successfully (I guess you first need to remove things and then uninstall the binding - makes sense);
Using āsearch for thingsā Iāve found the new ālocal moonā and ālocal sunā;
openhab> bundle:list
START LEVEL 100 , List Threshold: 50
ID | State | Lvl | Version | Name
202 | Active | 80 | 0.9.0.201706170545 | Astro Binding
And:
openhab> feature:list|grep -i astro
esh-binding-astro | 0.9.0.SNAPSHOT | | Started | addons-2.2.0-SNAPSHOT |
openhab-binding-astro | 2.2.0.SNAPSHOT | x | Started | addons-2.2.0-SNAPSHOT | Astro Binding
So the duplicate entries have been removed.
So now Iāll have to wait untill the sun sets before I can check if the trigger is now triggered correctly (the values in items were already populated correctly before).
What the f**k? Sorry, no more ideas. There were some astro binding issues fixed with the latest snapshot, maybe you try do get that new snapshot working ā¦
I would do a quick install on a separate computer (Windows, Mac), itās just unzipping to a folder, then install only the astro binding and copy your astro rules and astro items to that instance.
And see what happens ā¦
I canāt remember any issues where the trigger did not trigger at all like in @Dries case . There have been several issues with the astro binding lately, to find out which one made it into a snapshot you may look at:
This way you may find out if your openHAB instance is the problem or your setup regarding the astro binding.
Steps could be:
new clean openHAB install
only astro binding installed
check the channel triggers, if okay: add your items and rules
check the triggers, if okay: look for problems in your original openHAB install. If rules do not trigger: look for problems in your astro items and rules.
