It appears that the start
and end
channels of the sunset element in the astro binding are reporting the same value. This is not the case for the sunrise element.
Things:
DateTime Astro_Sunrise_Start <sunrise> (AstroSun) {channel="astro:sun:local:rise#start"}
DateTime Astro_Sunrise_End <sunrise> (AstroSun) {channel="astro:sun:local:rise#end"}
DateTime Astro_Noon_Start <sun> (AstroSun) {channel="astro:sun:local:noon#start"}
DateTime Astro_Noon_End <sun> (AstroSun) {channel="astro:sun:local:noon#end"}
DateTime Astro_Sunset_Start <sunset> (AstroSun) {channel="astro:sun:local:set#start"}
DateTime Astro_Sunset_End <sunset> (AstroSun) {channel="astro:sun:local:set#end"}
Sitemap:
Default item=Astro_Sunrise_Start icon="sunrise" label="Sunrise start [%1$tH:%1$tM]"
Default item=Astro_Sunrise_End icon="sunrise" label="Sunrise end [%1$tH:%1$tM]"
Default item=Astro_Noon_Start icon="sun" label="Noon start [%1$tH:%1$tM]"
Default item=Astro_Noon_End icon="sun" label="Noon end [%1$tH:%1$tM]"
Default item=Astro_Sunset_Start icon="sunset" label="Sunset start [%1$tH:%1$tM]"
Default item=Astro_Sunset_End icon="sunset" label="Sunset end [%1$tH:%1$tM]"
Result:
Item |
Value |
Sunrise start |
08:01 |
Sunrise end |
08:05 |
Noon start |
12:58 |
Noon end |
12:59 |
Sunset start |
17:54 |
Sunset end |
17:54 |
I suppose the double sunset value is a mistake (I’d expect similar timings between start and end of sunrise and sunset events).
I also notice there is only 1 minute between start and end of noon, but that’s probably due to rounding to the closest minute.
Indeed, formatting the time as %1$tH:%1$tM
(or the equivalent shorthand %1$tR
) or as %1$tT
doesn’t give second-accuracy values (every value is rounded to the nearest minute). Just in case, if you need your timezone, you should use %1$tZ
In the event log, right after midnight I see:
2019-02-14 00:00:30.713 [vent.ItemStateChangedEvent] - Astro_Sunrise_Start changed from 2019-02-13T08:01:00.000+0100 to 2019-02-14T07:59:00.000+0100
2019-02-14 00:00:30.715 [vent.ItemStateChangedEvent] - Astro_Sunrise_End changed from 2019-02-13T08:05:00.000+0100 to 2019-02-14T08:03:00.000+0100
2019-02-14 00:00:30.758 [vent.ItemStateChangedEvent] - Astro_Sunset_Start changed from 2019-02-13T17:54:00.000+0100 to 2019-02-14T17:52:00.000+0100
2019-02-14 00:00:30.779 [vent.ItemStateChangedEvent] - Astro_Sunset_End changed from 2019-02-13T17:54:00.000+0100 to 2019-02-14T17:56:00.000+0100
From then on I get every 5 minutes the following event log entry (filtered to see only sunrise and sunset related events):
2019-02-14 00:00:30.780 [vent.ItemStateChangedEvent] - Astro_ Sunset _Start changed from 2019-02-14T17:52:00.000+0100 to 2019-02-14T17:56:00.000+0100
2019-02-14 00:04:01.007 [vent.ItemStateChangedEvent] - Astro_ Sunset _Start changed from 2019-02-14T17:56:00.000+0100 to 2019-02-14T17:52:00.000+0100
2019-02-14 00:04:01.033 [vent.ItemStateChangedEvent] - Astro_ Sunset _Start changed from 2019-02-14T17:52:00.000+0100 to 2019-02-14T17:56:00.000+0100
2019-02-14 00:09:00.991 [vent.ItemStateChangedEvent] - Astro_ Sunset _Start changed from 2019-02-14T17:56:00.000+0100 to 2019-02-14T17:52:00.000+0100
In the openhab log, I see the following messages around the same time (off by 1 minute):
2019-02-14 00:00:30.333 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:moon:local
2019-02-14 00:00:30.722 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:sun:local
2019-02-14 00:05:00.333 [ERROR] [e.internal.WriterInterceptorExecutor] - MessageBodyWriter not found for media type=text/event-stream, type=class org.glassfish.jersey.media.sse.OutboundEvent, genericType=class org.glassfish.jersey.media.sse.OutboundEvent.
2019-02-14 00:10:00.333 [ERROR] [e.internal.WriterInterceptorExecutor] - MessageBodyWriter not found for media type=text/event-stream, type=class org.glassfish.jersey.media.sse.OutboundEvent, genericType=class org.glassfish.jersey.media.sse.OutboundEvent.
2019-02-14 00:15:00.333 [ERROR] [e.internal.WriterInterceptorExecutor] - MessageBodyWriter not found for media type=text/event-stream, type=class org.glassfish.jersey.media.sse.OutboundEvent, genericType=class org.glassfish.jersey.media.sse.OutboundEvent.
2019-02-14 00:20:00.333 [ERROR] [e.internal.WriterInterceptorExecutor] - MessageBodyWriter not found for media type=text/event-stream, type=class org.glassfish.jersey.media.sse.OutboundEvent, genericType=class org.glassfish.jersey.media.sse.OutboundEvent.
2019-02-14 00:25:00.333 [ERROR] [e.internal.WriterInterceptorExecutor] - MessageBodyWriter not found for media type=text/event-stream, type=class org.glassfish.jersey.media.sse.OutboundEvent, genericType=class org.glassfish.jersey.media.sse.OutboundEvent.
Looking more closely at the event log, I see the following (unfiltered) log entries:
2019-02-10 00:01:15.751 [vent.ItemStateChangedEvent] - astro_moon_local_phase_ageDegree changed from 61.388823356643364 ° to 61.395207832167834 °
2019-02-10 00:01:15.752 [vent.ItemStateChangedEvent] - astro_moon_local_phase_agePercent changed from 17.052450932400934 % to 17.0542243978244 %
2019-02-10 00:01:15.753 [vent.ItemStateChangedEvent] - astro_moon_local_phase_illumination changed from 21.748130305537998 % to 21.75237435456608 %
2019-02-10 00:01:15.753 [vent.ItemStateChangedEvent] - astro_moon_local_distance_date changed from 2019-02-10T00:00:30.087+0100 to 2019-02-10T00:01:15.736+0100
2019-02-10 00:01:15.755 [vent.ItemStateChangedEvent] - astro_moon_local_distance_distance changed from 399024.21048672224 km to 399022.3604295172 km
2019-02-10 00:01:15.756 [vent.ItemStateChangedEvent] - astro_moon_local_position_azimuth changed from 288.71076003048614 ° to 288.8641721718961 °
2019-02-10 00:01:15.756 [vent.ItemStateChangedEvent] - astro_moon_local_position_elevation changed from -13.165320515049142 ° to -13.272783262713583 °
2019-02-10 00:01:16.748 [vent.ItemStateChangedEvent] - astro_sun_local_position_azimuth changed from 337.6138484485739 ° to 337.9090614278761 °
2019-02-10 00:01:16.750 [vent.ItemStateChangedEvent] - astro_sun_local_position_elevation changed from -51.78774597897857 ° to -51.83379157079161 °
2019-02-10 00:01:54.325 [vent.ItemStateChangedEvent] - ntp_ntp_local_dateTime changed from 2019-02-10T00:00:54.319+0100 to 2019-02-10T00:01:54.320+0100
2019-02-10 00:01:54.327 [vent.ItemStateChangedEvent] - ntp_ntp_local_string changed from 2019-02-10 00:00:54 CET to 2019-02-10 00:01:54 CET
2019-02-10 00:02:54.326 [vent.ItemStateChangedEvent] - ntp_ntp_local_dateTime changed from 2019-02-10T00:01:54.320+0100 to 2019-02-10T00:02:54.321+0100
2019-02-10 00:02:54.327 [vent.ItemStateChangedEvent] - ntp_ntp_local_string changed from 2019-02-10 00:01:54 CET to 2019-02-10 00:02:54 CET
2019-02-10 00:03:54.328 [vent.ItemStateChangedEvent] - ntp_ntp_local_dateTime changed from 2019-02-10T00:02:54.321+0100 to 2019-02-10T00:03:54.323+0100
2019-02-10 00:03:54.329 [vent.ItemStateChangedEvent] - ntp_ntp_local_string changed from 2019-02-10 00:02:54 CET to 2019-02-10 00:03:54 CET
2019-02-10 00:04:54.339 [vent.ItemStateChangedEvent] - ntp_ntp_local_dateTime changed from 2019-02-10T00:03:54.323+0100 to 2019-02-10T00:04:54.324+0100
2019-02-10 00:04:54.339 [vent.ItemStateChangedEvent] - ntp_ntp_local_string changed from 2019-02-10 00:03:54 CET to 2019-02-10 00:04:54 CET
2019-02-10 00:05:54.330 [vent.ItemStateChangedEvent] - ntp_ntp_local_dateTime changed from 2019-02-10T00:04:54.324+0100 to 2019-02-10T00:05:54.325+0100
2019-02-10 00:05:54.332 [vent.ItemStateChangedEvent] - ntp_ntp_local_string changed from 2019-02-10 00:04:54 CET to 2019-02-10 00:05:54 CET
2019-02-10 00:06:15.756 [vent.ItemStateChangedEvent] - astro_moon_local_phase_ageDegree changed from 61.395207832167834 ° to 61.43716587412588 °
Just in case this helps finding the problem.
