Astro☀night#start channel UNDEF and others too
And In my example the problem was that from 19th od May there is no night in Warsaw :wink:
There is a bug inside of astro binding related to the transition from above. I have already proposed a pull request with the fix. At tleast this kind of issue will be fixed.
Other thing reported:
This I would not consider as a bug since at this time in Warsaw there is no night, so we can consider UNDEF as a information that the night is not present at this place on this specific time. However UNDEF may be a bit confusing, so the user can think that there is some kond of error inside of astro binding and astro has some problems with calculating the correct time. If astro give us the state like NOT_PRESENT, then we could now that astro knows how to correctly calculate the date/time and it knows that at this particular place on a specific time, the night is not present, so it will show to us NOT_PRESENT instead od UNDEF. That would be a small improvement. What do you think?
However this:
I would consider as a bug in astro binding. If the binding is able to calculate the AstroDawnStop_Time then it should be also to be able to calculate correctly the AstroDawnStart_Time.
Great that you wrote fix. But the Travis CI build failed.
I think that is good idea. UNDEF for me, mean something wrong :wink: NOT_PRESENT is more natural.
I don’t think it is a bug.
Look at https://www.timeanddate.com/sun/poland/warsaw on e.g. 26 of May. The dusk start at evening of 25 and it doesn’t stop till midnight (so it can stop at 24:00). And on 26 of May the Dawn stop at the morning, but never start (so it can start at 00:00). Astronomical Twilight is from: 00:00 - 02:35 and from 22:32 - 00:00.
It also should be NOT_PRESENT, not UNDEF.
Build fails because there is something wrong with Smartmeter Binding 2.5.0-SNAPSHOT. You need to take a closer look into build log to find out. It looks like Travis builds all bindings together.
Ok, I will take a look at this and go back to you later.
UNDEF is explicitly supposed to be used in this sort of situation. UNDEF essentially means NOT_PRESENT. I think a sentence added to the README to explain what it means when one sees UNDEF would be more appropriate (and easier to get approved) than adding a new special State type to the core, especially since that new State type is already supposed to be covered by the existing UNDEF. Adding NOT_PRESENT or replacing NOT_PRESENT with UNDEF will require changes to the OH core and will ripple out to several other bindings, so the change cannot be taken lightly.
The main reason why UNDEF is confusing to some users is it isn’t used all that much by the bindings. But I’m happy to see more and more bindings use it just like Astro does, to indicate that there is no State or the State cannot be known (e.g. when the MQTT Broker Thing goes offline, all of the Channels that use that Broker go to UNDEF to indicate we have no way to know the current states).
That’s just a matter of interpreting the language used. UNDEF stands for undefined, not for error. It can mean error, but it can also mean can’t calculate that, as in “what weekday is 29th Feb this year?” and it can mean “I can’t get that data at this time” because a device is busy.
Do you mean astro docs?
Yes, that is what I mean.
The definition of UNDEF comes from the OpenHAB Core library. Here is how it is commented in the code:
 * There are situations when item states do not have any defined value.
 * This might be because they have not been initialized yet (never
 * received an state update so far) or because their state is ambiguous
 * (e.g. a dimmed light that is treated as a switch (ON/OFF) will have
 * an undefined state if it is dimmed to 50%).
My impression about UNDEF - in general - is that the value is undefined. But we do not know what is the root caus of this. It may be as stated in the astro docs:
But it also may be a result of a bug inside of astro - just like in case of reported #5006 issue. Another thing is when OpenHAB service is during startup and the state of thing is really undefined yet.
I have the feeling that Astro should never deliver UNDEF, because every status/phase/range can be well known by doing a correct calculations, so the state that NIGHT is not present could be indicated by something different than UNDEF.
For now we can also live with UNDEF but it would be good eliminate as much of those as we can.
@majherek, thanks for the link to this online datetime calulator. I have took a look at th 19th and 20th of May in Warsaw and I have prepared the table of what states/ranges should generate Astro binding to coved those two days correctly (in my opinion):
   ASTRO_DUSK = 19th May 00:12 -> 19th May 00:12
        NIGHT = 19th May 00:12 -> 19th May 00:51
EVENING_NIGHT = 19th May 00:12 -> 19th May 00:32 (NOON + 12h)
MORNING_NIGHT = 19th May 00:32 -> 19th May 00:51
   ASTRO_DAWN = 19th May 00:51 -> 19th May 02:51
  NAUTIC_DAWN = 19th May 02:51 -> 19th May 03:52
   CIVIL_DAWN = 19th May 03:52 -> 19th May 04:35
     SUN_RISE = 19th May 04:35 -> 19th May 04:35
     DAYLIGHT = 19th May 04:35 -> 19th May 20:29
	 NOON = 19th May 12:32
      SUN_SET = 19th May 20:29 -> 19th May 20:29
   CIVIL_DUSK = 19th May 20:29 -> 19th May 21:13
  NAUTIC_DUSK = 19th May 21:13 -> 19th May 22:15
   ASTRO_DUSK = 19th May 22:15 -> 20th May 00:00
   ASTRO_DUSK = 20th May 00:00 -> 20th May 00:32 (NOON + 12h)
        NIGHT =    NOT_PRESENT -> NOT_PRESENT
EVENING_NIGHT =    NOT_PRESENT -> NOT_PRESENT
MORNING_NIGHT =    NOT_PRESENT -> NOT_PRESENT
   ASTRO_DAWN = 20th May 00:32 -> 20th May 02:49
  NAUTIC_DAWN = 20th May 02:49 -> 20th May 03:50
   CIVIL_DAWN = 20th May 03:50 -> 20th May 04:34
     SUN_RISE = 20th May 04:34 -> 20th May 04:34
     DAYLIGHT = 20th May 04:34 -> 20th May 20:31
	 NOON = 20th May 12:32
      SUN_SET = 20th May 20:31 -> 20th May 20:31
   CIVIL_DUSK = 20th May 20:31 -> 20th May 21:15
  NAUTIC_DUSK = 20th May 21:15 -> 20th May 22:17
   ASTRO_DUSK = 20th May 22:17 -> 21th May 00:00
Astro calculates a sun rise/set as a range with about 4 minutes duration (not included above). I have also use NOT_PRESENT in the example. With this representation all of the ranges will be consistent with the astronomical events. Unfortunately Astro binding is not able to deliver two ASTRO_DUSK events/ranges for the specific date (there a two ASTRO_DUSKs at 20th May 2019 in Warsaw). I do not know how can it be “fixed”. One of the option could be to deliver the closesd range/event, so between midnight and noon astro will devliver
and after the noon it will deliver
What do you think guys?
Opposite opinion from me. If there is no sunrise today then today’s sunrise time is not defined. UNDEF is entirely appropriate,
Barring genuine bugs, there is no other reason for Astro to set UNDEF than this kind of situation. Adding some other new state (which would have to affect all Items of DateTime state, right across openHAB), some new state like NOT_PRESENT doesn’t add any information. Whether it says UNDEF or NOT_PRESENT you know what it means - there’s no answer for that question today.
If it’s not been calculated yet after start up, it will be NULL. The description from core is a bit misleading here - Items are created NULL and stay that way until updated by some action.
The fact that something may get set to UNDEF due to some bug is not I think relevant. A bug could just as well cause unexpected setting of NOT_PRESENT or 23:59 1/1./2099. A bug is a bug, an erroneous value is an erroneous value.
Thanks for clarification around this NULL value. However I have read this topic again and I see that @rlkoshak has also explained this before. Sorry - my bad.
Yes, I need to agree with this.
@rossko57, so you propose something like this: in Astro binding UNDEF means that the specific event/phase/range/date/time is not present at the specific date and location. Other words if night_startTime is UNDEF, then it means that there is no night at the specific time and place. This would be also backward compatible so there will be no need to update the rules in the openHAB system. I can understand this point of view.
So now - with this aproach - we confirmed that Astro binding can return UNDEF for some specific channel, which - under some specific conditions (like high latitude locationas at the June doesn’t have NIGHT) - is an expected behavior. Unless somebody says, that for his location at this specific date the date of event is wrongly calculated, which should be treated as a bug (then it should be fixed in Astro binding).
:+1: I completely agree. If there is no such time today, then UNDEF is completely appropriate. There is nothing about the state UNDEF that implies the Item is UNDEF because of some sort of problem. Nor should there be IMHO. If we don’t know the state of a Channel, the Channel is in an undefined state. There are other ways to determine if there is something wrong (e.g. the Offline state for Channels).
If an Item gets set to UNDEF erroneously has no bearing on the argument for the inclusion of a new NOT_PRESENT state.
There is already enough confusion on the difference between UNDEF and NULL where the distinction is pretty clear cut. The distinction between UNDEF and NOT_PRESENT is going to be much too subtle and it will cause a ton of confusion for users.
I do agree, if a Channel is calculable by Astro that Channel should have a valid state. But if it isn’t then UNDEF is the proper state.
Don’t apologise, it’s useful to air these things.
I think the NULL / UNDEF distinction was not nearly as clear cut in OH1 (where we had Undefined instead) and there may be woolly comments like the one you found that come from that historical background.
Great question Witold and great discussion gentlemen
And of course you can test for UNDEF in a rule with an if statement and have your interface of choice display whatever you want under those conditions
Ok, so the UNDEF variable is for now clarified.
I have just one question to clarify. Please go back to my previous post where I have put an example of all phases on 19th and 20th May in Warsaw. There are two ASTRO_DUSKs (one right after the midnight on 19th May, second right before midnight of the same day) ranges at those days. Astro binding can only provide one ASTRO_DUSK range at the time. Which one should be provided?
And second thing: if some specific range overlaps the midnight, then what should provide Astro? For example there is the following Astro Dusk
19th May 22:15 -> 20th May 00:32
So for example on the 19th May 2019, what should Astro provide:
the full range
ASTRO_DUSK = 19th May 22:15 → 20th May 00:32
or truncated to midnight range
ASTRO_DUSK = 19th May 22:15 → 20th May 00:00
or UNDEF as the astro dusk doesn’t end at th 19th May
ASTRO_DUSK = 19th May 22:15 → UNDEF
Looks like https://www.timeanddate.com always truncates the date/time to midnight.
Good point. No idea what can be done about that.
There’s only one of each static channel type. So let’s populate that with the next event, just after midnight.
When Astro next recalculates at midnight - it will have already missed the second one for what is now the previous day.
A dirty fix might be to have it recalculate at noon as well as midnight.
Not sure what you mean here; do you mean the phase name string channel? That really just tells you what the last event was out of a set of particular events. e.g. ASTRO_DAWN, NAUTIC_DAWN, CIVIL_DAWN …
I would say sun phase name would change to ASTRO_DUSK at 19th May 22:15, there would be no NIGHT phase today I think?, then change to ASTRO_DAWN at 20th May 00:32
Let’s take as an example a simple ASTRO_DUSK channel; actually there are three channels:
astroDusk#start
astroDusk#end
astroDusk#duration
In more cases the night starts before midnight and ends after midnight. Let’s assume that at some specific date we have astroDusk#start = 16 Jun 23:10 astroDusk#end = 17 Jun 00:36
What should say Astro in those two channels (for now let’s forget what is Astro doing now):
or
astroDusk#start = 16 Jun 23:10 astroDusk#end = 17 Jun 00:00
or
astroDusk#start = 16 Jun 23:10 astroDusk#end = UNDEF
The https://www.timeanddate.com shows the data always truncated to midnight, but I’m not quite sure now if this is a good way to go for Astro. If Astro shows on 16 Jun something like:
then on 17 Jun it needs to theoretically show:
astroDusk#start = 17 Jun 23:10 astroDusk#end = 17 Jun 00:36
which will lead to a false astroDusk#start event to be triggered at the midnight, which is incorrect. Astro should show a reall times and not truncate them to midnight and also it should not set UNDEF.
For example, my test openHAB installation shows now ASTRO_DUSK as below:
23:24:12.654 [safeCall-1] INFO  smarthome.event.ItemStateEvent:53 - astro_sun_8c2f8c23_astroDusk_start updated to 2019-06-16T23:10:00.000+0200
23:24:12.670 [safeCall-1] INFO  smarthome.event.ItemStateEvent:53 - astro_sun_8c2f8c23_astroDusk_end updated to UNDEF
23:24:12.670 [safeCall-1] INFO  smarthome.event.ItemStateEvent:53 - astro_sun_8c2f8c23_astroDusk_duration updated to UNDEF
Those UNDEFS could be replaced with a real dates, however those dates are tomorrow days. I do not know - maybe I’m chasing a ghost here?
Are not all times Astro calculates for today? As in the actual day that it is?
And then at midnight it recalculates everything for that next about to start day?
maybe I don’t understand
Can’t comment on what you want, but so far as I can see current behaviour is that at midnight or boot time, events are calculated for today’s calendar day.
Any particular event may not happen today, as we know (UNDEFs)
Your astroDusk examples are essentially the same case as “ordinary” sun:night channels at low latitudes.
Does duration work for that, night spanning across midnight? Which of the two night periods in today’s date does it refer to? Never looked at it.
If that does work, I would say your astroDusk duration UNDEF observation is a genuine bug.
Curious what happens in the Arctic … does duration give months? Would you want next sunrise to be set for months ahead?
I wonder if “solving” the odd but real case of what to do about two of the same kind of events in one calendar day would umm, throw some light on possible improvements.
I do not think we want to discard the notion of providing events for today?
Example, we boot up and want to look at sunrise and sunset to determine if it is daylight. We want today’s events, even if they are in the past “now”.
Equally, there are uses for knowing tomorrow’s events, perhaps we want to schedule something for next dawn. Perhaps thinking of the Arctic case helps here … maybe not tomorrow’s sunrise, but just the next sunrise after “now”?
Not thought through, but perhaps each event could provide an extra DateTime channel #next.
Sometimes that would be the same as today’s start because that hasn’t happened yet, sometimes that would be in the future, maybe tomorrow or next month.
There is a recalculation cost to that, which should not be high because few will use this stuff .
But as Astro generates events anyway, maybe it is not a large burden to have each event fire a recalculation of it’s own #next.
In Astro there is something like PositionalJob and this is executed as how often as configured in the thing refresh interval. I have chenged it in my openHAB test environment to 15 seconds, so the channel values are updated every 15 seconds.
There is also a DailyJobSun which is executed 30 seconds after the midnight and registers the assynchronous triggers for all of the astro events (so it seems to be possible to set a thing refresh interval to some high value - like every 6 hours - and those asynchronous triggers will publish events at the correct time anyway).
I have made a short tests around passing the midnight from 16th Jun to 17th Jun, for city Warsaw in Poland.
Before midnight I had something like below in the log:
23:59:57.285 [safeCall-2] INFO  smarthome.event.ItemStateEvent:53 - astro_sun_8c2f8c23_astroDusk_start updated to 2019-06-16T23:10:00.000+0200
23:59:57.349 [safeCall-2] INFO  smarthome.event.ItemStateEvent:53 - astro_sun_8c2f8c23_astroDusk_end updated to UNDEF
23:59:57.355 [safeCall-2] INFO  smarthome.event.ItemStateEvent:53 - astro_sun_8c2f8c23_astroDusk_duration updated to UNDEF
23:59:57.460 [safeCall-1] INFO  smarthome.event.ItemStateEvent:53 - astro_sun_8c2f8c23_phase_name updated to ASTRO_DUSK
It says UNDEF for astroDusk_end and astroDusk_duration, however the phase_name phase name is calculated correctly to ASTRO_DUSK. In the source code - I see - that to calculate the phase name it silently assumes that ASTRO_DUSK ends at midnight however it says that the end time is UNDEF.
Interesting thing is when the date changes, right after the midnight:
00:00:12.293 [safeCall-1] INFO  smarthome.event.ItemStateEvent:53 - astro_sun_8c2f8c23_astroDusk_start updated to 2019-06-17T23:11:00.000+0200
00:00:12.297 [safeCall-1] INFO  smarthome.event.ItemStateEvent:53 - astro_sun_8c2f8c23_astroDusk_end updated to UNDEF
00:00:12.302 [safeCall-1] INFO  smarthome.event.ItemStateEvent:53 - astro_sun_8c2f8c23_astroDusk_duration updated to UNDEF
00:00:12.247 [safeCall-1] INFO  smarthome.event.ItemStateEvent:53 - astro_sun_8c2f8c23_astroDawn_start updated to UNDEF
00:00:12.252 [safeCall-1] INFO  smarthome.event.ItemStateEvent:53 - astro_sun_8c2f8c23_astroDawn_end updated to 2019-06-17T02:06:00.000+0200
00:00:12.257 [safeCall-2] INFO  smarthome.event.ItemStateEvent:53 - astro_sun_8c2f8c23_astroDawn_duration updated to UNDEF
00:00:12.494 [safeCall-3] INFO  smarthome.event.ItemStateEvent:53 - astro_sun_8c2f8c23_phase_name updated to ASTRO_DAWN
Right after the midnight Astro calculates the DUSK to be at the end of the current date but it wrongly calculates that we are in ASTRO_DAWN since the midnight, and the current sun phase is wrongly calculated to ASTRO_DAWN. The correct result should be:
ASTRO_DUSK till 17 May 00:36
ASTRO_DAWN from 17 May 00:36 till 02:04
NAUTIC_DAWN in my case is calculated correctly.
Another interesting thing. I have changed the date in my computer to 20 Apr 2019, to see how Astro calculates NIGHT. Here it is:
09:44:27.416 [safeCall-3] INFO  smarthome.event.ItemStateEvent:53 - astro_sun_8c2f8c23_night_start updated to 2019-04-20T21:59:00.000+0200
09:44:27.422 [safeCall-2] INFO  smarthome.event.ItemStateEvent:53 - astro_sun_8c2f8c23_night_end updated to 2019-04-21T03:10:00.000+0200
09:44:27.429 [safeCall-2] INFO  smarthome.event.ItemStateEvent:53 - astro_sun_8c2f8c23_night_duration updated to 311 min
Its startTime is on 20th Apr but endTime is on 21th Apr. The duration is calculated correctly (as a difference of endTime and startTime). So for NIGHT it desn’t truncate to midnight but it shows the real night end on the next day.
Could Astro do the same with ASTRO_DUSK, NAUTIC_DUSK and CIVIL_DUSK?
I have the feeling that Astro was at first designed to provide events related to the specific date but we observe a weired behavior around midnight for a high latitude locations. I also feel that Astro should deliver events related to the current day but there are some special cases when we have two the same events at the same date (like two ASTRO_DUSK or two NAUTIC_DUSK and so on) but Astro is able to deliver only one of them at the time. So maybe it could provide events for the current date but - in case of doubled events - it should provide the closesd one? This means that Astro should also reschedule the event triggering after the NOON?
Also the Sun’s noon is not alwasy at 12:00. In the north latitude on earth the Sun’s noon is around 12:30 on Jun and around 11:30 on Dec. The same relates the Sun’s midnight: it varies from 23:30 to 00:30, so the ASTRO_DUSK may end between 23:30 and 00:30.
This is a good question. At least the current sun phase name should be correctly calculated to DAYLIGHT or NIGHT.
From one side - we take again an example of ASTRO_DUSK - if Astro truncates the ASTRO_DUSK to midnight, then it should generate two ASTRO_DUSKs:
ASTRO_DUSK = 16th Jun 23:10 -> 17th Jun 00:00
ASTRO_DUSK = 17th Jun 00:00 -> 17th Jun 00:36
then astroDusk#start will be generated twice. What if I have a rule in my openHAB, to switch on some lights for 30 minutes on every astroDusk#start? Then I expect the lights to be on only between 23:10 and 23:40, but not on 00:00 and 00:30.
