Attributes not showing in HABot
I’m trying to get HABot to work on my openhab system. So I installed HABot throught the paper UI according to the walkthrough. Now I stuck in part 2 of the walkthrough…
I have added some tags to my items. For example:
// Küche - Thermostat
Group gKueche_Heizung (gKueche) ["Thermostat"]
Dimmer Kueche_Heizung_Oeffnung  "Öffnung [%d %%]"                                           (gKueche_Heizung, gArchiveEveryHour, gArchiveOnChange)                      ["Öffnung", "Messung"]
Number Kueche_Heizung_Temp_Ist  "Temperature Ist [%.1f °C]"             <Temperature>       (gKueche_Heizung, gArchiveEveryHour, gArchiveOnChange)                      ["Temperatur", "Messung"]
Number Kueche_Heizung_Temp_Soll "Temperature Soll [%.1f °C]"            <Temperature>       (gKueche_Heizung, gArchiveEveryHour, gArchiveOnChange)                      ["Temperatur", "Sollwert"]
Number Kueche_Heizung_Mode      "Modus"                                                     (gKueche_Heizung, gArchiveEveryHour, gArchiveOnChange)
Number Kueche_Heizung_Battery   "Battery [%d %%]"                       <Battery>           (gKueche_Heizung, gArchiveEveryHour, gArchiveOnChange, gBatteryLevel)       ["Batterie", "Messung"]
But they are not shown in HABot under “View item attributes”. There are no attributes listet at all.
What am I doning wrong?
The bot also does not find anything when I add a search in the chat.
Thanks for the help.
The tags should be in English :slight_smile: from this list:
Then you can refer to your items in German (the framework has translations for the tags here)
