I have an August Pro Lock connected via z-wave, and I’ve been noticing that the battery levels reported by the lock are goofy at best. Here’s what I’m seeing,
My kwikset doors are showing a steady battery level decline, which the August Pro is showing a weird behavior, with values all over the place.
Right now, the batteries are below 25%, yet the lock is reporting 61%
../userdata/logs/openhab.log.7-2020-07-17 09:23:39.837 [DEBUG] [mmandclass.ZWaveSecurityCommandClass] - NODE 100: SECURITY_RXD 80 03 3D
../userdata/logs/openhab.log.7-2020-07-17 09:23:39.837 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 100: Incoming command class COMMAND_CLASS_BATTERY, endpoint 0
../userdata/logs/openhab.log.7-2020-07-17 09:23:39.837 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 100: Received COMMAND_CLASS_BATTERY V1 BATTERY_REPORT
../userdata/logs/openhab.log.7:2020-07-17 09:23:39.837 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 100: Battery report value = 61
Does anybody else have an august pro lock that is reporting incorrect battery values?
