Hi Kris
I have commented out all loginfos but still get the whole xml file showing in the log
<element type="precipitation_range">0 to 1 mm</element>
<element type="air_temperature_minimum" units="Celsius">21</element>
<element type="air_temperature_maximum" units="Celsius">36</element>
<text type="precis">Possible shower.</text>
<text type="probability_of_precipitation">40%</text>
</forecast-period>
<forecast-period index="2" start-time-local="2019-02-07T00:00:00+10:30" end-time-local="2019-02-08T00:00:00+10:30" start-time-utc="2019-02-06T13:30:00Z" end-time-utc="2019-02-07T13:30:00Z">
<element type="forecast_icon_code">3</element>
<element type="air_temperature_maximum" units="Celsius">37</element>
<text type="precis">Mostly sunny.</text>
<text type="probability_of_precipitation">10%</text>
</forecast-period>
<forecast-period index="3" start-time-local="2019-02-08T00:00:00+10:30" end-time-local="2019-02-09T00:00:00+10:30" start-time-utc="2019-02-07T13:30:00Z" end-time-utc="2019-02-08T13:30:00Z">
<element type="air_temperature_minimum" units="Celsius">15</element>
<element type="air_temperature_maximum" units="Celsius">29</element>
<text type="probability_of_precipitation">0%</text>
</forecast-period>
<forecast-period index="4" start-time-local="2019-02-09T00:00:00+10:30" end-time-local="2019-02-10T00:00:00+10:30" start-time-utc="2019-02-08T13:30:00Z" end-time-utc="2019-02-09T13:30:00Z">
<element type="forecast_icon_code">1</element>
<element type="air_temperature_minimum" units="Celsius">10</element>
<element type="air_temperature_maximum" units="Celsius">28</element>
<text type="precis">Sunny.</text>
</forecast-period>
<forecast-period index="5" start-time-local="2019-02-10T00:00:00+10:30" end-time-local="2019-02-11T00:00:00+10:30" start-time-utc="2019-02-09T13:30:00Z" end-time-utc="2019-02-10T13:30:00Z">
<element type="air_temperature_minimum" units="Celsius">11</element>
<element type="air_temperature_maximum" units="Celsius">30</element>
</forecast-period>
<forecast-period index="6" start-time-local="2019-02-11T00:00:00+10:30" end-time-local="2019-02-12T00:00:00+10:30" start-time-utc="2019-02-10T13:30:00Z" end-time-utc="2019-02-11T13:30:00Z">
<element type="air_temperature_minimum" units="Celsius">14</element>
<element type="air_temperature_maximum" units="Celsius">32</element>
</forecast-period>
</area>
</forecast>
</product>
' to a state type which item 'BOM_Forecast_Icon_Code_6' accepts: [DecimalType, QuantityType, UnDefType].
