Autelis Binding - Channels Missing?
@digitaldan
Now that I have the Autelis binding up and running in OH2 I wanted to start building out my controls.
The first item I wanted to control was my waterfall pump, which is connected to Auxiliary 2 as per the Autelis setting screen.
When looking at the available channels in the Official Docs I did not see any for Auxiliary so I tried both the
equipment-circuit2
and
equipment-feature2
channels with no luck. I then surmised the channel I needed was missing and tried
equipment-aux2
and like magic I had control.
Is the documentation missing references to the equipment-aux channels?
Squid
I’m not sure, my controller does not have aux entries in any of the xml files ( check http://poolcontrol/status.xml ) , also I don’t think I have that same setup screen that you have posted, not sure if its a firmware difference or not.
Here’s my Status.XML…
I have the model 6520 for Jandy/Zodiac Controllers, do you have the Pentair or Hayward model by chance?
<response>
<system>
<runstate>8</runstate>
<model>6520</model>
<dip>10000000</dip>
<opmode>0</opmode>
<vbat>33</vbat>
<lowbat>1</lowbat>
<version>1.6.9</version>
<time>1479571532</time>
</system>
<equipment>
<pump>0</pump>
<pumplo/>
<spa>0</spa>
<waterfall/>
<cleaner>0</cleaner>
<poolht2/>
<poolht>0</poolht>
<spaht>0</spaht>
<solarht>0</solarht>
<htpmp/>
<aux1/>
<aux2>0</aux2>
<aux3>0</aux3>
<aux4>0</aux4>
<aux5>0</aux5>
<aux6>0</aux6>
<aux7>0</aux7>
<aux8/>
<aux9/>
<aux10/>
<aux11/>
<aux12/>
<aux13/>
<aux14/>
<aux15/>
<aux16/>
<aux17/>
<aux18/>
<aux19/>
<aux20/>
<aux21/>
<aux22/>
<aux23/>
</equipment>
<temp>
<poolsp>80</poolsp>
<poolsp2>60</poolsp2>
<spasp>102</spasp>
<pooltemp>70</pooltemp>
<spatemp>0</spatemp>
<airtemp>56</airtemp>
<solartemp>0</solartemp>
<tempunits>F</tempunits>
</temp>
</response>
Ahh, mine is Pentair, hence the difference. I can make a different thing type for the pentair version, do you know if you have chem.xml and pumps.xml?
Sorry I mean make a differnt thing type for Jandy
Hi Dan -
I do have chem.xml and pumps.xml which I believe were part of the newer Autelis firmware. I can make the current THING work, my only observation was that there was no channel for the AUX items which seems to be the basis of my control. I was able to create an undocumented channel called
equipment-aux2
Instead of creating a different version do you think it might be easier to update the docs? I say that because it seems like there are 4/5 other models and I’d hate for you to need to maintain 5 different versions.
Can you post the content of those please?
We really need channels defined for each type, OH2 is very much made for this type of situation, in fact I think this is all just some XML changes, I don’t think there will be any code changes, which is why it’s mostly working as you point out.
Here are my chem.xml and pumps.xml files…
CHEM.XML
<response>
<chem>
<avail>0</avail>
<chlrp>0</chlrp>
<saltp>0</saltp>
<chlrs>0</chlrs>
<salts>0</salts>
<orp1>0</orp1>
<orp2>0</orp2>
<ph1>0</ph1>
<ph2>0</ph2>
<orpfd1>0</orpfd1>
<orpfd2>0</orpfd2>
<phfd1>0</phfd1>
<phfd2>0</phfd2>
</chem>
</response>
PUMPS.XML
<response>
<pumps>
<vsp1/>
<vsp2/>
<vsp3/>
<vsp4/>
</pumps>
</response>
Dan, thanks as always for your assistance and dedication to OH!
