I am trying to get api authentication working and having no luck.
My system is a raspberry pi running buster. Openhab is version 3.1.0 release build, upgraded from an earlier version using apt-get method.
I have enter my username in the console like this:
openhab:users add username password user
I use cut and paste to eliminate typos when entering data. Tried creating different username and passwords, rebooted etc. I don’t know what more I can do. It seems so straight forward, but I am stumped.
What would you like to achieve ?
Recent browser do not longer support adding user:password as part of an URL.
In case you just want to make sure that you do not need to type in user/password combinations use the browsers password manager to store the user and password.
I am testing that I can access /rest/things on openhab. This is troubleshooting problems with habAPP. I have tried Firefox, Chrome and Safari. From you response, I tried curl in this format:
curl -u USERNAME http://server.example
I am prompted for a password and then get
{“error”:{“message”:“Access denied”,“http-code”:403}}
Please provide full example code of your trial just replace the domain name with xxxx.
From the curl code you provided I can’t see that it is the same as the URL you used in the browser.
Thanks Wolfgang. I am testing on the openhab server itself.
curl -u test http://localhost:8080/rest/things
Enter host password for user 'test':
{"error":{"message":"Access denied","http-code":403}}root@zippy:/home/chris#
I just changed the password for username test in the karaf console, so I can see what I did on the screen. Openhab is responding by prompting for a password as can be seen.
What I am doing is pretty simple and straight forward. But I am no stranger to seeing people (myself) do dumb things that another’s eyes can see.
Right for security reasons higher privileges are required to access the REST API.
Alternatively you can create a token ( under admin profile ) and do not need to enter a password.
Thanks for the response. I am trying to get habAPP running and attaching to things and items via “http” protocol are a requirement. I am trying several things that are new to me, and can get a little frustrating at times.
Thanks,
Chris
