Auto populate group with items based on item tag
Hi all,
Is there a way to automatically populate group items with items based on a tag?
For example, I have a group for battery status items. Instead of manually adding an item’s battery status to the group whenever I create a new one, I want to auto-insert these items based on their tag.
Thanks,
Florian
No.
This has been discussed previously, and pretty much every time it comes up the final conclusion is it really doesn’t pass a cost/benefit analysis.
You could write a rule that keeps a group membership updated with a list of all items that share a tag, but 1) there’s no good event for triggering this rule so it’d have to just run periodically which seems pretty excessive, and 2) any manual change of a tag means you are either editing the item in a file or via the item page in the UI and in both cases it is very little additional effort to just also add the item to a group manually.
From my personal point of view, tags and groups are two fundamentally distinct ideas. I have 0 situations that I can think of where I have a 1:1 correspondence between a tag some group membership. I can see the the couple of instances where semantic tags, such as a battery tag might also make a functional group (although for me this is not the case as I have % level battery items and low threshold battery items), but these really are the exception and not the rule.
