Hello! First post here. I haven’t used openHAB, but am considering it if it can help me achieve what I need to do with my lighting.
I would like to use a GE Smart Dimmer and an Aeotec Multisensor (or something along those lines) to control lights in a specific room. Basically, as the available outdoor light fluctuates throughout the day I want the lights to mimic those changes. For instance, full sun = 100% light intensity, nighttime = 0% light intensity, with every possible fluctuation in between (i.e a cloud going in front of the sun, overcast days) to be regulated via the luminosity sensor data controlling the dimmer. In real-time would be optimal, but if not then a method that allows the parameters to update at a small interval would be acceptable.
Is there a way to set up these kinds of controls via openHAB? I plan on using a z-stick on a windows tablet PC as the hub in this room specifically.
