Automower binding issue with "Position.getLatitude()"
The Automower binding works quiet fine for me - I can send command to the mower via the actions. However, the regular retrieval of the automower status information does not work as I get those error messages, see below. Anybody having the same issue or an idea how to fix?
java.lang.NullPointerException: Cannot invoke "org.openhab.binding.automower.internal.rest.api.automowerconnect.dto.Position.getLatitude()" because the return value of "org.openhab.binding.automower.internal.rest.api.automowerconnect.dto.MowerData.getLastPosition()" is null
	at org.openhab.binding.automower.internal.things.AutomowerHandler.updateChannelState(AutomowerHandler.java:317) ~[?:?]
	at org.openhab.binding.automower.internal.things.AutomowerHandler.updateAutomowerState(AutomowerHandler.java:215) ~[?:?]
	at org.openhab.binding.automower.internal.things.AutomowerHandler.lambda$0(AutomowerHandler.java:94) ~[?:?]
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) ~[?:?]
	at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) ~[?:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) ~[?:?]
Bridge Thing
UID: automower:bridge:385f03ef86
label: Automower Connect Bridge
thingTypeUID: automower:bridge
configuration:
  pollingInterval: 3600
  appKey: xxx
  appSecret: xxx
Automower Thing
UID: automower:automower:xxx
label: Automower Aspire (Automower Husqvarna Automower® Aspire™ R4)
thingTypeUID: automower:automower
configuration:
  mowerId: xxx
  pollingInterval: 600
bridgeUID: automower:bridge:385f03ef86
channels:
  - id: name
    channelTypeUID: automower:nameType
    label: Automower Name
    description: The channel providing the automower name
    configuration: {}
  - id: mode
    channelTypeUID: automower:modeType
    label: Mode
    description: The current mode
    configuration: {}
  - id: activity
    channelTypeUID: automower:activityType
    label: Activity
    description: The current activity
    configuration: {}
  - id: state
    channelTypeUID: automower:stateType
    label: State
    description: The current state
    configuration: {}
  - id: last-update
    channelTypeUID: automower:lastUpdateType
    label: Last Update
    description: The time when the mower sent the last update
    configuration: {}
  - id: battery
    channelTypeUID: system:battery-level
    label: Batterieladung
    description: Zeigt die aktuelle Batterieladung in Prozent an (0% - 100%).
    configuration: {}
  - id: error-code
    channelTypeUID: automower:errorCodeType
    label: Error Code
    description: The error code at the time of last update
    configuration: {}
  - id: error-timestamp
    channelTypeUID: automower:errorTimestampType
    label: Error Time
    description: The time when the error occurred
    configuration: {}
  - id: planner-next-start
    channelTypeUID: automower:plannerNextStartTimestampType
    label: Next Auto Start
    description: The channel providing the time for the next auto start. If the
      mower is charging then the value is the estimated time when it will be
      leaving the charging station. If the mower is about to start now, the
      value is NULL.
    configuration: {}
  - id: planner-override-action
    channelTypeUID: automower:plannerOverrideActionType
    label: Override Action
    description: The channel providing an action that overrides current planner operation.
    configuration: {}
  - id: calendar-tasks
    channelTypeUID: automower:calendarTasksType
    label: Planner Info JSON
    description: The channel providing a JSON with the information about the planner tasks.
    configuration: {}
  - id: start
    channelTypeUID: automower:start
    label: Start with Duration
    description: Start for a duration in minutes
    configuration: {}
  - id: resume_schedule
    channelTypeUID: automower:resumeSchedule
    label: Resume Schedule
    description: Resume schedule
    configuration: {}
  - id: pause
    channelTypeUID: automower:pause
    label: Pause
    description: Pause the mower now until manual resume
    configuration: {}
  - id: park
    channelTypeUID: automower:park
    label: Park with Duration
    description: Park for a duration in minutes
    configuration: {}
  - id: park_until_next_schedule
    channelTypeUID: automower:parkUntilNextSchedule
    label: Park Until Next Schedule
    description: Park until next schedule
    configuration: {}
  - id: park_until_further_notice
    channelTypeUID: automower:parkUntilFurtherNotice
    label: Park and Pause the Schedule
    description: Park and pause the mower schedule until manual resume
    configuration: {}
  - id: last-position
    channelTypeUID: automower:positionType
    label: GPS Position
    description: Last Position
    configuration: {}
  - id: position01
    label: GPS Position
    description: The channel providing a waypoint of the mower's activity.
    configuration: {}
  - id: position02
    label: GPS Position
    configuration: {}
  - id: position03
    label: GPS Position
    configuration: {}
  - id: position04
    label: GPS Position
    configuration: {}
  - id: position05
    label: GPS Position
    configuration: {}
  - id: position06
    label: GPS Position
    configuration: {}
  - id: position07
    label: GPS Position
    configuration: {}
  - id: position08
    label: GPS Position
    configuration: {}
  - id: position09
    label: GPS Position
    configuration: {}
  - id: position10
    label: GPS Position
    configuration: {}
  - id: position11
    label: GPS Position
    configuration: {}
  - id: position12
    label: GPS Position
    configuration: {}
  - id: position13
    label: GPS Position
    configuration: {}
  - id: position14
    label: GPS Position
    configuration: {}
  - id: position15
    label: GPS Position
    configuration: {}
  - id: position16
    label: GPS Position
    configuration: {}
  - id: position17
    label: GPS Position
    configuration: {}
  - id: position18
    label: GPS Position
    configuration: {}
  - id: position19
    label: GPS Position
    configuration: {}
  - id: position20
    label: GPS Position
    configuration: {}
  - id: position21
    label: GPS Position
    configuration: {}
  - id: position22
    label: GPS Position
    configuration: {}
  - id: position23
    label: GPS Position
    configuration: {}
  - id: position24
    label: GPS Position
    configuration: {}
  - id: position25
    label: GPS Position
    configuration: {}
  - id: position26
    label: GPS Position
    configuration: {}
  - id: position27
    label: GPS Position
    configuration: {}
  - id: position28
    label: GPS Position
    configuration: {}
  - id: position29
    label: GPS Position
    configuration: {}
  - id: position30
    label: GPS Position
    configuration: {}
  - id: position31
    label: GPS Position
    configuration: {}
  - id: position32
    label: GPS Position
    configuration: {}
  - id: position33
    label: GPS Position
    configuration: {}
  - id: position34
    label: GPS Position
    configuration: {}
  - id: position35
    label: GPS Position
    configuration: {}
  - id: position36
    label: GPS Position
    configuration: {}
  - id: position37
    label: GPS Position
    configuration: {}
  - id: position38
    label: GPS Position
    configuration: {}
  - id: position39
    label: GPS Position
    configuration: {}
  - id: position40
    label: GPS Position
    configuration: {}
  - id: position41
    label: GPS Position
    configuration: {}
  - id: position42
    label: GPS Position
    configuration: {}
  - id: position43
    label: GPS Position
    configuration: {}
  - id: position44
    label: GPS Position
    configuration: {}
  - id: position45
    label: GPS Position
    configuration: {}
  - id: position46
    label: GPS Position
    configuration: {}
  - id: position47
    label: GPS Position
    configuration: {}
  - id: position48
    label: GPS Position
    configuration: {}
  - id: position49
    label: GPS Position
    configuration: {}
  - id: position50
    label: GPS Position
    configuration: {}
Hello Markus,
i have the same issue.
I figured out when the “Regenwächter” in the smart routines stop the mower (rain), the status information is stopped.
If there is no “rainstop” the mower is always up to date.
The same issue occured when i deleted all times from one ore more fields.
Maybe the “rainstop” override the same value, so that this value makes the error with NULL.
Just discovered that with openhab 5.0.0 there is a major update of the binding. I will give this a try.
https://github.com/openhab/openhab-addons/pull/17545
Hi Markus,
are your problems with the connection gone with 5.0.0 ?
I also updated to 5.0.0 and the errors still exists… :frowning:
Please open a GitHub issue with the stacktrace above. A NullPointerException should never occur.
From there we can provide a fix and possibly patch 5.0.1
Hi Leo,
thx for your reply.
I never open a issue before, do you have a hint where exact and how i can do this ?
Al source code is maintained at GitHub. Bugs are tracked there as issues. You can file it here:
Thanks for doing so! Appreciated
Thx Leo,
think i make a new issue :slight_smile:
This issue was fixed in the meanwhile. Please use the latest binding from OH5.1.0 SNAPSHOT. It comes with the fix for this issue together with several other improvements.
As alternative workaround you can add an (deactivated) StayoutZone (using the Automower App).
