Over the last few weeks, I have been having a bit of a play with getting a moderately functional dashboard going for the Automower.
My intent was to be able to control key functions from within OpenHAB, but a non-goal was for configuration, for which I will continue to use the Husqvarna App to perform, probably infrequently.
With a bit of help (and often hindrance) from Gemini, I have managed to get a basic prototype working, and I am sharing it here, for others who may wish to have a play with this. I’ll post any improvements I make here as well. While it display/works on a browser, it’s a Mobile-First design, so doesn’t look quite as pretty on a big screen.
There are a few steps needed to set it up and get it working, and these are detailed further down. In each section I have added background information, so you can understand the intent/reasoning of that step.
But before we get into the setup, here’s an overview of what it should look like, and its main functions:
First photo shows the summary box, which contains the basic controls and status of the mower. It’s worth noting that the Overall Status ('Mowing; in the above picture), Details (‘87 % done in House North’ in above picture) and the cutting height are all synthetic/proxy items, managed by a rule we will create as part of the setup process.
As you can see, the work areas are all listed below this, and they display a summary of their state (Enabled/Disabled/Mowing).
Also recently added, was the expandable map, based on the Husqvarna Automower Status Card by @ltty, but this variant uses local map tiles instead, which does come with a few extra steps to setup…
The next 2 photos show the options displayed when you hit the ‘Home’ button, or the ‘Start’ button (Noting the button will change to ‘Pause’ when mower is running). When starting the mower, you can either resume the schedule (which could mean it is parked until the next start), or ‘Override schedule’ to send it to a specific area.
The work areas are all accordion-lists, and can be expanded for additional control/status, as shown in the first photo below. The second photo shows the mower service status information, which appears below the work-areas accordion list.
The lists for the Work Areas are dynamically populated, so if you follow the below configuration steps for your current (and any future) work areas, you shouldn’t need to edit the page itself.
I have raised a couple of feature requests in the addons Github, which would make the setup process slightly easier, but for now just follow these steps, which include the workarounds.
Install & configure the Automower Binding
First step is to install the Automower binding, and create & configure the ‘Automower Connect Bridge’. You should then also be able to discover and add the Mower and Work Area things. Just follow the binding documentation for this step, but do not link any channels/items as yet.
Setup Groups for Mower and Work Areas
Background: The groups are used for both the mower and the work-areas, and allow items to be subsequently setup under these, in a consistent and predictable fashion.
Set up some groups for the mower (highlighted), and also for each of the work areas. I have created these as ‘Equipment’ type groups. You can call these groups what ever you like,but you will need to make sure you configure the page and rule to match. The following example shows the groups I have setup for our mower:
Add Tags to Work Area Groups
Background: This solution uses tags to find the work-areas relating to this mower, for the dynamically built menus (OH-Repeater), and also to loop through work-areas within the rule
For each of the Work Area groups created above, add a non-semantic tag as follows, but use whatever name makes sense for your installation… Just make sure you set it to match in the configuration of the UI Page, and the Rule
.Create Items
Background: This solution relies on default item names as specified by the Binding channel, which are a combination of the parent group name, and the channel name. The rule and the page just use the base group name, and expect the suffixes to follow this pattern.
When using the ‘Add Points to Model’ approach, these will populate correctly with the ‘naming schema’ this solution expected. If you use any other naming convention, you will need to edit the rule and UI page accordingly.
Mower Thing
- Select Add ‘Points to Model’
- Select ‘Show Advanced’
- Select the Parent Group for the Mower that you created in the previous step
- Select the following Channels
- status
- state
- activity
- mode
- inactive-reason
- next-start
- error-message
- error-code
- work-area
- cutting-height
- battery
- last-update
- command
- pause
- resume-schedule
- park
- park-until-next-schedule
- park-until-further-notice
- start-in-workarea
- statistics
- total-running-time
- charging-cycles
- cutting-blade-usage
- status
Or just ‘Select all’ if you don’t mind having a few extra (unused) channels linked to items, or have some nefarious plan for using them in future (e.g. in other rules to control the Automower).
Work Area Thing
For each Work Area Thing:
- Select the Parent Group that you created in the earlier step, for the corresponding Work Area
- Select the following Channels:
- Name
- Cutting Height
- Enabled
- Progress
- Last Time Completed
Synthetic/Proxy Items
Background: The solution uses a few ‘proxy’ items to store values which are populated by the rule. This includes the Status and Detail strings which are displayed at the top of the page, which are ‘synthetic’ values comprised from multiple items in the mower. The cutting height is also derived from the Current Work Area Height, as the Mower Cutting height does not display the current height (but we use that value when no work areas are active).
Create these items under the Mower ‘Core’ group, using the same naming convention as you did for the points you added in the last step, with the following suffixes:
- _Current_Cutting_Height (Number:Length - CM)
- _Summary_Detail (String)
- _Summary_Status (String)
As an example:
Number:Length automower_name_core_Current_Cutting_Height "Automower Current Cutting Height (Proxy Item)" (automower_name_core) [Point] { stateDescription=" " [pattern="%d cm"], unit="cm" }
String automower_name_core_Summary_Detail "Automower Summary Detail" (automower_name_core) [Point]
String automower_name_core_Summary_Status "Automower Summary Status" (automower_name_core) [Point]
Transform the cutting height values to CM
Background: So the Husqvarna API, and therefore the binding channels, has the cutting height as ‘1-9’ for the mower and ‘0-100%’ for the Work areas. Whilst I did try managing the conversion in the UI Page, to display as CM, some component would always display the raw item value, e.g. popover for sliders. Converting the item to store/display CM was an easier approach.
I have raised a GitHub feature request for additional channels presented in CM to be added to the binding (along with a min/max value), so maybe if addressed in future, this whole section could be skipped.
Change Cutting Height items dimension/unit:
For all mower & work area Cutting Height items:
- Change the Dimension to be ‘Length’
- Change the unit to be ‘CM’
- Change the State Description to be ‘%d cm’
Create Transformation Script
Background: This (bloated!!) transform script can handle both the mower and workarea Thing to Item, and Item Command to Thing transforms. You also need to feed it the Min & Max cutting heights for your specific mower, and it will take care of the rest.
Create a JS transform script called automower_height, via Main UI, and populate it with the below code.
Note: If you use a file based script instead, you will need to adjust the syntax in the subsequent Transform sections.
(function(data) {
// 1. Safe null/UNDEF/empty check
if (data === null || data === undefined || data === "" || data === "UNDEF" || data === "null") {
return "UNDEF";
var strData = String(data);
// 2. Extract configuration parameters safely
var mode = (typeof type !== 'undefined') ? String(type).toLowerCase() : 'mower';
var minHeight = (typeof min !== 'undefined') ? parseFloat(min) : 2.0;
var maxHeight = (typeof max !== 'undefined') ? parseFloat(max) : 6.0;
var heightSpan = maxHeight - minHeight;
if (heightSpan <= 0) return "UNDEF"; // Avoid division by zero
// 3. Determine Direction
var direction = (typeof dir !== 'undefined') ? String(dir).toLowerCase() : 'in';
if (strData.indexOf("cm") !== -1) {
direction = 'out';
// DIRECTION: IN (Thing -> Item / UI)
if (direction === 'in') {
var raw = parseFloat(strData);
if (isNaN(raw)) return "UNDEF";
// console.log("Automower Incoming Payload: " + data + " | Parsed Raw: " + raw);
var cm = 0.0;
if (mode === 'workarea') {
cm = minHeight + ((raw / 100) * heightSpan);
} else {
cm = minHeight + (((raw - 1) / 8) * heightSpan);
// Clamp & round to nearest 0.5 cm
cm = Math.max(minHeight, Math.min(maxHeight, cm));
return (Math.round(cm * 2) / 2).toFixed(1);
// DIRECTION: OUT (UI / Item Command -> Thing)
else {
var cmVal = parseFloat(strData.replace(/[^\d.]/g, ''));
if (isNaN(cmVal)) return "UNDEF";
if (cmVal <= minHeight) return "0";
if (cmVal >= maxHeight) return "100";
var targetPct = Math.round(((cmVal - minHeight) / heightSpan) * 100);
return Math.max(0, Math.min(100, targetPct)).toString();
} else {
if (cmVal <= minHeight) return "1";
if (cmVal >= maxHeight) return "9";
var step = Math.round(1 + (((cmVal - minHeight) / heightSpan) * 8));
return Math.max(1, Math.min(9, step)).toString();
})(input);
Mower Cutting Height Transformation
Add the following ECMAscript transforms to the mower Cutting Height Link. Adjust the min and max cutting height (in CM) to match your mower.
Thing to Item Transform (Mower):
config:js:automower_height?type=workarea&min=2.0&max=6.0&dir=in
Item Command to Thing Transform (Mower):
config:js:automower_height?type=mower&min=2.0&max=6.0&dir=out
Work Area Height Transformation
Add the following ECMAscript transforms to ALL Work Area Cutting Height Links. Adjust the min and max cutting height (in CM) to match your mower.
Thing to Item Transform (Work Area):
Item Command to Thing Transform (Work Area):
config:js:automower_height.js?type=workarea&dir=out&min=2&max=6
Setup Metadata for Work Area ID
Background: The Work Area ID is only available as a Thing Property, which Main UI pages cannot access. We need to know this ID, to be able to send a ‘Start in Area’ Command. As a work-around we will add this as Custom Item Meta-Data to the parent group for each work-area.
I have also logged a Github Feature Request for realising the Area ID as a channel, and if it is addressed, this step could also be skipped in future.
For each work area thing, look in ther properties for the workareaID
Then within the corresponding group you created for that work area, add the workAreaId metadata with the value from the Thing properties in the prior step. This is done via ‘Add Custom Namespace’.
Create rule for synthetic items
Background: We need this rule to run every-time one of the items changes, that it uses to build its synthetic Status and Detail messages. We also use a ‘every minute’ Cron trigger, to pickup changes in %complete from the active work area, without needing to add every work area completion item to the triggers.
This rule also finds the height for the current cutting area, and populates this into a proxy item, or falls back to the core mower cutting height if no area is active.
Create a rule (I called mine automower_state_summary ).
Use the following triggers (obviously changing the names to match your mower items) :
triggers:
- id: "1"
itemName: automower_name_core_State
type: ItemChanged
- id: "2"
itemName: automower_name_core_Activity
type: ItemChanged
- id: "3"
itemName: automower_name_core_Mode
type: ItemChanged
- id: "5"
itemName: automower_name_core_Inactive_Reason
type: ItemChanged
- id: "6"
itemName: automower_name_core_Next_Start
type: ItemChanged
- id: "7"
itemName: automower_name_core_Error_Message
type: ItemUpdated
- id: "8"
itemName: automower_name_core_Error_Code
type: ItemUpdated
- id: "10"
itemName: automower_name_core_Work_Area_Name
type: ItemChanged
- id: "9"
cronExpression: 0 * * * * ? *
type: Cron
Then add an ECMA Script Action as follows, and make sure you update the definitions for following 2 variables at the top, to match your installation:
BASE_PREFIXWORK_AREA_TAG
// CONFIGURATION
var BASE_PREFIX = "automower_marvin_core"; // Base prefix for core items
var WORK_AREA_TAG = "automower_marvin_work_areas"; // Independent tag for work areas
// ITEM STATE RETRIEVAL
var state = items.getItem(BASE_PREFIX + "_State").state;
var activity = items.getItem(BASE_PREFIX + "_Activity").state;
var mode = items.getItem(BASE_PREFIX + "_Mode").state;
var inactiveReason = items.getItem(BASE_PREFIX + "_Inactive_Reason").state || "NONE";
var nextStartRaw = items.getItem(BASE_PREFIX + "_Next_Start").state;
var errorMessage = items.getItem(BASE_PREFIX + "_Error_Message").state || "NULL";
var errorCode = items.getItem(BASE_PREFIX + "_Error_Code").state || "NULL";
var activeAreaName = items.getItem(BASE_PREFIX + "_Work_Area_Name").state;
var globalHeight = items.getItem(BASE_PREFIX + "_Cutting_Height").state;
var mainStatus = "Unknown";
var mainDetail = "";
// WORK AREA PROGRESS & CUTTING HEIGHT LOOKUP
var activeProgress = null;
var activeHeight = null;
if (activeAreaName && activeAreaName !== "NULL" && activeAreaName !== "UNDEF") {
var areaItems = items.getItemsByTag(WORK_AREA_TAG);
for (var i = 0; i < areaItems.length; i++) {
var areaBase = areaItems[i].name;
if (items.getItem(areaBase + "_Name").state === activeAreaName) {
var progState = items.getItem(areaBase + "_Progress").state;
var heightState = items.getItem(areaBase + "_Cutting_Height").state;
if (progState !== "NULL" && progState !== "UNDEF") {
activeProgress = progState;
if (heightState !== "NULL" && heightState !== "UNDEF") {
activeHeight = heightState;
break;
var currentCuttingHeight = activeHeight || globalHeight || "NULL";
// NEXT START FORMATTING
var nextStartText = "Until further notice";
if (nextStartRaw && nextStartRaw !== "NULL" && nextStartRaw !== "UNDEF" && nextStartRaw !== "") {
var cleanStr = nextStartRaw.toString().replace(' ', 'T');
var nextDate = new Date(cleanStr);
if (!isNaN(nextDate.getTime())) {
var now = new Date();
var todayStart = new Date(now.getFullYear(), now.getMonth(), now.getDate());
var targetStart = new Date(nextDate.getFullYear(), nextDate.getMonth(), nextDate.getDate());
var diffDays = Math.round((targetStart - todayStart) / (1000 * 60 * 60 * 24));
var hours = nextDate.getHours().toString().padStart(2, '0');
var minutes = nextDate.getMinutes().toString().padStart(2, '0');
var timeStr = hours + ":" + minutes;
if (diffDays === 0) {
nextStartText = "Next start today at " + timeStr;
} else if (diffDays === 1) {
nextStartText = "Next start tomorrow at " + timeStr;
} else {
var days = ['Sun', 'Mon', 'Tue', 'Wed', 'Thu', 'Fri', 'Sat'];
nextStartText = "Next start " + days[nextDate.getDay()] + " " + timeStr;
// STATUS EVALUATION
// 1. Errors & Fatal Faults
if (state === "ERROR" || state === "FATAL_ERROR") {
mainStatus = "Error";
if (errorMessage && errorMessage !== "NULL" && errorMessage !== "UNDEF" && errorMessage !== "") {
mainDetail = errorMessage;
} else if (errorCode && errorCode !== "NULL" && errorCode !== "UNDEF" && errorCode !== "") {
mainDetail = "Error code: " + errorCode;
} else {
mainDetail = "Check mower console";
// 2. Stopped / Paused
} else if (state === "STOPPED" || activity === "STOPPED_IN_GARDEN") {
mainStatus = "Stopped";
mainDetail = "Stopped in garden";
} else if (state === "PAUSED") {
mainStatus = "Paused";
mainDetail = "Manual pause";
// 3. EPOS Planning / Satellite Search / Transient Startup
} else if (inactiveReason === "PLANNING" || inactiveReason === "SEARCHING_FOR_SATELLITES" || activity === "NOT_APPLICABLE") {
mainStatus = "Planning";
mainDetail = (inactiveReason === "SEARCHING_FOR_SATELLITES") ? "Acquiring satellite signal" : "Preparing & calculating path";
// 4. Transit / Movement ("On The Way")
} else if (activity === "LEAVING") {
mainStatus = "On The Way";
mainDetail = (activeAreaName && activeAreaName !== "NULL" && activeAreaName !== "UNDEF") ? "Going to " + activeAreaName : "Going to Work Area";
} else if (activity === "GOING_HOME") {
mainDetail = "Going to Charging Station";
// 5. Charging
} else if (activity === "CHARGING") {
mainStatus = "Charging";
mainDetail = nextStartText;
} else if (state === "RESTRICTED_PARK_OVERRIDE") {
mainDetail = "Until further notice";
} else {
mainDetail = "Charging battery";
// 6. Parked / Restricted States
} else if (state === "RESTRICTED_PARK_OVERRIDE" || state === "RESTRICTED_WEEK_SCHEDULE" || activity === "PARKED_IN_CS" || mode === "HOME") {
mainStatus = "Parked";
if (state === "RESTRICTED_FROST") {
mainDetail = "Frost guard active";
} else if (state === "RESTRICTED_SENSOR") {
mainDetail = "Weather timer active";
} else {
// 7. Active Mowing
} else if (activity === "MOWING") {
mainStatus = "Mowing";
if (activeProgress !== null && activeProgress !== "") {
mainDetail = activeProgress + " done in " + activeAreaName;
} else {
mainDetail = "Cutting " + activeAreaName;
} else if (mode === "SECONDARY_AREA") {
mainDetail = "Cutting secondary area";
} else {
mainDetail = "Cutting main area";
} else {
mainStatus = (state === "IN_OPERATION") ? "Planning" : state;
mainDetail = (activity !== "NULL" && activity !== "NOT_APPLICABLE") ? activity.replace(/_/g, ' ') : "Updating status...";
// POST UPDATES TO SYNTHETIC/PROXY ITEMS
items.getItem(BASE_PREFIX + "_Summary_Status").postUpdate(mainStatus);
items.getItem(BASE_PREFIX + "_Summary_Detail").postUpdate(mainDetail);
items.getItem(BASE_PREFIX + "_Current_Cutting_Height").postUpdate(currentCuttingHeight);
Setup Maps
The inclusion of the maps leverages the work @ltty did over on Husqvarna Automower Status Card , and if you are happy to use the online service, just use the ‘index.html’ on the above linked page, which sources the tiles from an online provider.
If you want to use locally cached map tiles, read on…
Create Maps Directory Structure & Install Prerequisites
# Create directory tree
sudo -u openhab mkdir -p /etc/openhab/html/mower/leaflet/images
sudo -u openhab mkdir -p /etc/openhab/html/mower/tiles
# Download Leaflet JS and CSS (pinned to v1.9.4)
sudo -u openhab curl -sSL https://unpkg.com/leaflet@1.9.4/dist/leaflet.js -o /etc/openhab/html/mower/leaflet/leaflet.js
sudo -u openhab curl -sSL https://unpkg.com/leaflet@1.9.4/dist/leaflet.css -o /etc/openhab/html/mower/leaflet/leaflet.css
# Download standard Leaflet marker assets (referenced by leaflet.css)
sudo -u openhab curl -sSL https://unpkg.com/leaflet@1.9.4/dist/images/marker-icon.png -o /etc/openhab/html/mower/leaflet/images/marker-icon.png
sudo -u openhab curl -sSL https://unpkg.com/leaflet@1.9.4/dist/images/marker-icon-2x.png -o /etc/openhab/html/mower/leaflet/images/marker-icon-2x.png
sudo -u openhab curl -sSL https://unpkg.com/leaflet@1.9.4/dist/images/marker-shadow.png -o /etc/openhab/html/mower/leaflet/images/marker-shadow.png
Setup Map Download Rule
This rule will both perform the initial download of the Maps, and populate the above directories, however can also be setup via a cron-job (say Monthly), to ensure you have the latest tiles downloaded. Just make sure you setup the Lat/Lon coordinates appropriate to your site (I used Google Earth to determine these),
const Files = Java.type("java.nio.file.Files");
const Paths = Java.type("java.nio.file.Paths");
const StandardCopyOption = Java.type("java.nio.file.StandardCopyOption");
const URI = Java.type("java.net.URI");
const NORTH_LAT = -0.0000;
const SOUTH_LAT = -0.0000;
const WEST_LON = 0.0000;
const EAST_LON = 0.0000;
const ZOOM_LEVELS = [17, 18, 19, 20];
const OUTPUT_DIR = "/etc/openhab/html/mower/tiles";
const URL_TEMPLATE = "https://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer/tile/{z}/{y}/{x}";
function deg2num(lat, lon, zoom) {
let latRad = (lat * Math.PI) / 180.0;
let n = Math.pow(2, zoom);
let xtile = Math.floor(((lon + 180.0) / 360.0) * n);
let ytile = Math.floor((1.0 - Math.asinh(Math.tan(latRad)) / Math.PI) / 2.0 * n);
return { x: xtile, y: ytile };
let updated = 0;
let unchanged = 0;
ZOOM_LEVELS.forEach(z => {
let min = deg2num(NORTH_LAT, WEST_LON, z);
let max = deg2num(SOUTH_LAT, EAST_LON, z);
let xStart = Math.min(min.x, max.x);
let xEnd = Math.max(min.x, max.x);
let yStart = Math.min(min.y, max.y);
let yEnd = Math.max(min.y, max.y);
for (let x = xStart; x <= xEnd; x++) {
for (let y = yStart; y <= yEnd; y++) {
let targetDir = Paths.get(OUTPUT_DIR, String(z), String(x));
let targetFile = Paths.get(OUTPUT_DIR, String(z), String(x), `${y}.jpg`);
let tileUrl = URL_TEMPLATE.replace("{z}", z).replace("{x}", x).replace("{y}", y);
let conn = URI.create(tileUrl).toURL().openConnection();
conn.setRequestProperty("User-Agent", "openHAB-TileChecker/1.0");
// If local file exists, tell server to only return data if modified since our local timestamp
if (Files.exists(targetFile)) {
let lastModifiedMillis = Files.getLastModifiedTime(targetFile).toMillis();
conn.setIfModifiedSince(lastModifiedMillis);
conn.connect();
let responseCode = conn.getResponseCode();
if (responseCode === 200) {
// 200 OK: Tile is new or updated
Files.createDirectories(targetDir);
let inStream = conn.getInputStream();
Files.copy(inStream, targetFile, StandardCopyOption.REPLACE_EXISTING);
inStream.close();
// Sync local file timestamp to server's Last-Modified header if present
let serverLastModified = conn.getLastModified();
if (serverLastModified > 0) {
let fileTime = Java.type("java.nio.file.attribute.FileTime").fromMillis(serverLastModified);
Files.setLastModifiedTime(targetFile, fileTime);
updated++;
} else if (responseCode === 304) {
// 304 Not Modified: Imagery has not changed
unchanged++;
conn.disconnect();
console.info(`Tile check finished: ${updated} updated/downloaded, ${unchanged} unchanged.`);
Create Map Renderer
This, again, is the version which uses local tiles. Just make sure you set the centre location in the script, and the ‘Box Bounds’ (all currently xx.xxxx and yyy.yyyy in the below):
Make sure this is created using the openhab user:
sudo -U openhab nano index.html
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="utf-8">
<meta name="viewport" content="width=device-width, initial-scale=1.0">
<title>Automower Live Tracker</title>
<!-- Locally hosted Leaflet CSS -->
<link rel="stylesheet" href="leaflet/leaflet.css"/>
<style>
html, body {
height: 100%;
margin: 0;
padding: 0;
background: #1a1a2e;
overflow: hidden;
font-family: -apple-system, BlinkMacSystemFont, "Segoe UI", Roboto, sans-serif;
#map {
width: 100%;
height: 100vh;
#msg {
position: absolute;
inset: 0;
display: flex;
align-items: center;
justify-content: center;
color: #8888aa;
font-size: 14px;
pointer-events: none;
z-index: 1000;
#status-overlay {
position: absolute;
top: 10px;
right: 10px;
background: rgba(26, 26, 46, 0.85);
border: 1px solid rgba(255, 255, 255, 0.15);
color: #e0e0e0;
padding: 6px 12px;
border-radius: 6px;
font-size: 11px;
line-height: 1.4;
z-index: 999;
backdrop-filter: blur(4px);
</style>
</head>
<body>
<div id="map"></div>
<div id="msg">Loading track…</div>
<div id="status-overlay" style="display: none;"></div>
<!-- Locally hosted Leaflet JS -->
<script src="leaflet/leaflet.js"></script>
<script>
var params = new URLSearchParams(window.location.search);
var itemName = params.get('item') || 'Automower_Location';
var serviceId = params.get('serviceId') || 'influxdb';
var offsetNorth = parseFloat(params.get('offsetN') || '0');
var offsetEast = parseFloat(params.get('offsetE') || '0');
var trackPeriod = params.get('period') || '24h';
// Center of your property coordinates
var YARD_CENTER = [xx.xxxx, yyy.yyyy];
// Bounding box from your polygon coordinates
var YARD_BOUNDS = [
[-xx.xxxx, yyy.yyyy], // Southwest
[-xx.xxxx, yyy.yyyy] // Northeast
var map = null;
var marker = null;
var polyline = null;
var path = [];
var MOWER_ICON = L.divIcon({
html: '<svg xmlns="http://www.w3.org/2000/svg" width="26" height="26" viewBox="0 0 26 26"' +
' style="filter:drop-shadow(0 2px 5px rgba(0,0,0,0.7))">' +
'<circle cx="5" cy="5" r="3.2" fill="#222" stroke="#fff" stroke-width="1.2"/>' +
'<circle cx="21" cy="5" r="3.2" fill="#222" stroke="#fff" stroke-width="1.2"/>' +
'<circle cx="5" cy="21" r="3.2" fill="#222" stroke="#fff" stroke-width="1.2"/>' +
'<circle cx="21" cy="21" r="3.2" fill="#222" stroke="#fff" stroke-width="1.2"/>' +
'<rect x="5" y="5" width="16" height="16" rx="3" fill="#4CAF50" stroke="#fff" stroke-width="1.5"/>' +
'<circle cx="13" cy="13" r="3.5" fill="rgba(255,255,255,0.25)" stroke="rgba(255,255,255,0.6)" stroke-width="1"/>' +
'</svg>',
className: '',
iconSize: [26, 26],
iconAnchor: [13, 13]
function applyOffset(lat, lon) {
if (offsetNorth === 0 && offsetEast === 0) {
return [lat, lon];
var earthRadius = 6378137.0; // WGS84 major radius in meters
var deltaLat = (offsetNorth / earthRadius) * (180 / Math.PI);
var deltaLon = (offsetEast / (earthRadius * Math.cos(lat * Math.PI / 180))) * (180 / Math.PI);
return [lat + deltaLat, lon + deltaLon];
function calculateStartTime(periodStr) {
var match = String(periodStr).trim().match(/^(\d+)([mhd])$/i);
var now = Date.now();
if (!match) {
// Fallback: 24 hours
return new Date(now - 24 * 3600 * 1000).toISOString();
var value = parseInt(match[1], 10);
var unit = match[2].toLowerCase();
var ms = 0;
if (unit === 'm') ms = value * 60 * 1000;
else if (unit === 'h') ms = value * 3600 * 1000;
else if (unit === 'd') ms = value * 86400 * 1000;
return new Date(now - ms).toISOString();
function updateOverlay(lat, lon) {
var overlay = document.getElementById('status-overlay');
var now = new Date().toLocaleTimeString([], { hour: '2-digit', minute: '2-digit', second: '2-digit' });
overlay.innerHTML = '<strong>' + itemName + '</strong><br>' +
lat.toFixed(6) + ', ' + lon.toFixed(6) + '<br>' +
'<span style="color:#888;">Updated: ' + now + '</span>';
overlay.style.display = 'block';
function initMap(lat, lon) {
document.getElementById('msg').style.display = 'none';
if (map) return;
var startLat = (lat !== undefined && lat !== null) ? lat : YARD_CENTER[0];
var startLon = (lon !== undefined && lon !== null) ? lon : YARD_CENTER[1];
map = L.map('map', {
zoomControl: false,
attributionControl: false,
maxBounds: YARD_BOUNDS,
maxBoundsViscosity: 0.8
}).setView([startLat, startLon], 19);
// Point directly to locally stored tiles
L.tileLayer('tiles/{z}/{x}/{y}.jpg', {
minZoom: 17,
maxZoom: 21,
maxNativeZoom: 20,
errorTileUrl: ''
}).addTo(map);
window.addEventListener('resize', function() { map.invalidateSize(); });
setTimeout(function() { map.invalidateSize(); }, 200);
function redraw() {
if (!map || path.length === 0) return;
var last = path[path.length - 1];
if (polyline) map.removeLayer(polyline);
if (path.length > 1) {
polyline = L.polyline(path, {
color: '#FF6B35',
weight: 3,
opacity: 0.9,
lineJoin: 'round'
}).addTo(map);
if (marker) map.removeLayer(marker);
marker = L.marker([last[0], last[1]], { icon: MOWER_ICON }).addTo(map);
updateOverlay(last[0], last[1]);
function parseState(text) {
if (!text || text === 'NULL' || text === 'UNDEF') return null;
var parts = text.trim().split(',');
if (parts.length < 2) return null;
var lat = parseFloat(parts[0]);
var lon = parseFloat(parts[1]);
if (isNaN(lat) || isNaN(lon)) return null;
return applyOffset(lat, lon);
function fetchHistory() {
if (!itemName) {
initMap(YARD_CENTER[0], YARD_CENTER[1]);
return;
var startTime = calculateStartTime(trackPeriod);
var url = '/rest/persistence/items/' + encodeURIComponent(itemName) +
'?starttime=' + encodeURIComponent(startTime) +
'&serviceId=' + encodeURIComponent(serviceId) +
'&boundary=false';
fetch(url)
.then(function(r) { return r.ok ? r.json() : Promise.reject(r.status); })
.then(function(data) {
var pts = (data.data || []).map(function(d) { return parseState(d.state); })
.filter(function(p) { return p !== null; });
if (pts.length === 0) {
document.getElementById('msg').textContent = 'No movement recorded for selected period (' + trackPeriod + ')';
fetchPosition();
return;
path = pts;
initMap(last[0], last[1]);
redraw();
map.fitBounds(L.polyline(path).getBounds(), { padding: [25, 25], maxZoom: 19 });
.catch(function() {
fetchPosition();
function fetchPosition() {
if (!itemName) return;
fetch('/rest/items/' + encodeURIComponent(itemName) + '/state', { headers: { Accept: 'text/plain' } })
.then(function(r) { return r.ok ? r.text() : Promise.reject(r.status); })
.then(function(text) {
var pos = parseState(text);
if (!pos) {
return;
initMap(pos[0], pos[1]);
var moved = !last || Math.abs(last[0] - pos[0]) > 0.000005 || Math.abs(last[1] - pos[1]) > 0.000005;
if (!moved) return;
path.push(pos);
redraw();
map.panTo([pos[0], pos[1]]);
.catch(function() {
fetchHistory();
setInterval(fetchPosition, 30000);
</script>
</body>
</html>
Create MainUI Widget
Background: This is a dynamic widget, which should not require configuration as you change work areas in future, but do remember that the applicable steps for Work Areas described in the earlier sections, will need to be repeated for any new work areas.
Create a new widget called automower_control_widget via Main UI.
Paste the following into the code tab:
uid: automower_control_widget
tags: []
props:
parameters:
- default: automower_core
description: Base prefix for core items (e.g. automower_core)
label: Core Item Prefix
required: false
type: TEXT
- default: automower_work_areas
description: Independent tag assigned to work area items (e.g. automower_work_areas)
label: Work Area Tag
required: false
type: TEXT
- default: 2
description: Minimum allowed value for the cutting height slider
label: Minimum Cutting Height
required: false
type: DECIMAL
- default: 6
description: Maximum allowed value for the cutting height slider
label: Maximum Cutting Height
required: false
type: DECIMAL
- default: 0
description: North (+) or South (-) offset in meters
label: Map North/South Offset (m)
required: false
type: DECIMAL
- default: 0
description: East (+) or West (-) offset in meters
label: Map East/West Offset (m)
required: false
type: DECIMAL
- default: 24h
description: Track history lookback duration (e.g. 1h, 6h, 12h, 24h, 2d, 7d)
label: Track History Period
required: false
type: TEXT
parameterGroups: []
component: f7-block
style:
margin: 0
padding: 0
slots:
default:
- component: div
class: row
style:
display: flex
flex-wrap: wrap
margin: 0
width: 100%
slots:
default:
# Card 1: Core Status & Controls
- component: div
class: col-100 col-md-50 col-xl-25
style:
box-sizing: border-box
margin-bottom: 16px
padding: 0 8px
slots:
default:
- component: oh-list-card
noShadow: true
outline: false
style:
-webkit-backdrop-filter: blur(12px)
background: "=themeOptions.dark === 'dark' ? 'rgba(255, 255, 255, 0.05)' : 'rgba(0, 0, 0, 0.03)'"
border: "=themeOptions.dark === 'dark' ? '1px solid rgba(255, 255, 255, 0.12)' : '1px solid rgba(0, 0, 0, 0.08)'"
border-radius: 12px
margin: 0
padding: 12px
slots:
default:
- component: f7-block
style:
align-items: center
display: flex
justify-content: space-between
margin: 0
padding: 0
slots:
default:
- component: Label
style:
color: "=(items[props.basePrefix + '_Summary_Status'].state === 'Error') ? '#e74c3c' : (items[props.basePrefix + '_Summary_Status'].state === 'Paused' || items[props.basePrefix + '_Summary_Status'].state === 'Stopped') ? '#f39c12' : (items[props.basePrefix + '_Summary_Status'].state === 'Charging') ? '#f1c40f' : (items[props.basePrefix + '_Summary_Status'].state === 'Mowing') ? '#2ecc71' : (items[props.basePrefix + '_Summary_Status'].state === 'Planning' || items[props.basePrefix + '_Summary_Status'].state === 'On The Way') ? '#1abc9c' : '#3498db'"
font-size: 24px
font-weight: 800
letter-spacing: 0.5px
text: =items[props.basePrefix + '_Summary_Status'].state
- component: f7-chip
color: "=Number.parseFloat(items[props.basePrefix + '_Battery_Level'].state) >= 75 ? 'green' : (Number.parseFloat(items[props.basePrefix + '_Battery_Level'].state) >= 25 ? 'orange' : 'red')"
iconF7: "=Number.parseFloat(items[props.basePrefix + '_Battery_Level'].state) >= 75 ? 'battery_100' : (Number.parseFloat(items[props.basePrefix + '_Battery_Level'].state) >= 25 ? 'battery_25' : 'battery_0')"
text: =items[props.basePrefix + '_Battery_Level'].state + '%'
style:
margin: 4px 0 12px 0
padding: 0
slots:
default:
- component: Label
style:
color: "=(items[props.basePrefix + '_Summary_Status'].state === 'Error') ? '#e74c3c' : (themeOptions.dark === 'dark' ? 'rgba(255, 255, 255, 0.7)' : 'rgba(0, 0, 0, 0.06)')"
font-size: 14px
font-weight: "=(items[props.basePrefix + '_Summary_Status'].state === 'Error') ? 600 : 500"
text: =items[props.basePrefix + '_Summary_Detail'].state
style:
display: flex
gap: 10px
margin: 12px 0 8px 0
padding: 0
slots:
default:
- component: oh-button
fill: true
iconF7: house_fill
popoverOpen: .park-popover
style:
--f7-button-bg-color: "#3498db"
--f7-button-text-color: "#ffffff"
border-radius: 8px
flex: 1
action: command
actionCommand: ON
actionItem: =props.basePrefix + '_Pause'
fill: true
iconF7: pause_fill
style:
--f7-button-bg-color: "#f39c12"
border-radius: 8px
flex: 1
visible: =items[props.basePrefix + '_Summary_Status'].state === 'Mowing' || items[props.basePrefix + '_Summary_Status'].state === 'On The Way'
fill: true
iconF7: play_fill
popoverOpen: .play-popover
style:
--f7-button-bg-color: "#2ecc71"
border-radius: 8px
flex: 1
visible: =items[props.basePrefix + '_Summary_Status'].state !== 'Mowing' && items[props.basePrefix + '_Summary_Status'].state !== 'On The Way'
- component: f7-popover
class: park-popover
slots:
default:
inset: false
slots:
default:
- component: oh-list-item
groupTitle: true
title: Choose Duration
action: command
actionCommand: "30"
actionItem: =props.basePrefix + '_Park_with_Duration'
icon: f7:timer
popoverClose: true
title: 30 Minutes
action: command
actionCommand: "180"
icon: f7:timer
popoverClose: true
title: 3 Hours
action: command
actionCommand: "1440"
icon: f7:timer
popoverClose: true
title: 24 Hours
groupTitle: true
title: Park Until
action: command
actionCommand: ON
actionItem: =props.basePrefix + '_Park_Until_Next_Schedule'
icon: f7:calendar
popoverClose: true
title: Until Next Schedule
action: command
actionCommand: ON
actionItem: =props.basePrefix + '_Park_and_Pause_the_Schedule'
icon: f7:pause_circle
popoverClose: true
title: Until Further Notice
class: play-popover
slots:
default:
inset: false
slots:
default:
action: command
actionCommand: ON
actionItem: =props.basePrefix + '_Resume_Schedule'
icon: f7:play_fill
popoverClose: true
title: Resume Schedule
groupTitle: true
title: Select Work Area
- component: oh-repeater
fetchMetadata: workAreaId
for: area
fragment: true
itemTags: =props.workAreasTag
sourceType: itemsWithTags
slots:
default:
action: command
actionCommand: =loop.area.metadata.workAreaId.value
actionItem: =props.basePrefix + '_Start_in_Work_Area'
icon: f7:layers
popoverClose: true
title: =items[loop.area.name + '_Name'].state
- component: div
style:
border-top: "=themeOptions.dark === 'dark' ? '1px solid rgba(255, 255, 255, 0.1)' : '1px solid rgba(0, 0, 0, 0.08)'"
margin: 8px 0
- component: oh-label-item
icon: f7:layers
iconColor: blue
item: =props.basePrefix + '_Work_Area_Name'
title: "=(device.desktop) ? 'Active Work Area' : 'Area'"
visible: =items[props.basePrefix + '_Work_Area_Name'].state != 'NULL' && items[props.basePrefix + '_Work_Area_Name'].state != 'UNDEF'
icon: f7:arrow_up_down_circle
iconColor: green
item: =props.basePrefix + '_Current_Cutting_Height'
title: Cutting Height
after: "=items[props.basePrefix + '_Last_Update'].state !== 'NULL' && items[props.basePrefix + '_Last_Update'].state !== 'UNDEF' ? dayjs(items[props.basePrefix + '_Last_Update'].state).format('DD-MMM HH:mm:ss') : '-'"
icon: f7:clock
iconColor: gray
title: "=(device.desktop) ? 'Last Status Update' : 'Updated'"
# Card 2: Live Tracking (Map)
- component: div
style:
margin-bottom: 16px
padding: 0 8px
slots:
default:
accordionList: true
noShadow: true
outline: false
style:
border-radius: 12px
margin: 0
title: Live Tracking
slots:
default:
accordionItem: true
accordionItemOpened: false
icon: f7:map
iconColor: green
subtitle: Click to view live map
title: Map View
slots:
accordion:
- component: oh-webframe-card
borders: false
height: 500
noBorder: true
noShadow: true
outline: false
src: "='/static/mower/index.html?item=' + props.basePrefix + '_Last_GPS_Position&serviceId=influxdb&offsetN=' + (props.offsetNorth || 0) + '&offsetE=' + (props.offsetEast || 0) + '&period=' + (props.trackPeriod || '24h')"
# Card 3: Work Areas
- component: div
style:
margin-bottom: 16px
padding: 0 8px
slots:
default:
accordionList: true
noShadow: true
outline: false
style:
border-radius: 12px
margin: 0
title: Work Areas
slots:
default:
accordionList: true
for: i
fragment: true
slots:
default:
accordionItem: true
badge: "=items[loop.i.name + '_Enabled'].state !== 'ON' ? 'Disabled' : ((items[props.basePrefix + '_Summary_Status'].state === 'Mowing' || items[props.basePrefix + '_Summary_Status'].state === 'On The Way') && items[props.basePrefix + '_Work_Area_Name'].state === items[loop.i.name + '_Name'].state) ? 'Mowing' : 'Enabled'"
badgeColor: "=items[loop.i.name + '_Enabled'].state !== 'ON' ? 'gray' : ((items[props.basePrefix + '_Summary_Status'].state === 'Mowing' || items[props.basePrefix + '_Summary_Status'].state === 'On The Way') && items[props.basePrefix + '_Work_Area_Name'].state === items[loop.i.name + '_Name'].state) ? 'blue' : 'green'"
icon: f7:layers
iconColor: "=((items[props.basePrefix + '_Summary_Status'].state === 'Mowing' || items[props.basePrefix + '_Summary_Status'].state === 'On The Way') && items[props.basePrefix + '_Work_Area_Name'].state === items[loop.i.name + '_Name'].state) ? 'green' : 'blue'"
title: =items[loop.i.name + '_Name'].state
slots:
accordion:
nested: true
style:
padding-left: 20px
slots:
default:
- component: oh-toggle-item
icon: f7:power
iconColor: green
item: =loop.i.name + '_Enabled'
title: "=(device.desktop) ? 'Area Enabled' : 'Enabled'"
icon: f7:chart_bar
iconColor: blue
item: =loop.i.name + '_Progress'
title: "=(device.desktop) ? 'Mowing Progress' : 'Progress'"
after: "=items[loop.i.name + '_Last_Time_Completed'].state !== 'NULL' && items[loop.i.name + '_Last_Time_Completed'].state !== 'UNDEF' ? dayjs(items[loop.i.name + '_Last_Time_Completed'].state).format('DD-MMM HH:mm:ss') : '-'"
icon: f7:calendar_today
iconColor: gray
title: "=(device.desktop) ? 'Last Completed Time' : 'Completed'"
- component: oh-slider-item
iconColor: green
item: =loop.i.name + '_Cutting_Height'
label: true
max: =Number(props.maxCuttingHeight)
min: =Number(props.minCuttingHeight)
releaseOnly: true
step: 0.5
style:
--f7-list-item-after-font-weight: 600
--f7-list-item-after-min-width: 65px
--f7-range-bar-active-bg-color: "#1e90ff"
--f7-range-bar-bg-color: "=themeOptions.dark === 'dark' ? 'rgba(255, 255, 255, 0.08)' : 'rgba(0, 0, 0, 0.04)'"
--f7-range-bar-border-radius: 7px
--f7-range-bar-size: 14px
--f7-range-knob-box-shadow: 0px 2px 6px rgba(0,0,0,0.3)
--f7-range-knob-color: "#ffffff"
--f7-range-knob-size: 22px
--f7-range-label-bg-color: "#1e90ff"
--f7-range-label-border-radius: 6px
--f7-range-label-text-color: "#ffffff"
padding-right: 4px
# Card 4: Service & Maintenance
- component: div
style:
margin-bottom: 16px
padding: 0 8px
slots:
default:
noShadow: true
outline: false
style:
border-radius: 12px
margin: 0
title: Service & Maintenance
slots:
default:
icon: f7:timer
iconColor: gray
item: =props.basePrefix + '_Total_Running_Time'
title: "=(device.desktop) ? 'Total Running Time' : 'Total Hours'"
icon: f7:bolt_circle_fill
iconColor: orange
item: =props.basePrefix + '_Number_of_Charging_Cycles'
title: "=(device.desktop) ? 'Charging Cycles' : 'Charge Cycles'"
icon: f7:scissors
iconColor: red
item: =props.basePrefix + '_Cutting_Blade_Usage_Time'
title: "=(device.desktop) ? 'Cutting Blade Usage' : 'Blade Age'"
Add Widget to MainUI Page
You can insert the above widget into any page, but as an example, find the code for a simple page below which displays only the above widget:
version: 1
pages:
automower_control_page:
tags: []
props:
parameters: []
parameterGroups: []
component: oh-layout-page
label: Automower Control Page
sidebar: true
slots:
canvas: []
default:
- component: oh-block
config: {}
slots:
default:
- component: oh-grid-row
config: {}
slots:
default:
- component: oh-grid-col
width: "100"
slots:
default:
- component: widget:automower_control_widget
offsetNorth: 2
basePrefix: automower_core
workAreasTag: automower_work_areas
minCuttingHeight: 2.01
maxCuttingHeight: 6
grid: []
masonry: []
And then update the 4 following parameters at the top of the page, to match your installation:
basePrefix- Base prefix for core items (e.g. automower_core)workAreasTag- Independent tag assigned to work area items (e.g. automower_work_areas)minCuttingHeight- Minimum allowed value for the cutting height slidermaxCuttingHeight- Maximum allowed value for the cutting height slider
Testing, Tips & Notes
I will add to this section, as I collect learnings
- The logs will be your friend for any fault finding…Mismatched item names will make an appearance in there fairly quick !!
- Remember that the Binding has a 5 minute update interval by default (for valid reasons) - Quite a few things will update immediately, others less so… (I think there was a recent change to using Websockets for some aspects, which may explain the immediate updates)
- For the Work Area Names to display correctly in the UI, on Mobile, they need to be sufficiently short (Desktop is fine):
- e.g. House South West, and House South East will both display in the Mobile UI as ‘House South’
- Changing these to House SW and House SE fixed the problem. This is done in the Husqvarna App, in the ‘Map’ tab. As the work-area names are dynamically populated in the Main UI page, these will just come through automatically
Good luck…
Change Log
V1.1
- Have added a map, based on the great work that @Ltty did over on Husqvarna Automower Status Card , with a couple of differences:
- This uses locally stored tiles, as I prefer less reliance on external services
- It also allows for offset configuration (N-S, E-W) like the Husqvarna app does, so it doesn’t appear that the mower is busy inside your house
- The offsets are passed as parameters to the ‘index.html’, also along with History duration, so these can be manipulated within the Widget properties
- The map is expandable, and doesn’t appear by default, keeping in line with what I have done for work areas, etc
- I have also included the rule here, to download and keep the ‘cached’ tiles up-to-date
- The MainUI page has now been converted to a widget
- An example to embed it within a MainUI page is also included
