I’m setting up a new instance of Openhab 3. I am currently running 2.5 and am using autoupdate=“false” on a switch to simulate a push button switch. How can I replicate this in OH3? I assume I need to edit the YAML code in the channel configuration but cannot get it to work. Has anyone else successfully created a push button?
Under “add metadata” there is an “auto-update” option where you can set the flag to false.
Thank you so much.
