it seems to work if you just create a blank txt document with append .rules i can live with that thanks for your help i have alot of light rules to sort now im doing lighs because the rules are simple
Can you add notes and descriptions to your rules
I have been using this command too turn off my hue colour light
sendCommand( BULB6LRMAIN1_Color, 63,3,0)
i would like to be able to add a only if light is not already set at 100 brightness that would be
63,3,100
but if somone changed the color of the bulb the first two numbers would be different so i cant use
if =63,3,100
is there a wildcard option like
if =*,*,100
Try this Code
rule "RGB"
Item your_item changed
var HSBType currentState
currentState = BULB6LRMAIN1_Color.state
var PercentType bright = currentState.getBrightness()
if (bright != 100) {
I will try more tomorrow now i have been trying to get this rule to work for ages its supposed to set the main light to a warm colour but only if its not set on bright white full brightness and movie mode is not enabled.
i just cant get it to work i have tried as many variations as i can think of but i think im just not skilled enought to understand whats wrong yet i just keep getting errors on KARAF console
rule "Auto Warm"
Time cron " 0 0 22 1/1 * ? *"
if (Movie_Mode_Trigger.state == OFF) {
if (BULB6LRMAIN1_Color.state != 63,3,100) {
BULB6LRMAIN1_Color.sendCommand(29,100,48)
00:16:41.137 [WARN ] [.core.internal.folder.FolderObserver] - Error while opening file during update: C:\Users\Sharpy\DOWNLO~1\OPENHA~1.0\conf\rules\Untitled-1.rules
00:16:41.436 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Untitled-1.rules'
00:16:41.437 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'Untitled-1.rules' is either empty or cannot be parsed correctly!
00:16:41.448 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'Untitled-1.rules' has errors, therefore ignoring it: [6,37]: mismatched input ',' expecting ')'
[6,39]: mismatched input ',' expecting '}'
[6,43]: mismatched input ')' expecting 'end'
Thanks for all your help you have helped me get quite a few rules transfered to text based ones its nearly bed time so will read this again and try again tomorrow now
this line has Errors
if (BULB6LRMAIN1_Color.state != "63,3,100") {
I think so is right
i will try before i go bed its a quick change if it works i can kick myself in my dreams lol
the rule was accepted after your edit making me feel stupid lol
the rule ran but seemed to have a strange outcome like it changed the wrong value or only accepted the first digit of the 3 i will update tomorrow now
00:37:12.468 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'BULB6LRMAIN1_Color' received command 63,3,100
00:37:12.468 [INFO ] [marthome.event.ItemStateChangedEvent] - BULB6LRMAIN1_Color changed from 63,3,29 to 63,3,100
00:37:19.756 [INFO ] [marthome.event.ItemStateChangedEvent] - Plug5AMP_Signal changed from -45 to -46
00:37:19.955 [INFO ] [marthome.event.ItemStateChangedEvent] - Plug2_Signal changed from -51 to -50
00:37:19.955 [INFO ] [marthome.event.ItemStateChangedEvent] - Plug3_Signal changed from -44 to -47
00:37:20.648 [INFO ] [marthome.event.ItemStateChangedEvent] - PLUG6TylerSTV_Signal changed from -57 to -56
00:37:49.797 [INFO ] [marthome.event.ItemStateChangedEvent] - Plug5AMP_Signal changed from -46 to -47
00:37:49.992 [INFO ] [marthome.event.ItemStateChangedEvent] - Plug2_Signal changed from -50 to -53
00:37:50.688 [INFO ] [marthome.event.ItemStateChangedEvent] - PLUG6TylerSTV_Signal changed from -56 to -58
00:38:00.046 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'BULB6LRMAIN1_Color' received command 29
00:38:00.046 [INFO ] [marthome.event.ItemStateChangedEvent] - BULB6LRMAIN1_Color changed from 63,3,100 to 63,3,29
This must be work
rule "Auto Warm"
if (BULB6LRMAIN1_Color.state instanceof HSBType) {
var DecimalType hue = currentState.getHue()
var PercentType sat = currentState.getSaturation()
if ( hue != 63 && sat != 3 && bright != 100 ) BULB6LRMAIN1_Color.sendCommand(29,100,48)
im back thanks for that i will try now and get post back
i copied the rule exactly how you said just changed the cron time
rule "Auto Warm"
Time cron " 0 6 14 1/1 * ? *"
movie mode was off and the bulb was also off but nothing happened after cron time
Try this … the sendCommand was wrong … I just copy it
rule "Auto Warm"
Time cron "0 0 22 1/1 * ? *"
if ( hue != 63 && sat != 3 && bright != 100) {
BULB6LRMAIN1_Color.sendCommand(new HSBType(new DecimalType(29), new PercentType(100), new PercentType(48)))
i did have a try of this but was busy yesterday it didn’t seem too work will try again after running some backups
i have tried this a few times now same response nothing happens
i have tried with the light off nothing happens
i have tried with the light set to a random colour nothing changes
im not sure whats wrong
after more learning im assuming that the early versions of this rule that you sent me where it just set the light to white instead of a colour in error it was caused by the quote marks not being in the send command i cant check as you edited over the older version of the rule
