Autowarm (CLOSED)
hi everyone im trying to transferer my rules created in paperui experimental engine to text based rules
my rule isnt working my ruke is
rule "Test LRLamp 20%@12:03PM Daily"
Time cron "	0 3 0 1/1 * ? *"
if (Lamp1_Brightness >= 20) {
sendCommand(Lamp1_Brightness, 20)
when this rule runs the log:tail command returns error
00:03:00.059 [ERROR] [ntime.internal.engine.ExecuteRuleJob] - Error during the execution of rule Test LRLamp 20%@10PM Daily: An error occurred during the script execution: The name '<XFeatureCallImplCustom> >= <XNumberLiteralImpl>' cannot be resolved to an item or type.
Sounds like it couldn’t find your Lamp1_Brightness item. You could try checking the items in Karaf, or log the state before the IF in your rule…
Your rule is error because Lamp1_Brightness is an item. You must do that :
rule "Test LRLamp 12:03PM Daily"
if ((Lamp1_Brightness.state as DecimalType).intValue >= 20) {
Is Brightness really Decimal … I think PercentType is correct…
I think this isn’t needed … I think this would be work too:
  Time cron "0 3 0 1/1 * ? *"
  if (Lamp1_Brightness.state >= 20) {
    Lamp1_Brightness.sendCommand(20)
im still pretty new too all the text based stuff so its hard to understand i might aswell learn french lol thanks everyone for your help
could you please explain why you made the changes to the origianal code and why it wasent working and why it now would
To Access the State of any Item you must describe it in rule. -> item.state not only item
the .state was missing then i will try now and get back too you
rule "Test KL 1:20PM Daily"
  Time cron "0 22 13 1/1 * ? *"
  if (BULB1DSKITCHEN_Brightness.state >= 20) {
    BULB1DSKITCHEN_Brightness.sendCommand(20)
this rule worked thanks for that i only made changes to the cron so it would run now and changed also changed bulb as people were using lamp 1
is there a way to slowly fade the light from 100 to 10 over an hour or so period ?
Maybe you can get some hints from this thread?
iv just looked throught there i will read it again see if i can make sense of it i was hoping for a simple command
like decrease brightness of lamp by -5 run by a cron time nothings ever simple lol
ok i have got my rule running the rule is still
rule "Dim LR Light @ 10:00PM Daily"
  Time cron "	0 0 22 1/1 * ? *"
could someone tell me how to add a only if to my rule i need the rule to run as long as Movie Mode is not Enabled
my movie mode trigger is called
Movie_Mode_Trigger changed from NULL to ON
if (Movie_Mode_Trigger.state == OFF) {
Thanks for that i will add it into my rule now
i was recomended a text editior too help with creating rules with OH cant remember what its called any ideas ?
just found that myself waiting for install i just didnt think the one i was recomended was called that
https://docs.openhab.org/configuration/editors.html
Here are all listed :slight_smile:
what editor would you recomend
do you after enable the openhab eextension or set it as a default in studio code i have pasted a rule and its just white text not colored i have downloaded and installed the OH extention
Works when opening a rule thanks
I don’t know …
I use Atom on my Macbook…
There is no Packages especially for Openhab… but rule code is JavaScript …
