Average calculation not working in Rule
I am trying to calculate the solar production average of the last 15 minutes. I read several examples with temperature, however I dont get it working with rules.
I have an Item which has the actual solar production with an htttp binding. That works fine. The data is stored in the internal RR4dJ Database.
In a rule I am trying to calculate the Average like this
var produktion = SolaranlageProduktion.state as Number
SolaranlageAverage.postUpdate(produktion.averageSince(now.minusMinute(15)))
Unfortunately I get the following error:
Script execution of rule with UID 'b28faa60d5' failed: var produktion = SolaranlageProduktion.state as Number
   1. The method averageSince(Object) is undefined for the type Number; line 2, column 96, length 12
   2. The method minusMinute(int) is undefined for the type ZonedDateTime; line 2, column 113, length 11
I also tried
then I get
1. The method minusMinute(int) is undefined for the type ZonedDateTime; line 2, column 97, length 11 2. Ambiguous feature call.
The extension methods
        postUpdate(Item, Number) in BusEvent and
        postUpdate(Item, State) in BusEvent
both match.; line 2, column 58, length 10
Can anyone help how to solve that issue?
  • Platform information:
    • OS: Docker containter
    • openHAB version: 3.1.0
So produktion is a Number variable.
Number variables do not have .averageSince() methods, only Items do.
Hence the report -
This one is self explanatory -
check spelling
Thanks for the answer. However that does not solve the problem.
I tried:
SolaranlageAverage.postUpdate(produktion.averageSince(now().minusMinutes(15)))
which gives:
SolaranlageAverage.postUpdate(produktion.averageSince(now( ___ ).minusMinutes(15)))
I fixed it.
It works like this
SolaranlageAverage.postUpdate(produktion.averageSince(now.minusMinutes(15))as Number)
