I made a rule which is pretty simple, still it gives me some problems…
It triggers on Sonoff_4CH_86_temp, and then uses that value to calculate the average temperature from the old readings.
rule "Work room temp averaging"
Item Sonoff_4CH_86_temp received update
var Number newValue = Sonoff_4CH_86_temp.state as DecimalType
var Number oldValue = Sonoff_4CH_86_tempAvg.state as DecimalType
var Number avgValue = 0
if(Sonoff_4CH_86_tempAvg.state instanceof DecimalType)
avgValue = (newValue.floatValue * 0.1) + (oldValue.floatValue * 0.9)
else
oldValue = newValue as DecimalType
avgValue = oldValue
sendUpdate(Sonoff_4CH_86_tempAvg, avgValue)
but I am getting this error in the log file
[ERROR] [.script.engine.ScriptExecutionThread] - Rule 'Work room temp averaging': org.eclipse.smarthome.core.library.types.DecimalType
Am I doing the value types wrong, or what is going wrong in my calculation?
