environment:
Raspberry Pi3B
Openhab 2.5.1
Fritzbox 7490 FW 7.19
With the automatic search the adapters are found several times, always via the 546e repeaters.
But in the binding the brigde (7490) was defined.
If you search for the DEC 200 you can also find them via the Fritzbox 7490 in the Inbox.
I have created the items in my own items and the addresses are correct.
This runs exactly one day.
Then the Dect 200 cannot be switched (manually, event trigger).
The whole thing has been rebuilt completely, same problem. Now you read that the Fritzbox sometimes rejects the connection? So why is the device online within OH2?
The only ones that can be addressed are the 546e repeaters because they are addressed directly over the IP.
Do you have any experience with DECT 200 and the connection to OH2?
Thanks in advance
