I want to manage different FritzBoxes at different places with OpenHAB 2.2.0.
As long as I can use an internal IP adress, I can access the corresponding box without any hassles. But as soon as I need to access it via its external adress (DynDNS) and https, I can not get any access. Here any magic out of my things config:
@cweitkamp That would be great! OpenHAB2 would be a great solution to me to connect several homes with one single interface! Hope to hear from you soon!
Time goes by and new features have been released. AVM released FRITZ!OS 7.0 which contains MyFRITZ! internet access to the FRITZ!Box without a warning from the browser (SSL certificate from Let’s Encrypt). Last weekend it was possible for me to setup a working connection from OH2 via MyFRITZ! service using HTTPS and a different port. I used the latest avmfritz binding version from OH2.4.0.M4 milestone without implementing any changes inside the code.
Is that a possible solution for you? If so I will guide you to enable it for you and will write a howto in the same breath.
