AVMFritz Binding DECT 200 Support
is it possible that the DECT 200 for the AVM FritzBinding is not fully supported at the moment? I receive updates for temperature and power but if I link an item to the outlet Channel I get NPE in DeviceHandler when sending a command to it in line 162: https://github.com/openhab/openhab2/blob/master/addons/binding/org.openhab.binding.avmfritz/src/main/java/org/openhab/binding/avmfritz/handler/DeviceHandler.java#L162
Looking at the code, it seems the connection is only initialized for the PL546E standalone thing type: https://github.com/openhab/openhab2/blob/master/addons/binding/org.openhab.binding.avmfritz/src/main/java/org/openhab/binding/avmfritz/handler/DeviceHandler.java#L83.
Isn´t it possible to switch the DECT 200 or am I doing something wrong?
Regards
Dennis
Can you give me an example for one switch. I need information about the openhab files *. cfg, items and sitemap.
thank you in advance
This is the things config file:
Bridge avmfritz:fritzbox:fritzbox [ ipAddress="192.168.178.1", user="openhab", password="openhab" ] {
    FRITZ_DECT_200 DECT1 [ ain="087610218095" ]
This the items file:
Switch Switch3 "Schalter Büro" (Office) { channel="avmfritz:FRITZ_DECT_200:fritzbox:DECT1:outlet" }
When executing
smarthome send Switch3 ON
I receive the exception posted above.
