Awtrix 3 Binding (formerly Awtrix Light)
There are some actions you can use. But I can also add this as a channel :+1:
Channel would be nice :wink:
Ok but those will be added on the bridge not the app.
Hm, not the best solution. No way to add it to the app Thing ?
The clock itself does not link sounds to apps, only to notifications. But sounds can be played anytime on the clock independent of apps. If you want a sound to be played when a certain app is shown it would probably be best to trigger this via a rule when the active app channel changes to the corresponding app name. The binding would need to do the same.
Just to make sure: have you realised that you can delete the thing after you disable the app? The app won’t come back then.
Yes, I tried that without success😩
Hmm that’s weird. If you set the app to disabled the retained message should be removed from the broker. Afterwards it should be safe to delete the app thing without the app coming back on the clock :thinking:
I will try again over the weekend
Could the issue be that I by mistake had a space in the ā€žwrongā€œ app name?
Yes that could be. You need the exact same name. If you have the awtrix iPhone app you can see the names of all active apps quite easily.
I will check…
I linked a new relase in the first post.
Apps Things that are deleted in OH will also be removed on the clock. Renaming of Apps in OH will now also remove the old app before a new one is created.
Thanks, gave it a try and this seems to work :+1:
Thank you for the feedback, its very much appreciated! I will add the other feature requests as soon as I find some spare time :+1:
I added the sound channels to the bridge in the latest release. Test was fine on my own clock.
I just installed from the marketplace in OH4.3.1 without any issues.
After updating to OH4.3.2, Awtrix app is no longer accessible via market place.
Indeed… hmm I haven’t set any version tags so I guess it should be shown. No idea why this happens :worried:
Strange, I have upgraded our democase today and reinstalled it from the marketplace.
Still working…
Today I can also see it. It did not pop up yesterday in the add-on store :man_shrugging:
