Still can’t see it. ![]()
Please check your marketplace setting, it is unpublished AFAIK
Hmm… I never had this option activated.
however… it doesn’t change anything, the binding still isn’t visible.
I will restart openHAB (but not until tomorrow) maybe this will help…
It has a published tag so it should not be necessary.
My instance is restarted every night for backup so this might have fixed it for me
Sorry, my bad, thought it did not.
After a complete restart, the Addon is back in the list…
I should have done the restart two days ago… ![]()
I have the same problem with the Twinkly binding. I cannot find the addon in the addon store. A restart did not solve it for me this time. Maybe I have better luck tomorrow ![]()
I “solved” this problem by opening the community marketplace settings in the UI and saving them (without changing anything). After that I could find the Twinkly binding. No idea why this happens but if anyone else cannot install this binding please try this first.
I just gave the windsurf IDE from Codeium a try to find out how well their AI called Cascade really is. I just let the AI create a README for this bundle and though it is not perfect I’m pretty impressed. Initially I copied the README of the espmilight binding and then asked Cascade to improve it. Here is what happened:
Me
Can you please rewrite this open README.md file so that it matches the contents of this awtrixlight bundle?
I'll help you rewrite the README.md file for the MQTT Awtrix Light bundle. First, let me gather information about the bundle's contents and structure.
Let me first look at the current README.md content:
Analyzed
README.md:(1-101)
Now let me search for relevant code in the bundle to understand its functionality:
Searched codebase
242 results
Based on the code I've found, I can see this is an MQTT binding for controlling Awtrix 3 LED matrix displays. Let me write a new README that better reflects the actual functionality:
Edited
README.md
+76
-195
25
Open diff
I've rewritten the README.md file to accurately reflect the MQTT Awtrix Light binding's functionality. The new README includes:
A clear introduction explaining what the binding does
Supported Things types (awtrixclock bridge and awtrixapp)
Prerequisites for using the binding
Detailed configuration parameters for both bridge and apps
Available channels for both bridge and apps
A complete example showing how to configure things and items
Information about discovery functionality
Available actions and how to use them
The new README is much more focused on the actual Awtrix Light functionality and removes all the irrelevant content about Milight/ESP8266 that was in the previous version. The structure is clearer and provides all the necessary information for users to get started with the binding.
And here is the actual result:
MQTT Awtrix Light Binding
This binding allows you to control Awtrix 3 LED matrix displays via MQTT. The Awtrix 3 is a customizable 32x8 LED matrix display that can show various information like time, weather, notifications and custom text/graphics.
Supported Things
This binding supports two types of things:
| Thing Type | Description |
awtrixclock (Bridge) |
Represents an Awtrix 3 display device. Acts as a bridge for apps. |
awtrixapp |
Represents an app running on the Awtrix display. Apps can show text, icons, notifications, etc. |
Prerequisites
- An MQTT broker (the MQTT binding must be installed and a broker configured)
- An Awtrix 3 LED matrix display configured to use MQTT
Thing Configuration
Bridge Configuration (awtrixclock)
| Parameter | Description | Required | Default |
basetopic |
The MQTT base topic for the Awtrix device | Yes | “awtrix” |
appLockTimeout |
Timeout in seconds before releasing app lock | No | 10 |
discoverDefaultApps |
Enable discovery of default apps | No | false |
lowBatteryThreshold |
Battery level threshold for low battery warning | No | 25 |
App Configuration (awtrixapp)
appname |
Name of the app | Yes | - |
useButtons |
Enable button control for this app | No | false |
Channels
Bridge Channels (awtrixclock)
| Channel | Type | Description |
brightness |
Dimmer | Display brightness |
power |
Switch | Power on/off |
batteryLevel |
Number | Battery level (if applicable) |
wifiSignal |
Number | WiFi signal strength |
temperature |
Number | Device temperature |
App Channels (awtrixapp)
text |
String | Text to display |
textCase |
Number | Text case (0=normal, 1=uppercase, 2=lowercase) |
icon |
String | Icon name to display |
color |
Color | Text color |
background |
Color | Background color |
rainbow |
Switch | Enable rainbow effect |
duration |
Number | Display duration in seconds |
lifetime |
Number | App lifetime |
Full Example
Things
Bridge mqtt:broker:myBroker [ host="localhost", port=1883 ]
Bridge mqtt:awtrixlight:myAwtrix "Awtrix Display" (mqtt:broker:myBroker) {
Thing awtrixapp clock "Clock App" [ appname="clock" ]
Thing awtrixapp weather "Weather App" [ appname="weather", useButtons=true ]
Items
// Bridge items
Dimmer Display_Brightness "Brightness [%d %%]" { channel="mqtt:awtrixlight:myAwtrix:brightness" }
Switch Display_Power "Power" { channel="mqtt:awtrixlight:myAwtrix:power" }
Number Display_Battery "Battery [%d %%]" { channel="mqtt:awtrixlight:myAwtrix:batteryLevel" }
// Weather app items
String Weather_Text "Weather Text" { channel="mqtt:awtrixlight:myAwtrix:weather:text" }
Color Weather_Color "Weather Color" { channel="mqtt:awtrixlight:myAwtrix:weather:color" }
Discovery
The binding can automatically discover Awtrix devices that publish their status to the configured MQTT broker. Once a device is discovered, it will appear in the inbox. Apps can also be discovered if discoverDefaultApps is enabled on the bridge.
Actions
The binding provides actions to control special features of the Awtrix display:
blinkIndicator(int indicatorId, int[] rgb, int blinkTimeInMs): Blink an indicator LED with specified color and duration
Example:
val actions = getActions("mqtt.awtrixlight", "mqtt:awtrixlight:myAwtrix")
actions.blinkIndicator(1, [255,0,0], 1000) // Blink first indicator red for 1 second
And after a few hints for improvements I got this. The question is now as always with AI features: Will it be faster to just write that myself or to review all of this properly? ![]()
Supported Things
awtrixapp |
Prerequisites
Thing Configuration
basetopic |
appLockTimeout |
appname |
useButtons |
Channels
brightness |
power |
display |
Switch | Display on/off |
batteryLevel |
low-battery |
Switch | Low battery warning |
wifiSignal |
Number | WiFi signal strength (RSSI) |
temperature |
Number:Temperature | Device temperature |
humidity |
Number | Relative humidity |
lux |
Number | Ambient light level |
sound |
Switch | Sound on/off |
autoBrightness |
Switch | Automatic brightness control |
buttonleft |
Trigger | Left button press event |
buttonright |
Trigger | Right button press event |
buttonselect |
Trigger | Select button press event |
indicator1 |
String | Control first indicator LED |
indicator2 |
String | Control second indicator LED |
indicator3 |
String | Control third indicator LED |
rtttl |
String | Play RTTTL ringtone |
screen |
String | Raw screen data |
app |
String | Currently active app |
active |
Switch | Enable/disable the app |
text |
textCase |
textOffset |
Number | Text offset position |
topText |
String | Text to display at the top |
icon |
pushIcon |
String | Push icon animation (STATIC, PUSHOUT, PUSHOUTRETURN) |
color |
background |
gradientColor |
Color | Secondary color for gradient effects |
rainbow |
duration |
lifetime |
lifetimeMode |
String | Lifetime mode |
scrollSpeed |
Number | Text scrolling speed |
effect |
String | Display effect |
effectSpeed |
Number | Effect animation speed |
effectBlend |
Switch | Blend effect with background |
effectPalette |
String | Color palette for effects |
autoscale |
Switch | Auto-scale content to fit display |
center |
Switch | Center content horizontally |
repeat |
Switch | Repeat animation |
blink |
Switch | Blink text |
fade |
Switch | Fade text |
bar |
Number | Progress bar value |
line |
Switch | Draw line |
progress |
Number | Progress value |
progressColor |
Color | Progress bar color |
progressBackground |
Color | Progress bar background color |
overlay |
Switch | Enable overlay mode |
reset |
Switch | Reset app to default state |
Full Example
Things
Bridge mqtt:awtrixlight:myAwtrix "Living Room Display" (mqtt:broker:myBroker) [ basetopic="awtrix", appLockTimeout=10, lowBatteryThreshold=25 ] {
Thing awtrixapp clock "Clock App" [ appname="clock", useButtons=true ]
Thing awtrixapp weather "Weather App" [ appname="weather" ]
Thing awtrixapp calendar "Calendar App" [ appname="calendar" ]
Thing awtrixapp custom "Custom App" [ appname="custom" ]
Items
// Bridge items (Living Room Display)
Group gAwtrix "Living Room Awtrix Display" <screen>
Dimmer Display_Brightness "Brightness [%d %%]" (gAwtrix) { channel="mqtt:awtrixlight:myAwtrix:brightness" }
Switch Display_Power "Power" (gAwtrix) { channel="mqtt:awtrixlight:myAwtrix:power" }
Switch Display_Screen "Screen" (gAwtrix) { channel="mqtt:awtrixlight:myAwtrix:display" }
Switch Display_Sound "Sound" (gAwtrix) { channel="mqtt:awtrixlight:myAwtrix:sound" }
Switch Display_AutoBrightness "Auto Brightness" (gAwtrix) { channel="mqtt:awtrixlight:myAwtrix:autoBrightness" }
Number:Temperature Display_Temperature "Temperature [%.1f °C]" (gAwtrix) { channel="mqtt:awtrixlight:myAwtrix:temperature" }
Number Display_Humidity "Humidity [%d %%]" (gAwtrix) { channel="mqtt:awtrixlight:myAwtrix:humidity" }
Number Display_Battery "Battery Level [%d %%]" (gAwtrix) { channel="mqtt:awtrixlight:myAwtrix:batteryLevel" }
Switch Display_LowBattery "Low Battery" (gAwtrix) { channel="mqtt:awtrixlight:myAwtrix:low-battery" }
Number Display_WiFi "WiFi Signal [%d %%]" (gAwtrix) { channel="mqtt:awtrixlight:myAwtrix:wifiSignal" }
String Display_CurrentApp "Active App [%s]" (gAwtrix) { channel="mqtt:awtrixlight:myAwtrix:app" }
// Clock App items
Switch Clock_Active "Clock Active" (gAwtrix) { channel="mqtt:awtrixlight:myAwtrix:clock:active" }
String Clock_Text "Clock Text" (gAwtrix) { channel="mqtt:awtrixlight:myAwtrix:clock:text" }
Color Clock_Color "Clock Color" (gAwtrix) { channel="mqtt:awtrixlight:myAwtrix:clock:color" }
Number Clock_Duration "Clock Duration" (gAwtrix) { channel="mqtt:awtrixlight:myAwtrix:clock:duration" }
// Weather App items
Switch Weather_Active "Weather Active" (gAwtrix) { channel="mqtt:awtrixlight:myAwtrix:weather:active" }
String Weather_Text "Weather Text" (gAwtrix) { channel="mqtt:awtrixlight:myAwtrix:weather:text" }
String Weather_Icon "Weather Icon" (gAwtrix) { channel="mqtt:awtrixlight:myAwtrix:weather:icon" }
Color Weather_Color "Weather Color" (gAwtrix) { channel="mqtt:awtrixlight:myAwtrix:weather:color" }
Switch Weather_Rainbow "Weather Rainbow Effect" (gAwtrix) { channel="mqtt:awtrixlight:myAwtrix:weather:rainbow" }
// Custom App items with advanced features
Switch Custom_Active "Custom App Active" (gAwtrix) { channel="mqtt:awtrixlight:myAwtrix:custom:active" }
String Custom_Text "Custom Text" (gAwtrix) { channel="mqtt:awtrixlight:myAwtrix:custom:text" }
String Custom_Icon "Custom Icon" (gAwtrix) { channel="mqtt:awtrixlight:myAwtrix:custom:icon" }
Color Custom_Color "Text Color" (gAwtrix) { channel="mqtt:awtrixlight:myAwtrix:custom:color" }
Color Custom_Background "Background Color" (gAwtrix) { channel="mqtt:awtrixlight:myAwtrix:custom:background" }
Number Custom_ScrollSpeed "Scroll Speed" (gAwtrix) { channel="mqtt:awtrixlight:myAwtrix:custom:scrollSpeed" }
Switch Custom_Center "Center Text" (gAwtrix) { channel="mqtt:awtrixlight:myAwtrix:custom:center" }
Number Custom_Progress "Progress [%d %%]" (gAwtrix) { channel="mqtt:awtrixlight:myAwtrix:custom:progress" }
Color Custom_ProgressColor "Progress Color" (gAwtrix) { channel="mqtt:awtrixlight:myAwtrix:custom:progressColor" }
Sitemap
sitemap awtrix label="Awtrix Display" {
Frame label="Display Control" {
Switch item=Display_Power
Slider item=Display_Brightness
Switch item=Display_Screen
Switch item=Display_Sound
Switch item=Display_AutoBrightness
Text item=Display_Temperature
Text item=Display_Humidity
Text item=Display_Battery visibility=[Display_LowBattery==ON]
Text item=Display_WiFi
Text item=Display_CurrentApp
Frame label="Clock App" {
Switch item=Clock_Active
Text item=Clock_Text
Colorpicker item=Clock_Color
Slider item=Clock_Duration
Frame label="Weather App" {
Switch item=Weather_Active
Text item=Weather_Text
Text item=Weather_Icon
Colorpicker item=Weather_Color
Switch item=Weather_Rainbow
Frame label="Custom App" {
Switch item=Custom_Active
Text item=Custom_Text
Text item=Custom_Icon
Colorpicker item=Custom_Color
Colorpicker item=Custom_Background
Slider item=Custom_ScrollSpeed
Switch item=Custom_Center
Slider item=Custom_Progress
Colorpicker item=Custom_ProgressColor
Rules
rule "Low Battery Warning"
Item Display_LowBattery changed to ON
// Send notification when battery is low
sendNotification("admin@email.com", "Awtrix Display battery is low: " + Display_Battery.state + "%")
rule "Weather Update"
Item Weather_Active changed to ON
// Update weather information when weather app becomes active
Weather_Text.sendCommand("22°C Partly Cloudy")
Weather_Icon.sendCommand("weather-partly-cloudy")
Weather_Color.sendCommand("0,0,255") // Blue color
Discovery
Actions
The binding provides various actions that can be used in rules to control the Awtrix display. To use these actions, you need to import them in your rules:
Indicator Control
Control the three indicator LEDs on the Awtrix display:
// Blink indicator 1 in red for 1 second
// Fade indicator 2 to blue over 2 seconds
actions.fadeIndicator(2, [0,0,255], 2000)
// Turn on indicator 3 in green
actions.activateIndicator(3, [0,255,0])
// Turn off indicator 1
actions.deactivateIndicator(1)
Device Control
Control basic device functions:
// Reboot the device
actions.reboot()
// Put device to sleep for 60 seconds
actions.sleep(60)
// Perform firmware upgrade
actions.upgrade()
Sound Control
Play sounds and melodies:
// Play a predefined sound file (without extension)
actions.playSound("notification")
// Play an RTTTL melody
actions.playRtttl("Indiana:d=4,o=5,b=250:e,8p,8f,8g,8p,1c6,8p.,d,8p,8e,1f,p.,g,8p,8a,8b,8p,1f6,p,a,8p,8b,2c6,2d6,2e6,e,8p,8f,8g,8p,1c6,p,d6,8p,8e6,1f.6,g,8p,8g,e.6,8p,d6,8p,8g,e.6,8p,d6,8p,8g,f.6,8p,e6,8p,8d6,2c6")
Notifications
Display notifications on the screen:
// Show simple notification with icon
actions.showNotification("Hello World", "alert")
// Show custom notification with advanced options
val params = newHashMap(
'text' -> 'Custom Message',
'icon' -> 'warning',
'color' -> [255,165,0], // Orange color
'rainbow' -> true,
'duration' -> 10
actions.showCustomNotification(
params, // Notification parameters
false, // hold: Keep notification until manually cleared
true, // wakeUp: Wake up from screen saver
true, // stack: Add to notification stack
"beep.rtttl", // RTTTL sound to play
"alert", // Sound file to play
false // loopSound: Loop the sound
Custom Notification Parameters
The showCustomNotification action accepts the following parameters in the params map:
| Parameter | Type | Description |
text |
String | The text to display |
textCase |
icon |
color |
int | RGB color array for text [r,g,b] |
background |
int | RGB color array for background [r,g,b] |
rainbow |
Boolean | Enable rainbow effect |
duration |
repeat |
Boolean | Repeat the notification |
scrollSpeed |
textOffset |
center |
Boolean | Center the text horizontally |
fade |
Boolean | Enable text fade effect |
progress |
Number | Show progress bar (0-100) |
progressColor |
int | RGB color array for progress bar [r,g,b] |
int | RGB color array for progress bar background [r,g,b] |
blinkText |
Boolean | Enable text blinking |
pushIcon |
The action method parameters:
hold |
Boolean | Keep notification until manually cleared |
wakeUp |
Boolean | Wake up from screen saver |
stack |
Boolean | Add to notification stack |
rtttl |
String | RTTTL melody to play |
sound |
String | Sound file to play (without extension) |
loopSound |
Boolean | Loop the sound |
Example Rules
Here are some example rules demonstrating the actions:
rule "Low Battery Warning with Indicator"
if (actions === null) {
logError("Awtrix Actions", "Actions not found")
return
// Blink red indicator
// Show notification
actions.showNotification("Battery Low!", "battery")
rule "Weather Alert"
Item Weather_Alert changed
return
'text' -> Weather_Alert.state.toString,
'icon' -> 'weather-storm',
'color' -> [255,255,0], // Yellow warning color
'duration' -> 30
// Show weather alert with sound
actions.showCustomNotification(params, false, true, true, "alert.rtttl", "warning", false)
// Activate warning indicator
actions.fadeIndicator(2, [255,165,0], 1000) // Orange indicator
A question to everyone who is using this binding for displaying notifications:
Currently you can only show notifications via thing actions. Either you go with the basic action that allows you to specify a text and icon or you can use the custom action that takes a map as parameter and in theory allows you to customise notifications just like you can do it with apps already (a couple of properties cannot be used on notifications like lifetime for example). This is however a bit complicated because the input map requires you to use the keys as they are used by the Awtrix 3 firmware. I just realised that while I was writing my documentation.
So the question is: how would you like to use notifications in general?
- Via Actions (feels natural to me but gets complicated with the many customisation options that should ideally be available)
- A new Notification thing (unless I add my own persistence layer the channels would not survive an OH reboot, it does feel a bit weird to create a thing for a notification or actually a type of notification that could be triggered via a specific channel)
- As a thing Action of an app thing itself: the notification could inherit all the settings of the app and could override a few selected properties. If you want a standalone notification you would need to create an app first though.
- Other ideas?
I use notification as channels in the main awtrix thing.
I set some different notifications and linked to an item.
so I only send value to the item and the notification is showed.
I can show my config if you want.
Greets
Yes please ![]()
I was about to write the same ![]()
I don’t really understand how you do it.
Ah sorry. It’s a mqtt thing.. ![]()
But it works fine for me.
UID: mqtt:topic:mqttbroker:Awtrix_clock
label: Awtrix clock mqtt
thingTypeUID: mqtt:topic
configuration: {}
bridgeUID: mqtt:broker:mqttbroker
channels:
- id: notify
channelTypeUID: mqtt:string
label: "notify "
description: ""
configuration:
formatBeforePublish: '{"text":"%s","icon":"555","topText":false,"effect":"Ripple","pushIcon":1,"repeat":2,"scrollSpeed":50}'
commandTopic: awtrix_clock/notify
postCommand: true
- id: notify_title
label: notify title
description: ""
configuration:
formatBeforePublish: '{"text":"%s","icon":"17668","color":"0,0,1","stack":false,"topText":true,"effect":"PlasmaCloud","pushIcon":1,"repeat":2,"scrollSpeed":75}'
postCommand: true
- id: settings
label: settings
description: ""
configuration:
formatBeforePublish: "%s"
commandTopic: awtrix_clock/settings
postCommand: true
- id: playSound
label: playSound
description: ""
configuration:
formatBeforePublish: '{"sound":"%s"}'
commandTopic: awtrix_clock/sound
postCommand: true
- id: vol_change
label: vol_change
description: ""
configuration:
formatBeforePublish: '{"text":"%s","icon":"56196","stack":false,"effect":"Ripple","pushIcon":1,"duration":1}'
postCommand: true
Ok yeah that should work as well and there’s nothing wrong about it. However I was of course trying to find a better solution for this binding.
Maybe I can just add a mapping into the action so that the channel names can be used instead of the awtrix firmware attributes…
I’m still using both a mqtt “generic” Thing and an awtrixclock Thing, but I have to admit, that’s because I’m veeery lazy ![]()
One thing, though, is the indicator. Why using a switch channel and lose the ability to change the color or other aspects of the indicator via channels? Of course one can use the actions - just found that option last week, nice.
I thought about that but this would require channels for indicator mode (static, blink, fade), the indicator colour and another one for the blink/fade interval. All of that times three for the three different indicators. I think it is much easier to use an action instead and therefore I offered only very basic indicator logic by the use of channels. I wouldn’t mind adding it though if it would be of use for you.
This binding will be part of the next OH 5.0 Milestone build.
Unfortunately the new version will not be compatible with the marketplace version as I had to change the thing IDs and also quite a few channel names. So if you want to switch to this new version it is necessary to recreate your things and channel links will definitely be broken after that.
On the other hand the official version will bring a few bug fixes, improved channel initialization logic and the notification action will now accept channel names as keys for the input map which will make it easier to create custom notifications. Moreover finally there is proper documentation for the binding.
That’s very appreciated, even when I have to recreate the Thing(s).
To be honest, this has happened to many other bindings as well and it’s no big deal after all.
The marketplace bindings are (according to my understanding) more mutative, so when it comes to the shift to an official binding, it’s to be expected that there are at least some breaking changes.
