Hello!
I’m setting up my new system (so far migrating things/items/rules) and i thought i’m on the right path, but when i tried to set up amanda i ran into this problem:
[16:49:57] openhabian@OHab2:~$ sudo su - backup
This account is currently not available.
i had another error popping up today (not being problematic for now)
i don’t know if this related:
[16:50:02] openhabian@OHab2:~$ sudo systemctl stop openhab2.service
Warning: The unit file, source configuration file or drop-ins of openhab2.service changed on disk. Run 'systemctl daemon-reload' to reload units.
(sudo) daemon-reload runs ok, but after reboot the error/problem appears again…
until now everything went great. the only error i made was this:
i enabled ZRAM via openhabian-config (while it was already enabled from the beginning… i’ve read @mstormi but i was somehow did NOT read it again and so i didn’t see the thirds line…)
today i figured out that ZRAM wasn’t working, so disabled and enabled it again via openhabian-config. ZRAM seems to work (at least now i don’t lose logs / persistence after reboot).
is any of this related?
Peter
edit: i was on 2.5.5-1 when i made this post. i upgraded to 2.5.6-2 - all problems remain though
i went for entry 34 Change passwords and chose “Amanda backup User account; “backup” to handle openHAB backups”, but i still can’t use the backup user (same “error” message as before). amanda is not installed yet, as i have no prepared everything… tried with terminal:
[18:10:22] openhabian@OHab2:~$ sudo passwd backup
Geben Sie ein neues Passwort ein:
Geben Sie das neue Passwort erneut ein:
passwd: Passwort erfolgreich geändert
[18:12:01] openhabian@OHab2:~$ sudo su - backup
Hi, I just ran into the same problem, but I am a bit confused now, because the documentation tells me to make sure the backup user can create/delete files BEFORE starting the Amanda installation. But if the user is created within the installation, how will I do that? Should I create the backup user myself manually then? Can do that, but would not want the installation to fail if I did that. Sorry if I missed something.
i understood it like this for example:
i have openhabian running on a raspberry and i wanted amanda to backup to my qnap-nas.
so i created the user backup (and also the root folder for the backups with permissions for the user backup) on my qnap to ensure amanda (installed on the raspberry) will be able to read/write files on the destination folder on my qnap.
Ahh this helped a lot. I did not read the docs with the remote perspective, but of course makes total sense! And has already prevented me from error, because I had created the “openhabian” user on the nfs share side to get access to the share, not “backup”. Thank you both!
I do not want to be nitpicky, but what tripped me in the docs was the section:
Blockquote Create a file there (touch /path/to/storage/file ), check its ownership (ls -l /path/to/storage/file ), then delete it (rm /path/to/storage/file ).
To do that, I would have to be the “backup” user on the local side as well, and since it is not created yet, the check cannot be done. Or can it?
