I installed a 60GB SSD with case on Raspberry Pi 3 Model B Rev 1.2.
I have SSD flash with openHABian image v1.4.1, after several attempts everything works.
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 57648464 2254292 53020316 5% /
devtmpfs 494908 0 494908 0% /dev
tmpfs 499516 0 499516 0% /dev/shm
tmpfs 499516 13060 486456 3% /run
tmpfs 5120 4 5116 1% /run/lock
tmpfs 499516 0 499516 0% /sys/fs/cgroup
/dev/sda1 42131 22829 19302 55% /boot
tmpfs 99900 0 99900 0% /run/user/1000
Now I wanted to set up an automatic daily Backup / Restore system, what do you recommend?
