Hi.
I am setting up a new rain sensor in my system. I’m planning to make rules that based on the rain readings populates Items for rain per hour (ie one value for each hour) and rain per day (one value per day). The intuitively correct way to graphically represent those Items would be with bar charts, but in MainUI I just find options for line charts. Is it something I’m missing or is there no way of doing bar charts?
Use the oh-chart
component for this, which was introduced with OH 3.1.0 M1 - it supports all type of charts (including bars).
Ah, that sounds like about what I need.
A stupid question though: Do I need to do any additional steps to get it working? I started with simply copy-pasting the first example from that thread, leaves me with nothing:
This is on 3.1M3.
Hey! Please note the syntax in first post in not correct anymore (only used that when doing the POC and was changed/updated when doing the PR) - the oh-serie
is not correct, please use:
- component: oh-time-series
Sorry for the confusion, will update my post and remove this to avoid any future confusion.
@crnjan Gave you the answer.
Here is one other example for a temp graph which you can switch between line and bar charts:
uid: lineChart_test
component: f7-card
slots:
default:
- component: oh-chart
periodVisible: false
options:
backgroundColor: transparent
slots:
grid:
- component: oh-chart-grid
top: 110
left: 55
right: 15
height: 160
title:
- component: oh-chart-title
left: center
text: Temperature
subtext: Some room
top: 10
tooltip:
- component: oh-chart-tooltip
trigger: axis
toolbox:
- component: oh-chart-toolbox
left: center
itemSize: 25
top: 60
feature:
dataView:
readOnly: false
dataZoom:
yAxisIndex: none
magicType:
type:
- line
- bar
restore: {}
saveAsImage: {}
xAxis:
- component: oh-time-axis
type: time
boundaryGap: false
gridIndex: 0
axisLabel:
show: true
yAxis:
- component: oh-value-axis
type: value
itemStyle:
color: rgb(255, 70, 131)
gridIndex: 0
splitLine: false
axisTick:
inside: true
axisLabel:
formatter: "{value} °C"
boundaryGap:
- 0
- 100%
series:
itemStyle:
color: rgb(255, 158, 68)
type: line
item: =props.item
Thanks! I’ve never done any own widgets before, so it feels like a threshold before I understand exactly how it works, but this feels like a starting point
