Barometer Gauge Widget [3.1.0.0;6.0.0.0)
A barometer with an optional LCD in a “classic” style. The unit for the primary scale can be set to hectopascal/millibars or inches of mercury. The secondary scale can be turned off or the unit set to hectopascal/millibars, inches of mercury, millimeters of mercury/torr, pascal or pounds per square inch. Most colors can be changed.
Screenshots
Changelog
Version 1.0
  • initial release
Resources
uid: barometer_gauge
tags:
  - barometer
  - gauge
  - pressure
props:
  parameters:
    - description: The title text
      label: Title
      required: false
      type: TEXT
    - context: item
      description: The barometric pressure Item
      label: Barometric Pressure Item
      required: true
      type: TEXT
    - default: mbar
      label: Primary Scale Unit
      required: false
      type: TEXT
      limitToOptions: true
      options:
        - label: inHg
          value: inhg
        - label: mbar/hPa
          value: mbar
    - default: none
      label: Secondary Scale Unit
      required: false
      type: TEXT
      options:
        - label: None
          value: none
        - label: inHg
          value: inhg
        - label: mbar/hPa
          value: mbar
        - label: mmHg/Torr
          value: mmhg
        - label: Pa
          value: pascal
        - label: psi
          value: psi
    - default: false
      label: Enable LCD
      description: Enable the LCD
      type: BOOLEAN
    - default: "#e64a19"
      description: The needle color
      label: Needle Color
      required: false
      type: TEXT
    - default: "#ddd"
      description: The gauge frame color
      label: Frame Color
      required: false
      type: TEXT
    - default: transparent
      description: The dial color
      label: Dial Color
      required: false
      type: TEXT
    - default: "#464646"
      description: The dial print color
      label: Print Color
      required: false
      type: TEXT
      description: The shadow color, e.g. "black" or "#0008"
      label: Shadow Color
      required: false
      type: TEXT
      advanced: true
    - default: "10"
      description: The blur value for the dial shadow (no effect if the dial is transparent)
      label: Shadow Blur
      required: false
      type: INTEGER
      advanced: true
    - default: "3"
      description: The offset value for the dial shadow (no effect if the dial is
        transparent)
      label: Shadow Offset
      required: false
      type: INTEGER
      advanced: true
    - default: 10
      description: The primary axis font size
      label: Primary Scale Font Size
      required: false
      type: INTEGER
      min: 6
      max: 50
      advanced: true
    - default: 10
      description: The secondary axis font size
      label: Secondary Scale Font Size
      required: false
      type: INTEGER
      min: 6
      max: 50
      advanced: true
    - description: The height of widget
      label: Height
      required: false
      type: TEXT
  parameterGroups: []
timestamp: Dec 31, 2024, 1:52:53 AM
component: oh-chart
  height: =props.height
slots:
  series:
    - component: oh-data-series
        emptyCircleStyle:
          color: =props.dialColor
          shadowBlur: =props.shadowBlur
          shadowColor: =props.shadowColor
          shadowOffsetX: =props.shadowOffset
          shadowOffsetY: =props.shadowOffset
        radius: 85%
        type: pie
        anchor:
          itemStyle:
            color: "#000"
          show: true
        axisLabel:
          show: false
        axisLine:
          lineStyle:
            color:
              - - 1
                - =props.frameColor
            shadowBlur: 6
            shadowColor: "#0008"
            width: 6
        axisTick:
          show: false
        detail:
          show: false
        endAngle: -270
        pointer:
          show: false
        radius: 85%
        splitLine:
          show: false
        startAngle: 90
        title:
          show: false
        type: gauge
        anchor:
          icon: path://M 21.5,90 C 21.2,90 20.8,89.9 20.5,89.8 19.2,89.2 18.7,87.8
            19.2,86.5 L 22.7,78.5 C 23.3,77.2 24.7,76.7 26,77.2 27.3,77.8
            27.8,79.2 27.3,80.5 L 23.8,88.5 C 23.4,89.5 22.5,90 21.5,90 Z M
            35.5,99 C 35.2,99 34.8,98.9 34.5,98.8 33.2,98.2 32.7,96.8 33.2,95.5
            L 36.7,87.5 C 37.3,86.2 38.7,85.7 40,86.2 41.3,86.8 41.8,88.2
            41.3,89.5 L 37.8,97.5 C 37.4,98.5 36.5,99 35.5,99 Z M 77.5,99 C
            77.2,99 76.8,98.9 76.5,98.8 75.2,98.2 74.7,96.8 75.2,95.5 L
            78.7,87.5 C 79.3,86.2 80.7,85.7 82,86.2 83.3,86.8 83.8,88.2
            83.3,89.5 L 79.8,97.5 C 79.4,98.5 78.5,99 77.5,99 Z M 63.5,90 C
            63.2,90 62.8,89.9 62.5,89.8 61.2,89.2 60.7,87.8 61.2,86.5 L
            64.7,78.5 C 65.3,77.2 66.7,76.7 68,77.2 69.3,77.8 69.8,79.2
            69.3,80.5 L 65.8,88.5 C 65.4,89.5 64.5,90 63.5,90 Z M 50.5,90 C
            50.2,90 49.8,89.9 49.5,89.8 48.2,89.2 47.7,87.8 48.2,86.5 L
            51.7,78.5 C 52.3,77.2 53.7,76.7 55,77.2 56.3,77.8 56.8,79.2
            56.3,80.5 L 52.8,88.5 C 52.4,89.5 51.5,90 50.5,90 Z M 57.699219,21.5
            C 48.440743,21.5 40.147523,26.568909 35.720703,34.470703
            34.740953,34.203051 33.756475,33.900391 32.800781,33.900391
            28.420493,33.900391 24.647047,36.370936 22.773437,40.054687
            22.48915,40.04404 22.169674,40 21.900391,40 17.410147,40
            13.200641,41.769453 10.121094,44.958984 7.1678467,48.021611
            5.5,52.004482 5.5,56.199219 V 56.417969 56.4375 C
            5.6087751,60.897281 7.374687,65.00355 10.5625,67.980469
            13.548648,70.954812 17.626182,72.599609 21.900391,72.599609 H
            77.599609 C 86.309736,72.599609 93.5,65.523566 93.5,56.800781
            93.5,49.861444 88.932957,43.93227 82.568359,41.845703
            80.209008,30.230901 69.847554,21.5 57.699219,21.5 Z M 57.699219,24.5
            C 68.664176,24.5 78.042381,32.574423 79.820312,43.148437 L
            79.982422,44.109375 80.925781,44.351562 C 86.461212,45.780061
            90.5,50.882599 90.5,56.800781 90.5,63.877996 84.689483,69.599609
            77.599609,69.599609 H 21.900391 C 18.385006,69.599609
            15.072076,68.251763 12.660156,65.839844 L 12.642578,65.820312
            12.623047,65.802734 C 10.021865,63.380944 8.5910267,60.095376
            8.5,56.363281 V 56.199219 C 8.5,52.793956 9.832544,49.578389
            12.279297,47.041016 14.799749,44.430547 18.190635,43 21.900391,43
            22.500391,43 22.886812,43.002294 23.353516,43.080078 L
            24.568359,43.28125 25.001953,42.130859 C 26.179894,39.017729
            29.196019,36.900391 32.800781,36.900391 33.834115,36.900391
            34.818897,37.066305 35.822266,37.484375 L 37.115234,38.023437
            37.742187,36.771484 C 41.489512,29.276836 49.159658,24.5
            57.699219,24.5 Z
          itemStyle:
            color: =props.printColor
          keepAspect: true
          offsetCenter:
            - -28%
            - -28%
          show: true
        axisLabel:
          show: false
        axisLine:
          show: false
        axisTick:
          show: false
        detail:
          show: false
        pointer:
          show: false
        progress:
          show: false
        radius: 85%
        splitLine:
          show: false
        title:
          show: false
        type: gauge
        anchor:
          icon: path://M 30.564453,16.353516 C 28.102313,16.408856 25.618034,17.058891
            23.333984,18.353516 L 23.328125,18.355469 23.324219,18.357422 C
            16.068289,22.567336 13.565629,31.965502 17.712891,39.226562 L
            17.714844,39.228516 17.716797,39.232422 C 18.367853,40.35585
            19.142015,41.365905 20.013672,42.255859 L 21.443359,40.857422 C
            20.688631,40.086851 20.017526,39.210444 19.451172,38.234375 V
            38.232422 C 19.450231,38.2308 19.448206,38.230138
            19.447266,38.228516 15.845167,31.914163 18.018962,23.748488
            24.328125,20.087891 26.31788,18.962151 28.472761,18.401583
            30.611328,18.353516 35.322022,18.247634 39.938438,20.627616
            42.457031,24.96875 42.887844,25.730189 43.237477,26.518041
            43.507812,27.322266 L 45.402344,26.685547 C 45.092284,25.763149
            44.694344,24.856113 44.197266,23.978516 L 44.193359,23.972656
            44.191406,23.96875 C 41.299927,18.980089 35.980963,16.231769
            30.564453,16.353516 Z M 57.699219,21.5 C 48.440743,21.5
            40.147523,26.568909 35.720703,34.470703 34.740953,34.203051
            33.756475,33.900391 32.800781,33.900391 28.420493,33.900391
            24.647047,36.370936 22.773437,40.054687 22.48915,40.04404
            22.169674,40 21.900391,40 17.410147,40 13.200641,41.769453
            10.121094,44.958984 7.1678467,48.021611 5.5,52.004482 5.5,56.199219
            V 56.417969 56.4375 C 5.6087751,60.897281 7.374687,65.00355
            10.5625,67.980469 13.548648,70.954812 17.626182,72.599609
            21.900391,72.599609 H 77.599609 C 86.309736,72.599609 93.5,65.523566
            93.5,56.800781 93.5,49.861444 88.932957,43.93227 82.568359,41.845703
            57.699219,24.5 Z M 17.489095,19.874083 C 16.978594,19.874083
            16.467895,19.679339 16.078407,19.289652 L 11.491641,14.70315 C
            10.712533,13.923976 10.712533,12.661017 11.491641,11.881842
            12.270815,11.102734 13.534039,11.10247 14.312949,11.881842 L
            18.899715,16.468344 C 19.678824,17.247519 19.678824,18.510478
            18.899715,19.289652 18.510294,19.679339 17.999793,19.874083
            17.489095,19.874083 Z M 44.548391,19.874083 C 44.037957,19.874083
            43.527192,19.679339 43.13777,19.289652 42.358664,18.510478
            42.358664,17.247254 43.13777,16.468344 L 47.724537,11.881842 C
            48.503711,11.102734 49.766935,11.10247 50.545845,11.881842
            51.324954,12.661017 51.324954,13.924241 50.545845,14.70315 L
            45.959078,19.289652 C 45.56959,19.679339 45.058892,19.874083
            44.548391,19.874083 Z M 11.885096,33.403732 H 5.3985013 C
            4.2966931,33.403732 3.403443,32.510489 3.403443,31.408681
            3.403443,30.306873 4.2966931,29.413629 5.3985013,29.413629 H
            11.885096 C 12.986904,29.413629 13.880148,30.306873
            13.880148,31.408681 13.880148,32.510489 12.986904,33.403732
            11.885096,33.403732 Z M 31.018744,14.270085 C 29.916936,14.270085
            29.023692,13.376841 29.023692,12.275033 V 5.7884384 C
            29.023692,4.6866301 29.916936,3.79338 31.018744,3.79338
            32.120552,3.79338 33.013795,4.6866301 33.013795,5.7884384 V
            12.275033 C 33.013795,13.376841 32.120552,14.270085
            31.018744,14.270085 Z
          itemStyle:
          keepAspect: true
          offsetCenter:
            - 0%
            - -43%
          show: true
        axisLabel:
          show: false
        axisLine:
          show: false
        axisTick:
          show: false
        detail:
          show: false
        pointer:
          show: false
        progress:
          show: false
        radius: 85%
        splitLine:
          show: false
        title:
          show: false
        type: gauge
        anchor:
          icon: path://M 29.5399,32.5569 C 28.7679,32.5569 27.9956,32.2624 27.4066,31.6731
            L 20.4703,24.7372 C 19.2921,23.5589 19.2921,21.649 20.4703,20.4707
            21.6486,19.2925 23.5589,19.2921 24.7368,20.4707 L 31.6731,27.4066 C
            32.8513,28.5849 32.8513,30.4948 31.6731,31.6731 31.0842,32.2624
            30.3122,32.5569 29.5399,32.5569 Z M 77.396,80.4134 C 76.6241,80.4134
            75.8517,80.119 75.2628,79.5297 L 68.3265,72.5934 C 67.1483,71.4151
            67.1483,69.5048 68.3265,68.3269 69.5048,67.1487 71.4151,67.1487
            72.593,68.3269 L 79.5293,75.2632 C 80.7075,76.4415 80.7075,78.3518
            79.5293,79.5297 78.9403,80.119 78.1684,80.4134 77.396,80.4134 Z M
            22.6036,80.4134 C 21.8316,80.4134 21.0593,80.119 20.4703,79.5297
            19.2921,78.3514 19.2921,76.4411 20.4703,75.2632 L 27.4066,68.3269 C
            28.5849,67.1487 30.4952,67.1487 31.6731,68.3269 32.8513,69.5052
            32.8513,71.4155 31.6731,72.5934 L 24.7368,79.5297 C 24.1479,80.119
            23.3759,80.4134 22.6036,80.4134 Z M 70.4601,32.5569 C
            69.6882,32.5569 68.9158,32.2624 68.3269,31.6731 67.1487,30.4948
            67.1487,28.5845 68.3269,27.4066 L 75.2632,20.4707 C 76.4415,19.2925
            78.3518,19.2921 79.5297,20.4707 80.7079,21.649 80.7079,23.5593
            79.5297,24.7372 L 72.5934,31.6731 C 72.0044,32.2624 71.2321,32.5569
            70.4601,32.5569 Z M 21.0653,53.017 H 11.256 C 9.5898,53.017
            8.23899,51.6662 8.23899,50 8.23899,48.3338 9.5898,46.983
            11.256,46.983 H 21.0653 C 22.7315,46.983 24.0823,48.3338 24.0823,50
            24.0823,51.6662 22.7315,53.017 21.0653,53.017 Z M 88.744,53.017 H
            78.9347 C 77.2685,53.017 75.9177,51.6662 75.9177,50 75.9177,48.3338
            77.2685,46.983 78.9347,46.983 H 88.744 C 90.4102,46.983
            91.761,48.3338 91.761,50 91.761,51.6662 90.4106,53.017 88.744,53.017
            Z M 50,91.761 C 48.3338,91.761 46.983,90.4102 46.983,88.744 V
            78.9347 C 46.983,77.2685 48.3338,75.9177 50,75.9177 51.6662,75.9177
            53.017,77.2685 53.017,78.9347 V 88.744 C 53.017,90.4106
            51.6662,91.761 50,91.761 Z M 50,24.0823 C 48.3338,24.0823
            46.983,22.7315 46.983,21.0653 V 11.256 C 46.983,9.5898
            48.3338,8.23899 50,8.23899 51.6662,8.23899 53.017,9.5898
            53.017,11.256 V 21.0653 C 53.017,22.7315 51.6662,24.0823 50,24.0823
            Z M 50,28.207031 C 37.99721,28.207031 28.207031,37.99721
            28.207031,50 28.207031,62.00279 37.99721,71.792969 50,71.792969
            62.00279,71.792969 71.792969,62.00279 71.792969,50
            71.792969,37.99721 62.00279,28.207031 50,28.207031 Z M 50,31.207031
            C 60.37564,31.207031 68.792969,39.62436 68.792969,50
            68.792969,60.37564 60.37564,68.792969 50,68.792969
            39.62436,68.792969 31.207031,60.37564 31.207031,50
            31.207031,39.62436 39.62436,31.207031 50,31.207031 Z
          itemStyle:
          keepAspect: true
          offsetCenter:
            - 28%
            - -28%
          show: true
        axisLabel:
          show: false
        axisLine:
          show: false
        axisTick:
          show: false
        detail:
          show: false
        pointer:
          show: false
        progress:
          show: false
        radius: 85%
        splitLine:
          show: false
        title:
          show: false
        type: gauge
        anchor:
          show: =props.primary=="mbar"?true:false
          itemStyle:
            color: =props.needleColor
            shadowBlur: 0
          showAbove: true
        axisLabel:
          distance: -6
          fontSize: =props.primaryFontSize
          fontWeight: 100
          rotate: tangential
        axisLine:
          lineStyle:
            color:
              - - 1
                - =props.printColor
            width: 1
        max: 1070
        min: 950
        splitNumber: 12
        radius: 60%
        axisTick:
          splitNumber: 5
          distance: 0
          length: -7%
          lineStyle:
        splitLine:
          distance: 0
          length: -7%
          lineStyle:
            width: 2
        data:
          - itemStyle:
            value: =Number.parseFloat(items[props.item].state)
        detail:
          backgroundColor: rgb(137,150,96)
          borderColor: "#000"
          borderWidth: 1
          color: "#000"
          fontFamily: Courier New
          fontSize: 1em
          fontWeight: 600
          height: 25%
          width: 94%
          formatter: "=v=>v.toFixed(props.primary=='inhg'?2:0)+(items[props.item].state.split(' ').length > 1 ? ' '+(items[props.item].state.split(' ')[1]=='hPa'?'mbar':items[props.item].state.split(' ')[1]) : '')"
          offsetCenter:
            - 0
            - 95%
          padding:
            - 1
            - 2
            - 0
            - 2
          show: =props.enableLCD?true:false
          valueAnimation: true
        pointer:
          icon: path://M 50 15 C 49.913974 15 49.800781 15.164063 49.800781 15.164062 L 49.734375 27.259766 C 49.577351 27.78691 49.375239 28.417768 49.199219 28.822266 C 48.818399 29.697395 47.800781 31.320312 47.800781 31.320312 C 47.800781 31.320313 48.684895 30.64024 49.716797 30.527344 L 49.5 70.138672 C 48.058396 70.382346 47.002396 71.629746 47 73.091797 C 47.002792 73.747385 47.220261 74.384011 47.619141 74.904297 C 47.575406 74.72325 47.552471 74.537807 47.550781 74.351562 C 47.550794 72.999197 48.647216 71.902775 50 71.902344 C 51.352784 71.902775 52.449206 72.999197 52.449219 74.351562 C 52.447529 74.537807 52.424594 74.72325 52.380859 74.904297 C 52.779739 74.384011 52.997208 73.747385 53 73.091797 C 52.999508 71.628269 51.943058 70.378687 50.5 70.134766 L 50.283203 30.525391 C 51.314589 30.615983 52.199219 31.158203 52.199219 31.158203 C 52.199219 31.158203 51.182411 29.591289 50.800781 28.742188 C 50.625205 28.351542 50.422793 27.740799 50.265625 27.230469 L 50.199219 15.164062 C 50.199219 15.164062 50.086026 15 50 15 z
          itemStyle:
            shadowBlur: 2
            shadowColor: "#000a"
            shadowOffsetX: 2
            shadowOffsetY: 2
          keepAspect: true
          length: 150%
          width: 15%
          offsetCenter:
            - 0
            - 53%
        title:
          offsetCenter:
            - 0
            - 35%
        tooltip:
          formatter: "=p=>'<b>'+p.value.toFixed(1)+(items[props.item].state.split(' ').length > 1 ? ' '+items[props.item].state.split(' ')[1] : '')+'</b>'"
        type: gauge
        anchor:
          show: =props.primary=="inhg"?true:false
          itemStyle:
            shadowBlur: 0
          showAbove: true
        axisLabel:
          distance: -6
          fontWeight: 100
          rotate: tangential
        axisLine:
          lineStyle:
            color:
              - - 1
                - =props.printColor
            width: 1
        max: 31.5
        min: 28
        startAngle: 229.0725
        endAngle: -37.5975
        splitNumber: 7
        radius: 60%
        axisTick:
          distance: 0
          splitNumber: 5
          length: -7%
          lineStyle:
        splitLine:
          distance: 0
          length: -7%
          lineStyle:
            width: 2
        data:
          - itemStyle:
        detail:
          show: false
        pointer:
          itemStyle:
            shadowBlur: 2
            shadowOffsetX: 2
            shadowOffsetY: 2
          keepAspect: true
          length: 150%
          width: 15%
          offsetCenter:
            - 0
            - 53%
        title:
          offsetCenter:
            - 0
            - 35%
        tooltip:
          formatter: "=p=>'<b>'+p.value.toFixed(3)+(items[props.item].state.split(' ').length > 1 ? ' '+items[props.item].state.split(' ')[1] : '')+'</b>'"
        type: gauge
        anchor:
          show: false;
        axisLabel:
          show: =props.secondary=="mbar"?true:false
          distance: 10
          fontSize: =props.secondaryFontSize
          fontWeight: 100
          rotate: tangential
        axisLine:
          lineStyle:
            color:
              - - 1
                - =props.printColor
            width: 1
        max: 1070
        min: 950
        startAngle: 225
        endAngle: -45
        splitNumber: 12
        radius: 57%
        axisTick:
          splitNumber: 5
          distance: 0
          length: 7%
          lineStyle:
        splitLine:
          distance: 0
          length: 7%
          lineStyle:
            width: 2
        detail:
          show: false
        pointer:
          show: false
        title:
          show: false
        type: gauge
        anchor:
          show: false;
        axisLabel:
          show: =props.secondary=="pascal"?true:false
          distance: 10
          fontSize: =props.secondaryFontSize-2
          fontWeight: 100
          rotate: tangential
        axisLine:
          lineStyle:
            color:
              - - 1
                - =props.printColor
            width: 1
        max: 107000
        min: 95000
        startAngle: 225
        endAngle: -45
        splitNumber: 12
        radius: 57%
        axisTick:
          splitNumber: 5
          distance: 0
          length: 7%
          lineStyle:
        splitLine:
          distance: 0
          length: 7%
          lineStyle:
            width: 2
        detail:
          show: false
        pointer:
          show: false
        title:
          show: false
        type: gauge
        anchor:
          show: false;
        axisLabel:
          show: =props.secondary=="inhg"?true:false
          distance: 10
          fontWeight: 100
          rotate: tangential
        axisLine:
          lineStyle:
            color:
              - - 1
                - =props.printColor
            width: 1
        max: 31.5
        min: 28
        endAngle: -37.5975
        splitNumber: 7
        radius: 57%
        axisTick:
          distance: 0
          length: 7%
          splitNumber: 5
          lineStyle:
        splitLine:
          distance: 0
          length: 7%
          lineStyle:
            width: 2
        detail:
          show: false
        pointer:
          show: false
        title:
          show: false
        type: gauge
        anchor:
          show: false;
        axisLabel:
          show: =props.secondary=="psi"?true:false
          distance: 10
          fontWeight: 100
          rotate: tangential
        axisLine:
          lineStyle:
            color:
              - - 1
                - =props.printColor
            width: 1
        max: 15.5
        min: 13.8
        startAngle: 221.67
        endAngle: -42.0525
        splitNumber: 8.5
        radius: 57%
        axisTick:
          splitNumber: 4
          distance: 0
          length: 7%
          lineStyle:
        splitLine:
          distance: 0
          length: 7%
          lineStyle:
            width: 2
        detail:
          show: false
        pointer:
          show: false
        title:
          show: false
        type: gauge
        anchor:
          show: false;
        axisLabel:
          show: =props.secondary=="mmhg"?true:false
          distance: 10
          fontWeight: 100
          rotate: tangential
        axisLine:
          lineStyle:
            color:
              - - 1
                - =props.printColor
            width: 1
        max: 800
        min: 710
        startAngle: 232.6725
        endAngle: -37.305
        splitNumber: 9
        radius: 57%
        axisTick:
          splitNumber: 5
          distance: 0
          length: 7%
          lineStyle:
        splitLine:
          distance: 0
          length: 7%
          lineStyle:
            width: 2
        detail:
          show: false
        pointer:
          show: false
        title:
          show: false
        type: gauge
  tooltip:
    - component: oh-chart-tooltip
        show: true
Thank you very much @Nadahar for your barometer widget.
I had to adjust the displayed range 880 … 1080 mbar (10 splits) because I had 899 mbar today
I checked various things before deciding on the range, one of which was:
https://learn.weatherstem.com/modules/learn/lessons/125/18.html
I also looked at many “real world” barometers. I know that conditions do exist that is outside of the range, but there were other factors to consider like readability (if you use both scales, the inner scale can be difficult to read) and the distance between the “symbols”. When you extend the range of the scale, you should ideally also move the symbols closer together.
But if you only use one scale and this works for you, that’s fine. But, you should know that 899 mbar is pretty severe weather, so I must say that I wonder if you have calibrated your sensor correctly.
Barometers always reference the atmospheric pressure at sea level, so if you live higher up, you need to compensate for this. Failing to do that would give too low readings.
Thank you for the education on barometers :slightly_smiling_face:
I’ll check how to calibrate my barometer sensor.
I found the following note:
If the altitude of the deployment site is known precisely, the correction value can also be calculated. The calculation is based on the assumption that air pressure decreases by 1 hPa for every 8 m of elevation difference.
I live at 840m above sea level which is a difference of 105 hPa.
105 hPa = 105 mbar, which makes your value much more “within normal range”, so that makes a lot of sense.
If there’s no way to “calibrate”/add an offset to your sensor, maybe you can use a OH profile to do the same.
I‘m using your widget @Nadahar in my three OH systems on a PI5. A couple of weeks ago
under OH 4.3.6 everything was fine.
When open then page, each widget was one time initialised and everything was good.
Now, after update to OH 5.0.0 the widget gets initialised, and after 10-30 sec the single widget get a new initialised. The most initialised is getting the garden widget left button.
Any idea why this now happens under OH 5.0.0?
IMG_0093
IMG_0094
No. When you say “initialized”, I assume that you mean that the start animation (where the dials go from zero) is run? As far as I know, this depends on the browser, not changes from OH. So, it’s strange if 5.0 has changed this.
But there could have been changes I’m not aware of. Maybe the echarts library that these widgets use has been updated for example, and that there’s a new bug in the new update?
@florian-h05 Do you have any idea if something has been updated that could affect this?
Yes, with initialized mean the animation where the dials go from zero.
This happens as you know only once. Now this happens 5-15 sec… I made a video to show you. Upper window is Firefox, bottom windows is edge browser.
I think I know now, were ist coming from.
When the temperatur or the humidiy changes in 0,x degrees e.g. the widget will be new initialized.
I have not seen this under OH 4.3.6.
The other stay still, because those are normal Shelly HT or Shelly HT +, which get a refresh every 10min…
That sounds like a bug somewhere, but I can’t quite understand that the widget can do anything about it…
Same problem here after update to OH 5.0. Several gauge displays (colorband) periodically initializing, looks very unsteady.
@florian-h05 Any idea what might have caused this? The widgets themselves don’t control the animations, they are based un state updates from Items. Has anything changed there, or any changes to the dependencies, echarts lib. etc?
I’ve found what’s causing this:
https://github.com/openhab/openhab-webui/commit/299f300dbf719d53cdfc40a09f2a9357ca5d6514
I haven’t figured out how to fix it though, except establishing that it start working if I remove:
      :init-options="{
        locale: ECHARTS_LOCALE
Could it be that there are other “init-options” that have defaults assigned if no object is provided, but that are “undefined” as soon as an object is provided?
Another option is that it’s caused by the locale being invalid. In my case, the locale doesn’t exist (probably isn’t implemented by echarts).
I’ve created a PR that, if merged, should fix the animation issue:
https://github.com/openhab/openhab-webui/pull/3321
The animations will remain bugged until the next release after the fix has been merged, but the problem isn’t with the widget, so there’s nothing that can be done with the widget to fix it.
Sorry for not answering, I wanted to check but did not find the time or forgot about it. As I can see you found the cause, will try to review your fix soon.
Just updated my systems to OH 5.0.1-1 and it seems, that the issue is gone with the startup from zero the Barometer, everytime and new value jumps in…
Thanks to the guys and the fixing of the issue….
Thanks for confirming.
It is necessary to enable the option to select alternative units of measurement for the primary scale—specifically, mmHg.
There’s been a while since I made this, so I don’t remember the exact reason for the choices I made - but there are “layout concerns” to take into account here, that might be the reason why I didn’t include everything on the primary.
Why can’t you just pick something else for the primary and set the secondary to mmHg?
Otherwise, somebody will have to figure out how this works again and make sure that it works. I just don’t remember the details at this point.
Hi Ravi, do you already have or plan a temperature/humidity widget? Have currently no marketplace access to check for.
Edit: found it, sorry for asking.
