Bash script to search and find rules quickly
searching for where existing rules/scenes/scripts etc are used in openHAB’s UI is very annoying
not very fancy but working I wrote a little bash script to search where rules/scenes/scripts are used in the UI of openHAB (in my case I want to know whether a specified scene/rule is used in other automations, inline scripts or in pages)
basically the script searches your jsondb files(automation_rules.js, uicomponents_ui_pages.json and uicomponents_ui_widget.json) with “jq” (commandline JSON processor)
sudo apt update && sudo apt install jq
just run the script with or without parameter to search for “myRule_or_whatever” and see where it’s used in your UI
please excuse my horrible English :wink:
#!/usr/bin/bash
dsh='-----'
[ -z "$1" ] && read -p "search: " s || s="$1"
echo "searching for: '$s'"
f=/var/lib/openhab/jsondb/automation_rules.json
p=/var/lib/openhab/jsondb/uicomponents_ui_page.json
w=/var/lib/openhab/jsondb/uicomponents_ui_widget.json
echo $dsh
echo "results in Rules:"
output=$(echo '{"daten": []}' | jq -r --arg s "$s" 'to_entries[] | select( [.. | strings | select(ascii_downcase | contains($s | ascii_downcase))] | any ) | "Regel-UID: \(.key) | Name: \(.value.value.name)"' $f)
if [[ -z "$output" ]]; then
  output=" - no results"
fi
echo "$output"
echo $dsh
echo "results in Pages"
output=$(echo '{"daten": []}' | jq -r --arg s "$s" 'to_entries[] | select( [.. | strings | select(ascii_downcase | contains($s | ascii_downcase))] | any ) | "Page-UID: \(.key) | Name: \(.value.value.name)"' $p)
fi
echo "$output"
echo $dsh
echo "results in widgets"
output=$(echo '{"daten": []}' | jq -r --arg s "$s" 'to_entries[] | select( [.. | strings | select(ascii_downcase | contains($s | ascii_downcase))] | any ) | "Widget-UID: \(.key) | Name: \(.value.value.name)"' $w)
fi
echo "$output"
echo $dsh
just place the script in your home directory, name it “searchoh.sh” or whatever you prefer
remember to make it executable :wink:
you can run the script with a parameter (ex: ./searchoh.sh myRule_or_whatever) or without parameter. If no parameter is provided the script asks for by using “read”
the output looks like:
searchoh myRule_or_whatever
searching for: 'myRule_or_whatever'
results in Rules:
Regel-UID: UID_of_myRule_or_whatever | Name: myRule_or_whatever
Regel-UID: c5292abf86 | Name: Rule_which_is_using_myRule_or_whatever
results in Pages
Page-UID: Page_which_is_using_myRule_or_whatever | Name: null
results in widgets
 - no results
Thanks for posting this.
There has been a lot of work in recent versions to improve the search in MainUI. What version are you using?
Using the search box in the developer tools already supplies all of these answers:
This rule is referenced in the metadata of some items and search even finds that:
Can you elaborate on what you find annoying with the UI search, I’m sure the devs would appreciate the feedback and like the chance to further improve it.
I am unfamiliar with the issue you are referencing and (ironically) a quick github search does not result in anything useful. Can you post a link to the issue to help this thread not rehash old issues?
thanks for your answer.
I’m on 5.2.1
you’re right. the UI’s search functionality is very powerful. In my case I couldn’t find a specific rule used in another rule (not inline script). The above mentioned approach does :wink:
And no, I am not going to go through every single item again, list all the findings, and repeat discussions that have already taken place.
Closing means accepting :slightly_smiling_face:
thanks for commenting. The above solution is just a suggestion. If you don’t like it or don’t want to use it. It’s on you. If it’s an old or known topic. SORRY. Maybe other users appreciate my suggestion.
Interesting. I guess I’ve never tried to search for a rule referenced in actions and not inline scripts, but you’re right. Even in my recent snapshot, that search condition does not work.
There was a similar issue a while back where item names in rule triggers did not show up in the MainUI search. I think that got resolved, so, it might be worth filing an issue about this specific use-case as well.
Hey, thanks for the great Bash script! Now I can use it instead of my own, and it’s actually working much better. :grinning_face_with_smiling_eyes:
As someone already mentioned before (although I can’t seem to find the original post anymore), there was an ongoing discussion on GitHub about several issues. However, it was never followed up on and the discussion was simply closed. That’s why I assumed the points had already been addressed and implemented.
Unfortunately, it seems that’s not the case after all. :sweat_smile:
I can. I have not found a way to open the developer sidebar on mobile yet and that is the main platform I use to manage my OH installation.
That’s an interesting point. Administration on mobile has always been less of a priority and the dev sidebar issue is an old limitation with the configuration of the f7 panels in general. The left panel overrides the central space so that still works on smaller screens, but the dev panel shares the space and f7 allows you set a screen width cutoff where that just can’t happen. You see the same effect on the desktop if you just change the size of the browser window. With the dev sidebar open if you start to make the window narrower there will be a point where the dev panel just disappears.
I’d say this is another good viewpoint that is worth a mention as a bug or maybe better a feature request. Shunting some of the dev sidebar features to the Dev Tools menu on smaller screens is quite reasonable.
small update. Now you can search for any expression you like in rules ,pages, widget , items, metadata, channels
#!/usr/bin/bash
clear
dsh='-----'
typeHint='
rules    = r
pages    = p
widget   = w
items    = i
metadata = m
channels = c
all      = return or empty
searchHint="
startsWith $s = s
contains   $s = c (return or empty)
declare -A searchTypeString
searchTypeString["s"]="startsWith"
searchTypeString["c"]="contains"
[ -z "$1" ] && read -p "${dsh}search: " s || s="$1"
[ -z "$2" ] && read -p "${dsh}which type ?${typeHint}" tp || tp="$2"
[[ "$tp" == "a" ]] && tp=""
[ -z "$3" ] && read -p "${dsh}which search type ?${searchHint}" searchType || searchType="$3"
[[ -z "$searchType" ]] && searchType="c"
echo "searching for: ${searchTypeString[$searchType]}('$s')"
declare -A f
declare -A t
if [[ -z "$tp" || "$tp" == "r" ]]; then f[0]="$p/automation_rules.json"; t[0]="RULES"; fi
if [[ -z "$tp" || "$tp" == "p" ]]; then f[1]="$p/uicomponents_ui_page.json"; t[1]="PAGES"; fi
if [[ -z "$tp" || "$tp" == "w" ]]; then f[2]="$p/uicomponents_ui_widget.json"; t[2]="WIDGETS"; fi
if [[ -z "$tp" || "$tp" == "i" ]]; then f[3]="$p/org.openhab.core.items.Item.json"; t[3]="ITEMS"; fi
if [[ -z "$tp" || "$tp" == "m" ]]; then f[4]="$p/org.openhab.core.items.Metadata.json"; t[4]="METADATA"; fi
if [[ -z "$tp" || "$tp" == "c" ]]; then f[5]="$p/org.openhab.core.thing.link.ItemChannelLink.json"; t[5]="CHANNELEDLINKS"; fi
echo "type: ${tp:-all}"
for i in "${!f[@]}"; do
	echo "$dsh"
	tt="${t[$i]}"
	ff="${f[$i]}"
	echo $'\n'"results in $tt:"
	if [[ "$searchType" == "s" ]]; then
		output=$(jq -r --arg s "$s" 'to_entries[] | select( [.. | (strings, (objects | keys_unsorted[])) | select(ascii_downcase | startswith($s | ascii_downcase))] | any ) | "            UID: \(.key) | Name: \(.value.value.name)"' "$ff")
	else
		output=$(jq -r --arg s "$s" 'to_entries[] | select( [.. | (strings, (objects | keys_unsorted[])) | select(ascii_downcase | contains($s | ascii_downcase))] | any ) | "            UID: \(.key) | Name: \(.value.value.name)"' "$ff")
	fi
		output="            none"
	else
		line_count=$(wc -l <<< "$output")
		output+=$'\n'"            $line_count results"
	fi
	echo "$output"
done
[ -z "$2" ] && echo "${dsh}
Shortcut for this operation
${dsh}
searchoh $s ${tp:-a} $searchType"
Should the line above be:
(return or empty)? It is missing the letter r?
Works well. I think I could use this sometimes.
sorry :wink: you are right
No need to be sorry. It’s just a typo.
I have used it today and it is good. I also use the UI developer search as well.
thx. As described my first approach was simply to find where an item or rule was used. The new approach is able to find nearly anything. In my case I extensively use widgets with complex css instructions. Using “stylesheet: @import /static/myStyleOrWhatever.css” within is useful to see if the widget is working. Before saving I usually uncomment this attribute to “_stylesheet” which is quite simple and effective. Just to check if there are widgets missing this uncommented attribute I can use the above script by searching “_stylesheet” (of course: with parameter startsWith) attributes.
My next approach should contain the ability to search for Strings containing quotes. (ie search ‘@@“myItem”’
