Hi Community!
I’ve been running Home Assistant on a Raspberry Pi for some time but it has deteriorated as of lately, and I’m looking into using openHAB instead.
I seem to have successfully installed OH on my Raspberry Pi. The GUI (Paper UI) seems to be working and I can ‘install’ add-ons. One of tha add-ons I added was “binding-insteonplm1-1.13.0”. I also added the access configuration in my /etc/openhab2/insteonplm.cfg:
port_0=/hub2/USER:PW@10.0.0.182:25105,poll_time=1000
I then issue ‘systemctl restart openhab2’. This seem to trigger some Insteon-related activity (as seen in /var/log/openhab2/openhab.log), but I can not see anything Insteon-related added under ‘Configuration’ nor ‘Inbox’ in the Paper UI.
Selected things seen in the log:
2019-11-21 05:58:53.922 [WARN ] [ding.insteonplm.internal.driver.Port] - bad data received: got unknown command code 0x50
2019-11-21 05:58:56.126 [WARN ] [ding.insteonplm.internal.driver.Port] - bad data received: got unknown command code 0x54
2019-11-21 05:58:58.638 [WARN ] [ding.insteonplm.internal.driver.Port] - bad data received: got unknown command code 0x54
2019-11-21 05:59:01.135 [WARN ] [ding.insteonplm.internal.driver.Port] - bad data received: got unknown command code 0x54
2019-11-21 05:59:03.640 [WARN ] [ding.insteonplm.internal.driver.Port] - bad data received: got unknown command code 0x54
2019-11-21 06:04:31.953 [INFO ] [g.insteonplm.InsteonPLMActiveBinding] - devices: 0 configured, 0 polling, msgs received: 0
2019-11-21 06:14:31.959 [INFO ] [g.insteonplm.InsteonPLMActiveBinding] - devices: 0 configured, 0 polling, msgs received: 0
2019-11-21 06:24:31.966 [INFO ] [g.insteonplm.InsteonPLMActiveBinding] - devices: 0 configured, 0 polling, msgs received: 0
Besides the Insteon HUB, I also have a USB PLM attached (which I’ve manually paired with most devices). When I switch to using this, I get slightly different information in the log:
2019-11-21 09:24:22.510 [INFO ] [g.insteonplm.InsteonPLMActiveBinding] - device 33.FA.0F found in the modem database, but is not configured as an item and the modem controls groups [0x01] and responds to groups [0x01].
2019-11-21 09:24:22.513 [INFO ] [g.insteonplm.InsteonPLMActiveBinding] - device 42.6E.EF found in the modem database, but is not configured as an item and the modem controls groups [0x01] and responds to groups [0x01].
2019-11-21 09:24:22.516 [INFO ] [g.insteonplm.InsteonPLMActiveBinding] - device 4D.B2.99 found in the modem database, but is not configured as an item and the modem controls groups [0x01] and responds to groups [0x01].
2019-11-21 09:34:19.192 [INFO ] [g.insteonplm.InsteonPLMActiveBinding] - devices: 0 configured, 0 polling, msgs received: 55
System information:
Linux Kernel: 4.19.58-v7+
Raspbian 9
OpenHAB2 version 2.4.0-1
java -version
openjdk version "1.8.0_222"
OpenJDK Runtime Environment (build 1.8.0_222-8u222-b10-1~deb9u1-b10)
OpenJDK Client VM (build 25.222-b10, mixed mode)
What am I missing? Is there a step I’m skipping?
