While debugging something else, I noticed that whenever I change a dimmer in my sitemap, the Basic UI is sending the change twice. Here’s a screen snip of the browser debug. You can see the two OfficeLamp_Dimmer calls
Here are the lines in the event log.
2017-01-31 11:48:59.064 [ItemCommandEvent ] - Item 'OfficeLamp_Dimmer' received command 31
2017-01-31 11:48:59.071 [ItemStateChangedEvent ] - OfficeLamp_Dimmer changed from 16 to 31
2017-01-31 11:48:59.262 [ItemCommandEvent ] - Item 'OfficeLamp_Dimmer' received command 31
Item definition
Dimmer OfficeLamp_Dimmer "Office Test Lamp [%d %%]" <light> { channel="zwave:device:zstick:node6:switch_dimmer" }
Sitemap definition
Slider item=OfficeLamp_Dimmer label="Office Test Lamp"
It doesn’t do this when changing the value from PaperUI or from the Karaf console.
Is anyone else seeing this?
