Hi @chris,
I am struggling for 3 weeks already with the sensative strips to get them back into my setup. They used to work and were included but due to a loss of my setup (and the secret)
- I had to reset them and ever since I tried for hours and hours to get them back into my system and fail. I am currently in direct contact with the manufacturer and they are very helpful (I am sure Jonathan wouldn’t mind if I even share the email conversation) but basically I always end up with very weird situations where the strip is discovered but not completely.
I have reset and reincluded them several times but the end up in one of the two situations:
- Either the manufacturer information IS discovered but then the process ends in REQUEST_NIF
- or the manufacturer information isn’t even discovered.
The latest situation I went in was pretty weird:
It did discover the manufacturer and the device type as it is says
2019-11-24 15:40:56.569 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 65: Device discovery completed
2019-11-24 15:40:56.574 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 65: Device discovery resolved to thingType zwave:sensative_1101011_00_000
now the Thing is “ONLINE” but says “Unknown Device” and when I try to heal it this is confirmed ("Can not start heal as initialisation is not complete (MANUFACTURER)).
then out of despair I deleted the thing, ran the discovery and then the node was discovered WITH the manufacturer information… the only little thing you see in the logs regarding the notes is two lines - this is very weird, is it not?
2019-11-24 18:53:28.472 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 65: Device discovered
2019-11-24 18:53:28.497 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 65: Got an event from Z-Wave network: ZWaveInclusionEvent
(the logs are attached)
The other thing is that Jonathan from the manufacturer said that the strip only awakes for roughly ten seconds to safe battery. If I run the discovery could it be that because of too many other devices (if have like 40) on the zwave network that there is too much other traffic so that it is just too late for the device to be contacted when it already went to sleep again?
Finally I tried to set the “1:lifeline” to “controller” and when updating the values I get:
2019-11-24 19:37:54.838 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 65: Association 1 consolidated to [controller]
2019-11-24 19:37:54.841 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 65: Unknown association group 1
and the value is not persisted (when I open it up again, the setting is gone)
I am running the ZWave Bundle 2.5.0.201911020359
Would it make sense to run the latest version “2.5.0.201911230756” or would you rather recommend to go back to an older bundle version?
cheers
Stefan
PS: I lately started contributing myself to a different binding (nanoleaf), so I got to know quite something about bundles, hence I am open to help you in any way that would solve that issue - even compiling the latest version on openhab-core or adding logs somewhere in the code (locally)
[node65.txt|attachment]
openhab-zwave-log.log (10.4 KB) openhab-zwave-log4.log (19.4 KB) openhab-zwave-log3.log (35.9 KB) openhab-zwave-log2.log (54.8 KB)
