Hey guys,
is it possible to show the percentage battery value from an innogy smarthome component?
I mean, the battery icon shows different battery level. But the datatype from the thing is Switch not Number. Where get the icon the values?
The problem i have is that the Radiator thermostat only have a battery status channel for “Battery Low” and i can combine that with a switch so .. “Battery Status Low?” → Switch Off / On
That is a little bit inaccurate
This answers your question it is a binary state you receive from the RST and is a limitation of the device.
Actually it is accurate it just doesn’t have the resolution you desire but can still be very useful.
I wouldn’t even display this information. What you could do is use a rule when this item is triggered to send you a notification that you need to change the battery in the device.
Yes the device need to send that data to you to make it accurate you could make an educated guess and depending on what brand of batt you use this time you can setup AI to track usage.
