Yesterday I worked up a python script that collects battery level percentages from about a dozen different sensors I have using some curl commands to the openhab rest api.
Door, temperature, a couple of remotes and that sort of thing. The script returned those values through a check_mk_agent to monitor battery states and let me start collecting states for graphing over time and allow me to see battery performance.
This morning while working on a different bit of code that also talks to the api I just noticed that all but one of the battery levels has started returning NULL instead of a percentage. Tried to heal one device that didn’t make a difference. Used a nanomote quad and it started reporting battery level then. Opened a couple doors so the sensor would activate but neither started reporting after that.
None of the batteries were close to being drained, the one nanomote at 22% was the lowest. The next lowest that I recall was in the mid 70’s%
How do I get these devices to restore that battery percentage?
