- Platform information:
- Hardware: PC
- OS: Windows 10, OH3.1.0
- Java Runtime Environment: java need to check, OH3.1.0
I was wondering if you could help with the following:
I have OH 3 running on a windows 10 PC with 3 Beckhoff BC9000/BK9000/BK9100 RIO stations. Everything connected with UTP cables, which all work perfectly.
Currently I only use DI and DO which I linked as follows:
MODBUS TCPSlave → MODBUS Poler → MODBUS data read or write.
The above works perfectly for DI/DO.
But now I want to add analog outputs, but I can’t get them to work.
In my test setup, 2 analog output cards are connected to the BC9000 with an end terminal.
The following configuration have i for the analog output:
MODBUS TCPSlave:
UID: modbus:tcp:TCPSlave_23
label: RIO_Schuur
thingTypeUID: modbus:tcp
configuration:
rtuEncoded: false
timeBetweenTransactionsMillis: 5
connectMaxTries: 1
reconnectAfterMillis: 0
port: XXX
timeBetweenReconnectMillis: 0
host: XXX.XXX.XX.XX
connectTimeoutMillis: 10000
enableDiscovery: false
MODBUS Poler:
UID: modbus:poller:mbpollsschuur2write
label: PollSchuurWrite2
thingTypeUID: modbus:poller
configuration:
length: 12
start: 0
refresh: 5
maxTries: 3
cacheMillis: 50
type: holding
bridgeUID: modbus:tcp:TCPSlave_23
MODBUS data write:
UID: modbus:data:mbpollsschuur2write:analog_schuur22
label: analog_schuur222
thingTypeUID: modbus:data
configuration:
readTransform: default
writeType: holding
writeTransform: default
updateUnchangedValuesEveryMillis: 1000
writeValueType: int16
writeMultipleEvenWithSingleRegisterOrCoil: false
writeMaxTries: 3
writeStart: "2"
bridgeUID: modbus:poller:mbpollsschuur2write
When i try to send a value i got this result:
COMMUNICATION_ERROR
Error (ModbusSlaveErrorResponseExceptionImpl) with write. Request: ModbusWriteRegisterRequestBlueprint [slaveId=1, reference=2, registers=ModbusRegisterArray(0027), maxTries=3, getFunctionCode()=WRITE_SINGLE_REGISTER]. Description: ModbusSlaveErrorResponseException(error=2). Message: Slave responsed with error=2
I can’t find out why… the RIO is configured correctly because if I add a DI or DO I can read it in/out directly. In addition, I can also control an analog output via KS2000 software from Beckhoff.
Could someone help me with the correct settings so that I can control the analog output?
