Beginner's Guide for Topic Creation
Agreed!
Agreed!
I will add this to the existing text.
I think only this should be added, not because you are wrong, but it might become too lengthy.
I agree, but let’s first find out from @ThomDietrich if the popup thing is in any way possible (if it accepts images, I would go for it). The mobile version shows only some of the buttons. I wonder if a new user would use the mobile version when dealing with items files, screenshots, etc.
I meant CPU architecture, not clock speed! Is the term architecture acceptable for our goal?
Agreed!
This is indeed a problem, let’s wait for Thom’s answer!
LATER EDIT: I edited according to our discussion! Thank you for you observations!
Yes, that’s perfect. When I see CPU I think speed, not arch.
Great work. I hope we can get this set up soon.
Hey guys!
Thanks @george.erhan and @rlkoshak for the lists, they both look quite good!
I checked with discourse but I couldn’t find any indication that showing something in the preview area is possible. I wonder if that should be feature-requested.
Anyhow, we can only copy this list into the “About category” article or we have to combine both of the lists into a single template, which is as we discussed not a good idea… I would vote for the first solution. Wdyt?
I agree, the first solution would be better.
I also looked in to Discourse and I think for now it’s hard (not impossible) and time consuming to setup the preview to display the information we want. So yes, the first solution should be a go for now.
Thanks for the support!
@ThomDietrich
Reviving this topic after seeing this:
[SOLVED] Starting openHAB as a Service - #3 by ThomDietrich
I am sure we will not avoid ALL the cases, but at least may be a start!
Sorry for the delay. The last thing that’s needed is: We need to turn the first part of Beginner's Guide for Topic Creation - #19 by george.erhan into a single posting, with a few headlines or such. Would you please do so? See as an example: About the Tutorials & Examples category
@george.erhan ping :slight_smile:
The rest of the task needs to be done by @Kai: Please add the post template from here as the template for the Setup, Configuration and Use category.
Alternatively the VS plugin…
Alternatively ip:9091 frontend
Agreed!
@ThomDietrich, I will do it this evening! Thanks!
Indent preformatted text by 4 spaces
No syntax highlighting
Hover over the icon and it will tell you what the icon represents. Below is the icon, what the hover text says, and what it drops into your posting. If you just type in the “what it drops into posting” you do not need to use the icons.
openHAB *.items code fences
```csv
your items code goes here
openHAB *.rules code fences
```php
your rules code goes here
openHAB *.sitemap code fences
```php
your sitemap code goes here
JavaScript code fences
```javascript
your javascript code goes here
generic code fences
your generic code goes here
Done. I added ONLY what is beneath the header “Topic Template” on that post - I hope this is what you expected?
Yep sounds good. It doesn’t work though. Could you please check? Maybe it is not inherited from the main category…
I checked and it does not work!
It works for me in the “Setup, Configuration and Use” category (as requested).
Note that this does NOT apply to any of its sub-categories - if it should be present on all of them, I have to add it there one by one as well.
The problem is that maybe you are the only one that is able to create a topic there.
For everyone else this is not possible and they have to use a sub category.
So templates for sub categories would be useful.
Ah, that’s a valid remark then :wink:
Ok, I have added the template to all sub-categories with the exception of “News & Important Changes”.
