I am trying to adapt the ButtonOn widget and add a kind of status badge. However, I am not sure which component to use for the badge.
It should look like the image below, with the status being displayed on the left side and a button to activate the device on the right side. For now I have been using the oh-button also for the badge, however even if I remove the action from the configuration, it remains clickable. I’d prefer to have something similar-looking but without an action associated. Is there any component like that?
My second question: is it possible to use any RGB values for the color? So far I can only get named colors like black, red or green to work, something like #FFFFFF does not work.
My configuration looks like this:
uid: ButtonOn
tags:
- marketplace:138629
props:
parameters:
- context: item
description: Control Item to operate the gates.
label: Control Item
required: true
type: TEXT
groupName: general
- context: item
description: Sensor Item to determine the gates open/close status.
label: Sensor Item
required: true
type: TEXT
groupName: general
- description: The state of the Sensor Item when the door is closed.
label: Sensor state when closed
required: true
type: TEXT
- description: Text to show on the button.
label: Button
required: false
type: TEXT
- description: Text to show as title.
label: Title
required: false
type: TEXT
parameterGroups:
- name: general
label: Display options
timestamp: Jan 20, 2023, 8:39:18 AM
component: f7-card
title: '=(props.title) ? props.title : "Title"'
slots:
default:
- component: f7-block
class: bog
style:
display: flex
flex-wrap: wrap
justify-content: space-between
align-content: space-between
padding: 20px
slots:
default:
- component: oh-button
text: '=(items[props.sensor_item].state == props.sensor_state_closed) ? "Closed" : "Open"'
color: '=(items[props.sensor_item].state == props.sensor_state_closed) ? "green" : "red"'
large: true
fill: true
outline: true
style:
width: 100px
text: '=(props.button) ? props.button : "Activate"'
large: true
outline: true
actionItem: =(props.control_item)
actionCommand: true
action: command
active: =(items[props.control_item].state === 'ON')
style:
width: 100px
