lblabr
(Lars Bretschneider)
March 13, 2019, 9:52pm
1
in my setup i can use alexa to control devices, i use the v2 syntax.
i’d like to switch to v3 syntax, it doesn’t work,
i took:
Switch LightSwitch "Light Switch" {alexa="PowerController.powerState"}
from example page: https://github.com/openhab/openhab-alexa/blob/v3/USAGE.md
buut it does not work, what do i missed ?
thanks in advance
Lars
H102
(CM6.5 H102)
March 14, 2019, 11:50pm
2
Do you have error messages in the logs? What OH version is running? What version of Alexa binding are you using?
lblabr
March 15, 2019, 7:30am
3
Package: openhab2
Version: 2.5.0~S1507-1
Priority: optional
Section: java
Source: openhab2
Maintainer: https://community.openhab.org
Installed-Size: 80,8 MB
Depends: adduser
Suggests: zulu-8 | zulu-embedded-8 | oracle-java8-installer | openjdk-8-jdk-headless
Conflicts: openhab2-online, openhab2-offline
Homepage: www.openhab.org
Download-Size: 71,1 MB
APT-Manual-Installed: no
APT-Sources: https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main amd64 Packages
Description: openhab2
Linux installation package for openHAB 2.
do i need the alexa binding ? i thought the binding is for the alexa device itself. controlling devices over alexa, is done by myopenhab.org thats connected to my local openhab instance
could you point me in the correct direction ?
thanks in advance
Lars
H102
(CM6.5 H102)
March 15, 2019, 11:27am
4
For using TTS commands you will need to install the alexa binding.
Release Candidate and Support Thread
This thread tries to give you support with the released version of the amazon echo control binding.
Also relative stable (sometimes more stable then the offical version) can be downloaded from here.
Please jump to the Preview and Beta: Amazon Echo Control Binding thread to get the latest features if you want do a beta test.
FAQ and Hints
When I have to remove and recreate things for a binding upgrade?
Check When I have to remove and recreate things for a …
See the link above for how to install and connect.
