i try to find out, what gateway can cover more protocols of 868Mhz for Raspi and OH?
- First of all it must be good compatible with OH. I mean without big problems, another gateways and so on
- It must cover more protocols, at least Homematic, Homematiс IP, MAX! Heizung and it will be good that others like Homematic based protocols for example Kopp, Bosch and others.
I have found:
CUL CC1101-USB
As i understood it works not direct, but throught Homegear with OH, works only with Homematic/IP and MAX. Maybe it supports other protocols?
RPI-RF-MOD
If i am right, it supports only Homematic and IP. MAX is not supported or i am wrong?
CCU3
Is support everything and other gateway, but price is the biggest and for every protocol you need to buy extra plugin/licence.
maybe you would advice another one?
Thanks!
