What would be the best way to (gracefully) stop an already running OH2 runtime?
Assuming that the runtime is running on a Linux platform (Raspberry Pi, native or in docker image), all I can think of would be to send the process a kill signal.
If i like to stop or restart openhab on my Ubuntu i use
sudo service openhab stop or sudo service openhab restart
The same with start.
Thomas
Kill should work gracefully as long as your not doing a kill -9
I believe that this uses kill.
As @sipvoip points out, kill ought to allow the JVM to close gracefully - if you watch the logging output after a kill you can see the various tasks closing down…
Thanks, I will use kill and see what happens
