Best way to setup a testsystem with the same configuration as the production system
Hello all…
since several years I have an openhabian installation running on a RPi. Everything works.
So I have also the current latest version running. 3.4.0-1.
Idea is no to setup an testsystem with the same configuration.
I do not want to make from the SDCARD an 1:1 copy and put in the Testsystem.
I want to setup from a new OH Image a news basic installation and use the backup and restore feature in the OH installation.
Installation from the new image was working fine and also the basic setup was done.
After that I was making a backup from the production system, and copied the backupfile to the testsystem.
→ But now, when I try to restore the configuration from the production system on the testsystem I get all this kinds of errors…
Any Idea how to fix this issue?
Started /usr/share/openhab/runtime/bin/restore openhab-backup-23_01_20-08_33_31.zip
          openHAB restore script
Using '/etc/openhab' as conf folder...
Using '/var/lib/openhab' as userdata folder...
Making Temporary Directory
Extracting zip file to temporary folder.
 Backup Information:
 Backup Version         | 3.4.1 (You are on 3.4.1)
 Backup Timestamp       | 23_01_20-08_33_31
 Config belongs to user | openhab
             from group | openhab
Your current configuration will become owned by openhab:openhab.
Any existing files with the same name will be replaced.
Any file without a replacement will be deleted.
Okay to Continue? [y/N]: y
Moving system files in userdata to temporary folder
Deleting old userdata folder...
rm: cannot remove '/var/lib/openhab/persistence': Device or resource busy
Restoring system files in userdata...
Deleting old conf folder...
Restoring openHAB with backup configuration...
cp: error writing '/var/lib/openhab/persistence/rrd4j/hue_0820_00178875a637_2_dimmer_switch.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/MobilierSteckdosenButtton_Batterieladung.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/BRoKellerFahrradladegerT_SwitchLed.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/JochenZimmerHandyFenster_SwitchLed.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/samsungtv_tv_881197a4_9541_4c2f_b337_792c2d685260_stopBrowser.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/BRoKellerSteckdose_Device_SignalstRke.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/GartenRasenpumpe_BetriebsLEDaus.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/Jochen_Zimmer_Heizkorper_Firmwareaktualisierung_verfugbar.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/BuroKellerSteckdose_Firmwareaktualisierungvorhanden.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/AnnikaFernseher_Lautstarke.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/SchlafzimmerRollorechts_RollerControl0open100closed.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/SchlafzimmerRolloLinks_Device_Uptime.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WetterAussenGarten_Ladegerat.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/Garagentor_Betrieb.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/JochenZimmerHandyFenster_Power.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/hue_0820_00178875a637_4_battery_level.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/KlimaanlageNetzteilschalter_Betrieb.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/OutdoorCameraSteckdoseBalkon_Betrieb.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/GartenGaragentorSwitch.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/LokaleSonnendaten_Daylight_Duration.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_9FEB30_led.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_4D1CB7_rssi.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/hue_0210_00178875a637_3_effect.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/Jochen_Zimmer_Heizkorper_Zieltemperatur.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_7005DE_current.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WetterInnenFlur_Sensors_temperature.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_FC3C5F_power.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/LICHTER_AUS.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/HofeinfahrtLichter_Firmwareaktualisierungvorhanden.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/lgwebos_WebOSTV_2c87671f_b829_4349_f102_f284c3363514_mediaStop.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_FB378B_power.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/SonstigesSteckdose_SwitchLed.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WintergartenMarkiseButton_Battery_lowBattery.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_91C873_led.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/NetworkUPSTool_BatteryRuntime.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_700CCA_switch.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/Gartenlichtervorne_Betrieb.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WetterInnenWintergarten_Device_SignalstRke.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/SchlafzimmerRolloRechts_Roller_RollerControl0Open100Closed.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/LokaleMonddaten_Position_Elevation.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WetterAussenGarage_Batterieladung.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/Heizung_Signalstarke.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/SchlafzimmerRollorechts_LastPower2.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WintergartenStehlampe_Current.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/SchlafzimmerRollorechts_Geratetemperatur.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WetterInnenWintergarten_NiedrigerBatteriestatus.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/HofeinfahrtLichter_Relay_Input.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WetterInnenJochenZimmer_Battery_batteryLevel.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/KlimaanlageAUS.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WintergartenSteckdose_Betrieb.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/KellerHauswasserwerk_Signal.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WintergartenSteckdose_Firmwareaktualisierungvorhanden.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/JochenZimmerSteckdose_Signal.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/HofeinfahrtButton_StatusLEDaus.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/TerrassenMarkise_Firmwareaktualisierungvorhanden.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/SchlafzimmerRollolinks_RollerPosition100open0closed.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/TerrassenMarkise_Meter_LastPower1.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/TerrassenMarkise_Input1.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WintergartenMarkiseButton_Device_SignalstRke.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/JochenZimmerHeizkorper_Zustand.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WintergartenMarkise_SchnittletzteMin.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WohnzimmerHandyFenster_Voltage.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/FlurSteckdose_Firmwareaktualisierungvorhanden.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/Kameraaussen_ControlFFmpegMotionAlarm.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_806A6E_rssi.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WintergartenMarkise_Geratetemperatur.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/NetworkUPSTool_InputVoltage.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/BuroKellerFahrradladegerat_SwitchLed.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WetterInnenFlur_Batteriespannung.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/GartenEdelstahllampen_KumulierterGesamtverbrauch.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_FB378B_energyUsage.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_FB378B_led.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_2455A9_rssi.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WintergartenMarkiseButton_Ladegerat.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/HofeinfahrtButton_Ladegerat.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/Heizung_AutoEINTimer.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WintergartenSteckdose_Device_powerLed.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/BuroKellerSteckdose_BetriebsLEDaus.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/HaustRe_Relay_Input.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WohnzimmerDreifachSteckdose_Signal.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/Regensensor_Relay_Eingang.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WetterAussenGarage_NiedrigerBatteriestatus.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/GartenlichterVorne_Relay_Input.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WetterInnenWintergarten_Firmwareaktualisierungvorhanden.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/GartenRasenpumpe_Gesamtverbrauch.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/TerrassenMarkise_Meter_TotalEnergy.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/KlimaanlageButton_Ladegerat.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_FD5580_current.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_4D1CB7_energyUsage.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/JochenZimmerHeizkorper_Laufzeit.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/SchlafzimmerRollolinks_RollerControl0open100closed.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/JochenZimmerDreifachsteckdose_Current.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/LokaleSonnendaten_NauticDusk_Duration.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/Terrassenlicht_Meter1_Watt.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/Benachrichtungen_Switch.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/LGwebOSTVOLED55C97LA_Volume.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/GartenRasenpumpe_Laufzeit.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/TVUE48JS9090_Helligkeit.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_01599D_rssi.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WeihnachtsbeleuchtungInnen_Signalstarke.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/Gartenlichtervorne_Firmwareaktualisierungvorhanden.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_01599D_current.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/FlurButton1_Eingang.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/JochenZimmerWirelessCharger_SwitchLed.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_91C873_energyUsage.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/LokaleSonnendaten_Rise_Duration.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_C65341_energyUsage.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/LokaleMonddaten_BeleuchtungsstarkedesMondes.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WetterInnenWintergarten_Battery_lowBattery.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/FlurSteckdose_SchnittletzteMin.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/Terrassenlicht_Relay1_Output.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WintergartenMarkise_LastPower2.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WeihnachtsbeleuchtungInnen_Laufzeit.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WetterInnenBRoKeller_Sensors_temperature.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/AnnikaFernseher_ArtMode.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/SchlafzimmerRolloLinks_Device_.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/SchlafzimmerRollolinks_StatusLEDaus.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/AnnikaFernseher_StopBrowser.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/hue_0210_00178875a637_4_color_temperature.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/JochenZimmerDreifachsteckdose_Betrieb.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/Heizung_Geratetemperatur.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/SchlafzimmerRollorechts_LastPower3.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/JochenZimmerSteckdose_Voltage.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/JochenZimmerHeizkorper_Ladegeratistangeschlossen.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/Terrassenlicht_Relay1_TimerActive.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/PapaZimmerDeckenlichter_Farbtemperatur.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/FlurSteckdose_Betrieb.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/MobileOutdoorSteckdose_Signalstarke.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WintergartenMarkiseButton_Firmwareaktualisierungvorhanden.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_911088_voltage.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WintergartenStehlampe_Signal.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/LokaleMonddaten_Apogee_Distance.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/Terrassenlicht_Meter1_LastPower3.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/TerrassenMarkise_Input2.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/BuroKellerFahrradladegerat_Voltage.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WintergartenMarkiseButton_Device_updateAvailable.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/Jochen_Zimmer_Heizkorper_BoostTimer.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WintergartenSteckdose_Gesamtverbrauch.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WetterInnenWintergarten_Device_Laufzeit.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/GartenEdelstahllampen_KumulierterVerbrauch.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WetterInnenWintergarten_Battery_voltage.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/SchlafzimmerRollolinks_Signalstarke.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WetterAussenGarage_Battery_lowBattery.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/Terrassenlicht_Meter1_LastPower2.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WohnzimmerHandyWand_BetriebsLEDaus.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_01599D_switch.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WintergartenMarkiseButton_Batterieladung.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WetterAussenGarten_NiedrigerBatteriestatus.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/Terrassenlicht_Relay2_AutoOff.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/Garagentor_Signalstarke.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WohnzimmerHandyWand_Voltage.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/LokaleSonnendaten_EveningNight_Duration.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/LokaleSonnendaten_Eclipse_RingElevation.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/LokaleSonnendaten_Gesamtstrahlung.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WintergartenMarkise_Firmwareaktualisierungvorhanden.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/SchlafzimmerRolloRechts_Roller_Input2.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/JochenZimmerHeizkorper_Firmwareaktualisierungverfugbar.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_01599D_voltage.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/GartenEdelstahllampen_Geratetemperatur.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/BRoKellerSteckdose_Meter_Energy.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WintergartenSteckdose_LastPower3.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/SchlafzimmerRollorechts_StatusLEDaus.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/samsungtv_tv_881197a4_9541_4c2f_b337_792c2d685260_brightness.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_80AD25_voltage.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_911088_power.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/HauswirtschaftsraumSteckdose_Signal.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/GartenEdelstahllampen_Uptime.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WintergartenSteckdose_Signalstarke.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/JochenZimmerWirelessCharger_EnergyUsage.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WeihnachtsbeleuchtungInnen_Firmwareaktualisierungvorhanden.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/LokaleMonddaten_Azimut.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/FlurButton1_Laufzeit.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/JochenZimmerHeizkorper_NiedrigerBatteriestatus.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WintergartenMarkiseButton_Device_charger.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/KlimaanlageNetzteilschalter_Eingang.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_C65341_voltage.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Terrassenlicht_Meter1_CurrentWatts.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WetterInnenOG_Laufzeit.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/Regensensor_Signalstarke.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Garagentor_AutoONtimer.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/KlimaanlageNetzteilschalter_Leistung.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/JochenZimmerHandyFenster_EnergyUsage.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/GartenEdelstahllampen_Meter1_LastPower1.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/AnnikaFernseher_Stummschalten.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/GartenEdelstahllampen_Meter2_Watt.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/GartenEdelstahllampen_Firmwareaktualisierungvorhanden.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/FlurButton1_StatusLEDaus.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/LokaleSonnendaten_DirekteStrahlung.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WintergartenMarkise_Device_SignalstRke.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/LokaleSonnendaten_AstroDusk_Duration.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WintergartenMarkise_Eingang1.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WetterInnenJochenZimmer_Batteriespannung.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/HauswirtschaftsraumSteckdose_Current.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/LokaleSonnendaten_Eclipse_PartialElevation.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Jochen_Zimmer_Heizkorper_Niedriger_Batteriestatus.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WintergartenSteckdose_Leistung.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/SchlafzimmerRollorechts_Signalstarke.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/GartenEdelstahllampen_Signalstarke.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/GartenEdelstahllampen_Relay1_AutoOff.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WohnzimmerHandyWand_Signal.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_FB76F2_power.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/Terrassenlicht_Meter2_CurrentWatts.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_FC3C5F_current.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/SchlafzimmerRolloRechts_Device_SignalstRke.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/AnnikaFernseher_Power.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/KlimaanlageButton_NiedrigerBatteriestatus.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Jochen_Zimmer_Heizkorper_Batterieladung.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WintergartenMarkise_Signalstarke.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WetterInnenJochenZimmer_Luftfeuchtigkeit.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/FlurButton1_Ladegerat.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/TVUE48JS9090_Kanalnummer.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WohnzimmerHandyWand_EnergyUsage.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/BRoKellerSteckdosenleiste_Meter_Energy.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Hausture_Firmwareaktualisierungvorhanden.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/FlurSteckdose_BetriebsLEDaus.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WetterAussenGarten_Device_SignalstRke.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/Regensensor_Device_SignalstRke.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_7005DE_voltage.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/AnnikaFernseher_Scharfe.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WetterInnenJochenZimmer_NiedrigerBatteriestatus.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/OutdoorCamera_EnergyUsage.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/WetterInnenFlur_Signalstarke.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/JochenZimmerHeizkorper_BoostModus.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/OutdoorCamera_Voltage.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/samsungtv_tv_881197a4_9541_4c2f_b337_792c2d685260_mute.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WintergartenSteckdose_SchnittletzteMin.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_91C873_voltage.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/hue_0210_00178875a637_4_effect.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/JochenZimmerDeckenlichter_Farbe.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/GartenEdelstahllampen_Relay2_AutoOn.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/SchlafzimmerRolloLinks_Meter_Watt.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Heizung_Eingang.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/hue_0210_00178875a637_2_color.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/ZentralschalterKeller_AutoEINTimer.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Kameraaussen_FFmpegMotionAlarm.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_C65341_led.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/TerrassenMarkise_Device_SignalstRke.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/SonstigesSteckdose_EnergyUsage.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/NetworkUPSTool_UPSLoad.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/BRoKellerFahrradladegerT_Current.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_2455A9_led.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/BRoKellerFahrradladegerT_Voltage.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Regensensor_Betrieb.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/JochenZimmerHeizkorper_Zieltemperatur.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/KlimaanlageNetzteilschalter_Laufzeit.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WohnzimmerDreifachSteckdose_SwitchLed.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WintergartenMarkise_Roller_Steuerung0Offen100Geschlossen.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WintergartenSteckdose_WiFiStatusLEDaus.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/TVUE48JS9090_Lautstarke.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/BuroKellerSteckdose_Gesamtverbrauch.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WetterInnenBuroKeller_Laufzeit.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_FD5580_energyUsage.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WetterInnenBuroKeller_Firmwareaktualisierungvorhanden.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WetterAussenGarten_Device_Laufzeit.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/GartenEdelstahllampen_Relay1_AutoOn.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/LICHTER_AN.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/HofeinfahrtButton_Device_Laufzeit.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WetterAussenGarage_Battery_batteryLevel.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Gartentor_Betrieb.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/KlimaanlageNetzteilschalter_SchnittletzteMin.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/HofeinfahrtButton_Device_SignalstRke.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Hausture_Betrieb.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/BuroKellerSteckdose_Betrieb.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_FB378B_rssi.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/GartenEdelstahllampen_Relay2_Output.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/Heizung_Timeraktiv.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WohnzimmerHandyWand_Timeraktiv.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/HofeinfahrtButton_Signalstarke.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/Terrassenlicht_Relay1_AutoOn.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WetterInnenOG_Sensors_temperature.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Jochen_Zimmer_Heizkorper_Signalstarke.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Virtueller_Temperaturschalter_Aussen.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WetterInnenJochenZimmer_Temperatur.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/TerrassenMarkise_Device_.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WintergartenMarkiseButton_Battery_batteryLevel.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WohnzimmerHandyWand_AutoEINTimer.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/JochenZimmerDeckenlichter_Farbtemperatur.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/TerrassenMarkise_Watt.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/JochenZimmerHeizkorper_Position.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Garagentor_Device_SignalstRke.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WetterInnenJochenZimmer_Battery_voltage.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_4D1CB7_voltage.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WetterInnenFlur_Battery_batteryLevel.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_FD5580_power.rrd': No space left on device
cp: error writing '/var/lib/openhab/persistence/rrd4j/lgwebos_WebOSTV_2c87671f_b829_4349_f102_f284c3363514_volume.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Terrassenlicht_StatusLEDaus.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/GartenlichterHinten_Device_Uptime.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_2455A9_power.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_2455A9_energyUsage.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/AdventssternWohnzimmer_Voltage.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/LokaleSonnendaten_Set_Duration.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_806A6E_led.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/GartenEdelstahllampen_Meter1_Watt.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/GartenRasenpumpe_Signalstarke.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/TVUE48JS9090_SourceID.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/OutdoorCameraSteckdoseBalkon_Signalstarke.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_2455A9_voltage.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/NetworkUPSTool_BatteryCharge.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_7005DE_led.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Astro_Switch_Sun_Rize.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WetterInnenFlur_Luftfeuchtigkeit.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/TerrassenMarkise_Roller_RollerControl0Open100Closed.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Astro_Switch_Sun_Set.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WetterInnenWintergarten_Batterieladung.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/ZentralschalterKeller_Signalstarke.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/SchlafzimmerRollolinks_LastPower2.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Readme.txt': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_806A6E_current.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WetterAussenGarage_Laufzeit.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/FlurButton1_Ereigniszahler.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/BRoKellerSteckdose_Device_.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WohnzimmerHandyWand_Power.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_4D1CB7_current.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/FlurSteckdose_Geratetemperatur.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/SchlafzimmerRollolinks_Geratetemperatur.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Gartenlichterhinten_Input.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/JochenZimmerDreifachsteckdose_Power.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WetterAussenGarage_Temperatur.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/BRoKellerSteckdose_Led_BetriebsLEDAus.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Gartenlichterhinten_AutoOFFtimer.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WintergartenMarkiseButton_Status_Eingang_input.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Jochen_Zimmer_Heizkorper_Zeitplan_aktiv.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/NetworkUPSTool_InputRealpower.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/LGwebOSTVOLED55C97LA_Power.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/LokaleSonnendaten_DiffuseStrahlung.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_FB378B_voltage.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/KlimaanlageAN.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/HofeinfahrtLichter_Device_SignalstRke.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_FB76F2_rssi.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WintergartenMarkise_Meter_Strom.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/SchlafzimmerRollorechts_Input1.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/OutdoorCamera_Current.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/MobilierSteckdosenButtton_Firmwareaktualisierungvorhanden.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/JochenZimmerSteckdose_Current.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/AnnikaFernseher_StummSchalten.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/SchlafzimmerRolloLinks_Meter_TotalEnergy.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/PapaZimmerDeckenlichter_Schalter.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/KellerHauswasserwerk_Power.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/GartenlichterVorne_Device_SignalstRke.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/PapaZimmerDeckenlichter_Helligkeit.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WohnzimmerDreifachSteckdose_Betrieb.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/KlimaanlageSchalter.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/JochenZimmerDeckenlichter_Schalter.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WintergartenMarkise_Device_Laufzeit.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/samsungtv_tv_881197a4_9541_4c2f_b337_792c2d685260_sourceId.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WetterInnenFlur_Battery_lowBattery.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/SchlafzimmerRollorechts_Uptime.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WetterAussenGarten_Firmwareaktualisierungvorhanden.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/OutdoorCameraSteckdoseBalkon_StatusLEDaus.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_9FEB30_current.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_700CCA_current.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Gartenlichtervorne_AutoONtimer.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WetterInnenFlur_NiedrigerBatteriestatus.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/KlimaanlageNetzteilschalter_Spannung.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/BuroKellerFahrradladegerat_Current.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/GartenEdelstahllampen_Relay1_TimerActive.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WohnzimmerDreifachSteckdose_Power.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/AuEnlichter_Device_Uptime.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/BuroKellerSteckdose_LastPower3.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WetterAussenGarten_Luftfeuchtigkeit.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WetterInnenBuroKeller_NiedrigerBatteriestatus.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Jochen_Handy_Switch.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/LokaleMonddaten_Eclipse_PartialElevation.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/OutdoorCamera_Betrieb.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/JochenZimmerSteckdose_EnergyUsage.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WetterInnenFlur_Device_SignalstRke.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Kameraaussen_AudioAlarm.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/hue_0210_00178875a637_1_color_temperature.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Terrassenlicht_Meter1_LastPower1.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WintergartenMarkise_Roller_Eingang2.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/BenachrichtigungenTeilweise.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WintergartenSteckdose_Device_statusLed.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/MobileOutdoorSteckdose_Timeraktiv.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WetterInnenJochenZimmer_Firmwareaktualisierungvorhanden.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WohnzimmerHandyFenster_Current.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Terrassenlicht_Meter2_TotalKWH.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/KlimaanlageNetzteilschalter_AutoEINTimer.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/KlimaanlageNetzteilschalter_Timeraktiv.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/LokaleSonnendaten_AstroDawn_Duration.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WintergartenSteckdose_LastPower2.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WintergartenStehlampe_Voltage.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_4D1CB7_led.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/ZentralschalterKeller_Gesamtverbrauch.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/HauswirtschaftsraumSteckdose_Betrieb.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Gartenlichterhinten_Firmwareaktualisierungvorhanden.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WetterInnenBRoKeller_Device_Laufzeit.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/NetworkUPSTool_UPSTemperature.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/GartenEdelstahllampen_StatusLEDaus.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Hausture_AutoONOFFtimeractive.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/SchlafzimmerRollolinks_Firmwareaktualisierungvorhanden.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/LokaleSonnendaten_Night_Duration.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/TVUE48JS9090_Farbtemperatur.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/AnnikaFernseher_SourceID.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/JochenZimmerHeizkorper_Signalstarke.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Kameraaussen_MP4HistoryLength.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/BuroKellerSteckdose_AutoAUSTimer.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WohnzimmerHandyWand_Betrieb.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/NetworkUPSTool_InputCurrent.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/JochenZimmerWirelessCharger_Current.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/LokaleMonddaten_Distance_Distance.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_9FEB30_switch.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Gartenlichterhinten_AutoONtimer.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WetterInnenJochenZimmer_Signalstarke.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/OutdoorCameraSteckdoseBalkon_BetriebsLEDaus.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/HofeinfahrtButton_Status_Eingang.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/SchlafzimmerRolloLinks_Roller_Input2.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/TerrassenMarkise_Device_Uptime.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WintergartenSteckdose_AutoEINTimer.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Terrassenlicht_Meter1_TotalEnergy.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Gartentor_AutoONtimer.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WohnzimmerHandyWand_Geratetemperatur.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Gartentor_Firmwareaktualisierungvorhanden.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WeihnachtsbeleuchtungInnen_Gesamtverbrauch.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WetterInnenBRoKeller_Battery_voltage.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WetterInnenOG_Battery_batteryLevel.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Garagentor_Firmwareaktualisierungvorhanden.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Gartentor_Device_SignalstRke.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WeihnachtsbeleuchtungInnen_AutoAUSTimer.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_700CCA_led.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/JochenZimmerHeizkorper_BoostTimer.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WintergartenMarkiseButton_Signalstarke.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/Jochen_Zimmer_Heizkorper_Temperatur.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WintergartenSteckdose_Laufzeit.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WintergartenMarkise_Leistung.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/samsungtv_tv_881197a4_9541_4c2f_b337_792c2d685260_colorTemperature.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WetterInnenFlur_Laufzeit.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WetterAussenGarage_Battery_voltage.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/BuroKellerFahrradladegerat_Signal.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/WetterInnenJochenZimmer_Sensors_temperature.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/tplinksmarthome_hs110_FC3C5F_led.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/TerrassenMarkise_Roller_Input1.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/BRoKellerSteckdosenleiste_Relay_Betrieb.rrd': No space left on device
cp: cannot create regular file '/var/lib/openhab/persistence/rrd4j/HofeinfahrtLichter_Signalstarke.rrd': No space left on device
Failed to copy /tmp/openhab/restore/userdata/ to /var/lib/openhab/...
Please check /tmp/openhab/restore and replace userdata.
Did you try to run the backup script while openHAB is running ?
Please try again after stopping openHAB.
Hello Hans-Jörg.
No, the openHAB was stoped before with this command:
sudo /bin/systemctl stop openhab.service
BR
Jochen
Did you use openhabian-config to restore the backup?
Erg….? Is your sd card full…?
no.. no… The Production SD card has 16GB. The new one has 32GB and was initialized from the lastest stable image from openhab.org.
I’m also able to backup and restore on the Production system with that taken backupfile. So only the restore will not work an a "fresh installation.
It looks like I found the problem now.
ZRAM is now switch on by default in the installation.
With ZRAM running the restore from the backup file is not possible. We need to stop the service first.
Then restore the backup file and start both service .
sudo zram-config stop
sudo openhab-cli restore xyz.zip
sudo zram-config start
sudo /bin/systemctl start openhab.service
It looks like the migration is has now worked.
Thanks…
BR
Jochen
The new installation seems to work normal. I have also upgraded my production system from 16GB to 32GB SD cards.
The only negative impact I have seen so far is, that the backupfiles size after the migration has increase from arround 54MB zu 424MB.
Some 8x more that before the migration.
I checked the backupfile (ZIP-File) and it seems there is a new folder “kar” where the complete “addon bindings” are store. This folder also alone more that 400MB.
Has some an explaination for that?
Should this like it is?
BR
Jochen
How are you taking the backups? By default openhab-cli will take just what’s necessary (I’m seeing file sizes in the 30-40 MB range). If you supply the --full option it will capture everything including cache and tmp (I’m seeing file sizes 475+ MB)
Thanks for the feedback.
There is no change in the handling between the old way doing backup and the new one.
Everything is done via the “sudo openhabian-config” and the menuepoint 50 (Backup)
Is there somewhere a config, where this “–full” option could be switch off?
Making a backup via console and " sudo openhab-cli backup" generate also a more than 400MB file.
By doing a file via “sudo openhab-cli backup --full” the file has +900MB !!!
In the code of openhabian-config the option --full is not being used.
Depending on the type of persistence that is setup persistence data is part of the backup.
I see that addons / bindings that are installed via marketplace are backed up as well.
