Im looking for a way to interface with Zwave devices. ive been looking at two devices listed below… Anyone have any experience and success with any of those devices in openhab2? or openhab1? Im currently looking to move away from smartthings and am planning to move to a larger home so i would like a zwave system that can handle 100+ devices with ease.
I’m using the Aeon gen5 z-stick with a 27 node network on openhab2. Runs very well. I expect to max out at 30-40 nodes, so I’m far away from your 100+ node network.
The stick works with one or the other, but Linux on a Pi or other SBC is definitely a better choice than to run OH on Windows - way more people use OH that way.
Yes, zwave plus is compatible to zwave so it’ll work, but of course it still depends on each and every device, they need to be in the OH device database in order to work.
On scalability - all zwave controllers do can handle the maximum amount of nodes (232), and any RPi2 or 3 will provide way enough power to handle large houses with complicated rulesets (okok, there’s NO system that cannot be brought to its knees, but then it’s due to bad setup and programming, not because of lack of processing power).
Just ordered my aeon labs gen5 stick. Mostly im using GE zwave dimmer switches and lamp modules. Im looking into getting a few zwave door sensors and motion detectors as well as maybe some humidity sensors for the bathrooms so it will kick on the exhaust fan when the humidity in the shower gets too a certain level. Also have been looking at automated air vents for heating and ac. Anybody have any recomendations of what sensors they are using and what works well with the aeon labs gen5 stick.
