Yes, this is a known issue.
The error is not expected, but I have some ideas. Unfortunately, our power is out, so no computer for a while.
I tried with EXTRA_JAVA_OPTS in setenv.bat, in start.bat, in Windows environment and without this option as you suggested somewhere (I donāt remember where)
You donāt need EXTRA_JAVA_OPTS when using the bundle.
Actually I donāt use it
Looks like something does ā¦
1564 Dec 28 19:42 charsets.pkc
30712 Dec 28 19:42 cldrdata.pkc
117 Dec 28 19:42 dnsns.pkc
517 Dec 28 19:42 jaccess.pkc
1207 Dec 28 19:42 jce.pkc
2860 Dec 28 19:42 jfr.pkc
1574 Dec 28 19:42 jsse.pkc
10014 Dec 28 19:42 localedata.pkc
8505 Dec 28 19:42 nashorn.pkc
4705 Dec 28 19:42 openjsse.pkc
491 Dec 28 19:42 org.apache.karaf.diagnostic.boot-4.2.7.pkc
233 Dec 28 19:42 org.apache.karaf.jaas.boot-4.2.7.pkc
1072 Dec 28 19:42 org.apache.karaf.main-4.2.7.pkc
123 Dec 28 19:42 org.apache.karaf.specs.activator-4.2.7.pkc
386 Dec 28 19:42 org.apache.karaf.specs.java.xml-4.2.7.pkc
226 Dec 28 19:42 org.apache.karaf.specs.java.xml.ws-4.2.7.pkc
125 Dec 28 19:42 org.apache.karaf.specs.locator-4.2.7.pkc
2855 Dec 28 19:42 osgi.core-6.0.0.pkc
2418 Dec 28 19:42 packages.idx
47 Dec 28 19:42 resources.pkc
234258 Dec 28 19:42 rt.pkc
328 Dec 28 19:42 sunec.pkc
1452 Dec 28 19:42 sunjce_provider.pkc
1322 Dec 28 19:42 sunpkcs11.pkc
243 Dec 28 19:42 zipfs.pkc
As this happened at the same time I switched to the Jython addon, I assumed it was created when installing the addon. If not, any thoughts what else could have installed this?
Iām seeing this too. Very odd⦠but seems harmless. I will look into it Thank you for reporting!
I also have the packages folder in /conf (Windows 10)
is the 2.5.0 jar still supposed to work with 2.5.1-2 ? (yes I saw 2.5.1-1 had problems)
2020-01-13 02:02:34.963 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab2/addons/org.openhab.core.automation.module.script.scriptenginefactory.jython-2.5.0-SNAPSHOT.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.core.automation.module.script.scriptenginefactory.jython [203]
Unresolved requirement: Import-Package: org.openhab.core.automation.module.script; version="[2.5.0,3.0.0)"
I would have thought it would work, but Iāll take a look this week. I need to get onto 2.5.1 to test some device db updates in the zwave binding and to update the manual install script.
I had some trouble upgrading to 2.5.1 due to the bad package it was (initially) provided with, plus another issue, so Iām not sure it could be related to that as well.
openhab> bundle:list|grep -i jy
176 x Active x 80 x 2.5.0.201912061703 x openHAB Core :: Bundles :: Jython ScriptEngineFactory
openhab>
(py) Rules did work at some stage of the upgrade process but now they donāt do any more.
Theyāre also not listed in PaperUI.
The following seems to come up only in when the jython module starts up and when I restarted the bundle, so it may be related or not:
2020-01-13 18:52:26.587 [ERROR] [ersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
org.glassfish.jersey.server.internal.process.MappableException: org.eclipse.jetty.io.EofException
at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:92) ~[?:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor.proceed(WriterInterceptorExecutor.java:162) ~[bundleFile:?]
at org.glassfish.jersey.message.internal.MessageBodyFactory.writeTo(MessageBodyFactory.java:1130) ~[bundleFile:?]
at org.glassfish.jersey.server.ServerRuntime$Responder.writeResponse(ServerRuntime.java:711) [bundleFile:?]
at org.glassfish.jersey.server.ServerRuntime$Responder.processResponse(ServerRuntime.java:444) [bundleFile:?]
at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:434) [bundleFile:?]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:329) [bundleFile:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [bundleFile:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [bundleFile:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [bundleFile:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [bundleFile:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [bundleFile:?]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [bundleFile:?]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [bundleFile:?]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [bundleFile:?]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [bundleFile:?]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [bundleFile:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [bundleFile:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [bundleFile:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [bundleFile:?]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [bundleFile:?]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:852) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:544) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:536) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1581) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1307) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) [bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:482) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1549) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1204) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [bundleFile:?]
at org.eclipse.jetty.server.Server.handle(Server.java:494) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:374) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:268) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:367) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918) [bundleFile:9.4.20.v20190813]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
Caused by: org.eclipse.jetty.io.EofException
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:283) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.WriteFlusher.flush(WriteFlusher.java:422) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.WriteFlusher.write(WriteFlusher.java:277) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.AbstractEndPoint.write(AbstractEndPoint.java:381) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpConnection$SendCallback.process(HttpConnection.java:818) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.IteratingCallback.processing(IteratingCallback.java:241) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.IteratingCallback.iterate(IteratingCallback.java:223) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpConnection.send(HttpConnection.java:549) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpChannel.sendResponse(HttpChannel.java:857) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpChannel.write(HttpChannel.java:929) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:250) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:226) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:525) ~[bundleFile:9.4.20.v20190813]
at org.glassfish.jersey.servlet.internal.ResponseWriter$NonCloseableOutputStreamWrapper.write(ResponseWriter.java:325) ~[?:?]
at org.glassfish.jersey.message.internal.CommittingOutputStream.write(CommittingOutputStream.java:229) ~[bundleFile:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$UnCloseableOutputStream.write(WriterInterceptorExecutor.java:299) ~[bundleFile:?]
at org.glassfish.jersey.message.internal.ReaderWriter.writeTo(ReaderWriter.java:116) ~[bundleFile:?]
at org.glassfish.jersey.message.internal.AbstractMessageReaderWriterProvider.writeTo(AbstractMessageReaderWriterProvider.java:79) ~[bundleFile:?]
at org.glassfish.jersey.message.internal.InputStreamProvider.writeTo(InputStreamProvider.java:105) ~[bundleFile:?]
at org.glassfish.jersey.message.internal.InputStreamProvider.writeTo(InputStreamProvider.java:60) ~[bundleFile:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$TerminalWriterInterceptor.invokeWriteTo(WriterInterceptorExecutor.java:265) ~[bundleFile:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$TerminalWriterInterceptor.aroundWriteTo(WriterInterceptorExecutor.java:250) ~[bundleFile:?]
at org.glassfish.jersey.server.internal.JsonWithPaddingInterceptor.aroundWriteTo(JsonWithPaddingInterceptor.java:106) ~[?:?]
at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:86) ~[?:?]
... 53 more
Caused by: java.io.IOException: Datenübergabe unterbrochen (broken pipe)
at sun.nio.ch.FileDispatcherImpl.writev0(Native Method) ~[?:1.8.0_222]
at sun.nio.ch.SocketDispatcher.writev(SocketDispatcher.java:51) ~[?:1.8.0_222]
at sun.nio.ch.IOUtil.write(IOUtil.java:148) ~[?:1.8.0_222]
at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:504) ~[?:1.8.0_222]
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:263) ~[bundleFile:9.4.20.v20190813]
... 53 more
2020-01-13 18:52:26.607 [ERROR] [ersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
... 53 more
... 53 more
2020-01-13 18:52:26.593 [ERROR] [ersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
... 53 more
... 53 more
2020-01-13 18:52:26.590 [ERROR] [ersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
Iām now using the 2.5.0 Jython bundle with 2.5.1-2 (manual install), so there must be something specific to your install.
Is there more in the log? This error makes me wonder if the NGRE is installed (it needs to be). I donāt see how the other errors could be related, since they are from Jetty.
2.7.0 you mean I presume ? I had 2.7.1 running all the time now downgraded to 2.7.0, but no difference.
By the way now that EXTRA_JAVA_OPTS shall not be used anymore, how does the system know about the python package?
Yes NGRE is installed. It probably wasnāt by the time that error came up as I had a couple of problems upgrading to 2.5.1-2 (manual package remove/install, too).
I removed/readded the jar in the addons directory, resulting in this log which looks fine to me
2020-01-15 10:51:38.155 [DEBUG] [.AutomationResourceBundlesEventQueue] - Process bundle event 32, for automation bundle 'org.openhab.core.automation.module.script.scriptenginefactory.jython'
2020-01-15 10:51:38.157 [DEBUG] [vider.AbstractResourceBundleProvider] - Parse rules from bundle 'org.openhab.core.automation.module.script.scriptenginefactory.jython'
2020-01-15 10:51:38.158 [DEBUG] [.AutomationResourceBundlesEventQueue] - Process bundle event 32, for automation bundle 'org.openhab.core.automation.module.script.scriptenginefactory.jython'
2020-01-15 10:51:38.160 [DEBUG] [.AutomationResourceBundlesEventQueue] - Process bundle event 32, for automation bundle 'org.openhab.core.automation.module.script.scriptenginefactory.jython'
2020-01-15 10:51:39.914 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Initialized a custom ScriptEngineFactory for jython (2.7.0): supports python (2.7) with file extensions [py], names [python, jython], and mimetypes [text/python, application/python, text/x-python, application/x-python]
No, I mean the 2.5.0 version of the Jython bundle from the link in the OP. Have you removed the EXTRA_JAVA_OPTS, Jython, and the core Jython helper libraries?
In the bundle, I add Java system properties for python.home and python.path, which is what was being done through EXTRA_JAVA_OPTS.
Yes, this looks OK. Do your scripts running now?
I finally had some time to look at this. I know exactly what is happening and how to fix. Iāll post when Iāve updated the bundle.
Ah OK, Iām using that (OH) 2.5.0 bundle, too.
Removed everything from EXTRA_JAVA_OPTS but neither Jython nor helper libraries from the file system.
No my scripts still donāt run Btw it used to work with the addon - before I upgraded OH from 2.5.0 to 2.5.1.
The important piece is removing the EXTRA_JAVA_OPTS. The logs show that itās loaded. Are there logs when you loaded the scripts? Oh! Did you turn on logging for ājsr223ā (step 3)? Depending on how you upgraded, $OPENHAB_USERDATA/etc/org.ops4j.pax.logging.cfg may have been overwritten, so the scripts may be running but not logging.
Is there an issue open to add the logging config to the default pax logging config file?
Not yet. Iām working on a design spec doc first, then plan to open a number of issues all at once, including the logging. There are still some architectural questions to get consensus on. Go ahead and add it now or rest assured Iāll be addinging it in later⦠whichever floats your boat.
Java runs without any Jython arguments, logging is active. No log output other than the one I already shared. Putting another .py file into etc/openhab2/automation/jsr223/python/personal does not cause anything. Not even file activity when I strace() the running java process.
No idea short of to restart OH once more but Iām hesitating because it was such a bad experience on upgrade (took me hours to get it to work correctly).
openhab> log:get jsr223
DEBUG
openhab> log:get org.openhab.core.automation
DEBUG
[20:30:37] openhabian@openhabianpi:~$ ps -ef|grep ytho
openhab+ 334 32759 0 20:30 pts/0 00:00:00 grep --color=auto ytho
root 556 1 0 Jan13 ? 00:00:00 /usr/bin/python3 /usr/share/unattended-upgrades/unattended-upgrade-shutdown --wait-for-signal
[20:30:43] openhabian@openhabianpi:~$
An OH restart would be good. Maybe try restarting the automation bundle, or uninstall/reinstall the NGRE.
Good troubleshooting though! I canāt think of anything else to try other than a fresh install to prove to yourself that it does work .
See below what else I tried but none of this helped.
So I finally reluctantly restarted OH. Didnāt clear the cache.
And guess what, this time it works.
Rules reappeared in PaperUI and they all work incl. triggering from UI, removing and adding .pyās.
So, conclusion: I donāt know what it was. Nothing helped except for the OH restart but then it worked.
openhab> bundle:list|grep -i auto
237 x Active x 80 x 2.5.0 x openHAB Core :: Bundles :: Automation
238 x Active x 80 x 2.5.0 x openHAB Core :: Bundles :: Automation Media Modules
239 x Active x 80 x 2.5.0 x openHAB Core :: Bundles :: Automation Script Modules
240 x Active x 80 x 2.5.0 x openHAB Core :: Bundles :: Automation Script RuleSup
241 x Active x 80 x 2.5.0 x openHAB Core :: Bundles :: Automation REST API
Restarting 237,238,239 results in:
2020-01-15 22:00:37.184 [DEBUG] [.AutomationResourceBundlesEventQueue] - Process bundle event 2, for automation bundle 'org.openhab.core.automation'
2020-01-15 22:00:37.213 [DEBUG] [vider.AbstractResourceBundleProvider] - Parse rules from bundle 'org.openhab.core.automation'
2020-01-15 22:00:37.227 [DEBUG] [.AutomationResourceBundlesEventQueue] - Process bundle event 2, for automation bundle 'org.openhab.core.automation.module.script.rulesupport'
2020-01-15 22:00:37.230 [DEBUG] [vider.AbstractResourceBundleProvider] - Parse rules from bundle 'org.openhab.core.automation.module.script.rulesupport'
2020-01-15 22:00:37.763 [DEBUG] [e.automation.internal.RuleEngineImpl] - ModuleHandlerFactory added MediaModuleHandlerFactory
2020-01-15 22:00:37.767 [DEBUG] [e.automation.internal.RuleEngineImpl] - ModuleHandlerFactory added ScriptedCustomModuleHandlerFactory
2020-01-15 22:00:37.770 [DEBUG] [e.automation.internal.RuleEngineImpl] - ModuleHandlerFactory added ScriptedPrivateModuleHandlerFactory
2020-01-15 22:00:37.773 [DEBUG] [e.automation.internal.RuleEngineImpl] - ModuleHandlerFactory added ScriptModuleHandlerFactory
2020-01-15 22:00:37.776 [DEBUG] [e.automation.internal.RuleEngineImpl] - ModuleHandlerFactory added CoreModuleHandlerFactory
2020-01-15 22:00:37.778 [DEBUG] [e.automation.internal.RuleEngineImpl] - ModuleHandlerFactory added EphemerisModuleHandlerFactory
2020-01-15 22:00:37.781 [DEBUG] [e.automation.internal.RuleEngineImpl] - ModuleHandlerFactory added TimerModuleHandlerFactory
2020-01-15 22:00:37.784 [DEBUG] [e.automation.internal.RuleEngineImpl] - ModuleHandlerFactory added AnnotatedActionModuleTypeProvider
2020-01-15 22:00:37.869 [DEBUG] [e.automation.internal.RuleEngineImpl] - ModuleHandlerFactory added AnnotatedThingActionModuleTypeProvider
2020-01-15 22:02:31.458 [DEBUG] [e.automation.internal.RuleEngineImpl] - ModuleHandlerFactory added MediaModuleHandlerFactory
2020-01-15 22:02:35.577 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Removed GenericScriptEngineFactory
2020-01-15 22:02:35.590 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Removed NashornScriptEngineFactory
2020-01-15 22:02:35.621 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Removed JythonScriptEngineFactory
2020-01-15 22:02:35.813 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Initialized a custom ScriptEngineFactory for jython (2.7.0): supports python (2.7) with file extensions [py], names [python, jython], and mimetypes [text/python, application/python, text/x-python, application/x-python]
2020-01-15 22:02:35.991 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Initialized a generic ScriptEngineFactory for Oracle Nashorn (1.8.0_222): supports ECMAScript (ECMA - 262 Edition 5.1) with file extensions [js], names [nashorn, Nashorn, js, JS, JavaScript, javascript, ECMAScript, ecmascript], and mimetypes [application/javascript, application/ecmascript, text/javascript, text/ecmascript]
2020-01-15 22:02:36.029 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Initialized a custom ScriptEngineFactory for Oracle Nashorn (1.8.0_222): supports ECMAScript (ECMA - 262 Edition 5.1) with file extensions [js], names [nashorn, Nashorn, js, JS, JavaScript, javascript, ECMAScript, ecmascript], and mimetypes [application/javascript, application/ecmascript, text/javascript, text/ecmascript]
2020-01-15 22:02:36.034 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Removed JythonScriptEngineFactory
2020-01-15 22:02:36.037 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Removed GenericScriptEngineFactory
2020-01-15 22:02:36.040 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Removed NashornScriptEngineFactory
2020-01-15 22:02:36.045 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Initialized a custom ScriptEngineFactory for jython (2.7.0): supports python (2.7) with file extensions [py], names [python, jython], and mimetypes [text/python, application/python, text/x-python, application/x-python]
2020-01-15 22:02:36.085 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Initialized a generic ScriptEngineFactory for Oracle Nashorn (1.8.0_222): supports ECMAScript (ECMA - 262 Edition 5.1) with file extensions [js], names [nashorn, Nashorn, js, JS, JavaScript, javascript, ECMAScript, ecmascript], and mimetypes [application/javascript, application/ecmascript, text/javascript, text/ecmascript]
2020-01-15 22:02:36.118 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Initialized a custom ScriptEngineFactory for Oracle Nashorn (1.8.0_222): supports ECMAScript (ECMA - 262 Edition 5.1) with file extensions [js], names [nashorn, Nashorn, js, JS, JavaScript, javascript, ECMAScript, ecmascript], and mimetypes [application/javascript, application/ecmascript, text/javascript, text/ecmascript]
2020-01-15 22:02:36.263 [DEBUG] [e.automation.internal.RuleEngineImpl] - ModuleHandlerFactory added ScriptModuleHandlerFactory
2020-01-15 22:03:01.234 [INFO ] [me.core.service.AbstractWatchService] - Loading script 'javascript/core/000_startup_delay.js'
2020-01-15 22:03:01.870 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Added ScriptEngine for language 'js' with identifier: file:/etc/openhab2/automation/jsr223/javascript/core/000_startup_delay.js
2020-01-15 22:03:02.120 [INFO ] [jsr223.javascript.core.startup_delay] - Checking for initialized context
2020-01-15 22:03:02.224 [INFO ] [jsr223.javascript.core.startup_delay] - Context initialized... waiting 30s before allowing scripts to load
2020-01-15 22:03:32.305 [INFO ] [jsr223.javascript.core.startup_delay] - Complete
2020-01-15 22:03:32.308 [INFO ] [me.core.service.AbstractWatchService] - Loading script 'python/core/000_startup_delay.py'
2020-01-15 22:03:32.311 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Added ScriptEngine for language 'py' with identifier: file:/etc/openhab2/automation/jsr223/python/core/000_startup_delay.py
After that, itās now at least recognizing new files. Creating a .py results in:
2020-01-15 22:06:17.899 [INFO ] [me.core.service.AbstractWatchService] - Loading script 'python/personal/X.py'
2020-01-15 22:06:17.902 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Added ScriptEngine for language 'py' with identifier: file:/etc/openhab2/automation/jsr223/python/personal/X.py
but it's not running
Restarting 240,241 results in:
2020-01-15 22:08:33.361 [DEBUG] [e.automation.internal.RuleEngineImpl] - ModuleHandlerFactory added ScriptedCustomModuleHandlerFactory
2020-01-15 22:08:33.379 [DEBUG] [e.automation.internal.RuleEngineImpl] - ModuleHandlerFactory added ScriptedPrivateModuleHandlerFactory
2020-01-15 22:08:58.436 [INFO ] [me.core.service.AbstractWatchService] - Loading script 'javascript/core/000_startup_delay.js'
2020-01-15 22:08:58.868 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Added ScriptEngine for language 'js' with identifier: file:/etc/openhab2/automation/jsr223/javascript/core/000_startup_delay.js
2020-01-15 22:08:58.952 [INFO ] [jsr223.javascript.core.startup_delay] - Checking for initialized context
2020-01-15 22:08:59.019 [INFO ] [jsr223.javascript.core.startup_delay] - Context initialized... waiting 30s before allowing scripts to load
2020-01-15 22:09:29.063 [INFO ] [me.core.service.AbstractWatchService] - Loading script 'python/core/000_startup_delay.py'
2020-01-15 22:09:29.068 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Added ScriptEngine for language 'py' with identifier: file:/etc/openhab2/automation/jsr223/python/core/000_startup_delay.py
Uninstalling NGRE gave:
2020-01-15 22:25:19.242 [INFO ] [internal.service.FeaturesServiceImpl] - Removing features: openhab-misc-ruleengine/[2.5.1,2.5.1]
2020-01-15 22:25:37.831 [INFO ] [internal.service.FeaturesServiceImpl] - Changes to perform:
2020-01-15 22:25:37.834 [INFO ] [internal.service.FeaturesServiceImpl] - Region: root
2020-01-15 22:25:37.836 [INFO ] [internal.service.FeaturesServiceImpl] - Bundles to uninstall:
2020-01-15 22:25:37.838 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.automation/2.5.0
2020-01-15 22:25:37.839 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.automation.module.media/2.5.0
2020-01-15 22:25:37.842 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.automation.module.script/2.5.0
2020-01-15 22:25:37.844 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.automation.module.script.rulesupport/2.5.0
2020-01-15 22:25:37.846 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.automation.rest/2.5.0
2020-01-15 22:25:37.848 [INFO ] [internal.service.FeaturesServiceImpl] - Stopping bundles:
2020-01-15 22:25:37.853 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.config.serial/2.5.0
2020-01-15 22:25:37.875 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.automation.rest/2.5.0
2020-01-15 22:25:37.916 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.binding.zwave/2.5.1
2020-01-15 22:25:54.571 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.binding.telegram/2.5.1
2020-01-15 22:25:54.600 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.automation.module.script.rulesupport/2.5.0
2020-01-15 22:25:54.649 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.automation.module.script/2.5.0
2020-01-15 22:25:54.656 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Removed GenericScriptEngineFactory
2020-01-15 22:25:54.667 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Removed NashornScriptEngineFactory
2020-01-15 22:25:54.684 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Removed JythonScriptEngineFactory
2020-01-15 22:25:54.718 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.automation.module.media/2.5.0
2020-01-15 22:25:54.743 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.automation/2.5.0
2020-01-15 22:25:54.920 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.binding.mail/2.5.1
2020-01-15 22:25:54.974 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.binding.hue/2.5.1
2020-01-15 22:25:55.208 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.transport.serial.rxtx.rfc2217/2.5.0
2020-01-15 22:25:55.222 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.transport.serial/2.5.0
2020-01-15 22:25:55.258 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.transport.serial.rxtx/2.5.0
2020-01-15 22:25:55.270 [INFO ] [internal.service.FeaturesServiceImpl] - Uninstalling bundles:
2020-01-15 22:25:55.273 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.automation/2.5.0
2020-01-15 22:25:55.286 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.automation.module.media/2.5.0
2020-01-15 22:25:55.316 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.automation.module.script/2.5.0
2020-01-15 22:25:55.326 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.automation.module.script.rulesupport/2.5.0
2020-01-15 22:25:55.346 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.automation.rest/2.5.0
2020-01-15 22:25:55.427 [INFO ] [internal.service.FeaturesServiceImpl] - Refreshing bundles:
2020-01-15 22:25:55.429 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.binding.hue/2.5.1 (Wired to org.openhab.core.automation/2.5.0 which is being refreshed)
2020-01-15 22:25:55.431 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.binding.mail/2.5.1 (Wired to org.openhab.core.automation/2.5.0 which is being refreshed)
2020-01-15 22:25:55.432 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.binding.telegram/2.5.1 (Wired to org.openhab.core.automation/2.5.0 which is being refreshed)
2020-01-15 22:25:55.434 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.binding.zwave/2.5.1 (Should be wired to: org.openhab.core.io.transport.serial/2.5.0 (through [org.openhab.binding.zwave/2.5.1] osgi.wiring.package; filter:="(osgi.wiring.package=org.eclipse.smarthome.io.transport.serial)"))
2020-01-15 22:25:55.435 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.automation/2.5.0 (Bundle will be uninstalled)
2020-01-15 22:25:55.437 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.automation.module.media/2.5.0 (Bundle will be uninstalled)
2020-01-15 22:25:55.438 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.automation.module.script/2.5.0 (Bundle will be uninstalled)
2020-01-15 22:25:55.440 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.automation.module.script.rulesupport/2.5.0 (Bundle will be uninstalled)
2020-01-15 22:25:55.441 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.automation.rest/2.5.0 (Bundle will be uninstalled)
2020-01-15 22:25:55.443 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.config.serial/2.5.0 (Should be wired to: org.openhab.core.io.transport.serial/2.5.0 (through [org.openhab.core.config.serial/2.5.0] osgi.wiring.package; filter:="(&(osgi.wiring.package=org.eclipse.smarthome.io.transport.serial)(version>=2.5.0)(!(version>=3.0.0)))"))
2020-01-15 22:25:55.444 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.transport.serial/2.5.0 (Should be wired to: org.openhab.core.io.transport.serial/2.5.0 (through [org.openhab.core.io.transport.serial/2.5.0] osgi.wiring.package; filter:="(osgi.wiring.package=org.eclipse.smarthome.io.transport.serial)"))
2020-01-15 22:25:55.445 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.transport.serial.rxtx/2.5.0 (Wired to org.openhab.core.io.transport.serial/2.5.0 which is being refreshed)
2020-01-15 22:25:55.447 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.transport.serial.rxtx.rfc2217/2.5.0 (Wired to org.openhab.core.io.transport.serial/2.5.0 which is being refreshed)
2020-01-15 22:25:58.661 [INFO ] [internal.service.FeaturesServiceImpl] - Done.
2020-01-15 22:26:02.840 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab2/addons/org.openhab.core.automation.module.script.scriptenginefactory.jython-2.5.0-SNAPSHOT.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.core.automation.module.script.scriptenginefactory.jython [266]
at org.eclipse.osgi.container.Module.start(Module.java:444) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startAllBundles(DirectoryWatcher.java:1221) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:515) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [bundleFile:3.6.4]
2020-01-15 22:26:15.520 [INFO ] [zwave.handler.ZWaveControllerHandler] - Attempting to add listener when controller is null
Re-Installing NGRE resulted in:
2020-01-15 22:35:05.734 [INFO ] [internal.service.FeaturesServiceImpl] - Adding features: openhab-misc-ruleengine/[2.5.1,2.5.1]
2020-01-15 22:35:37.380 [INFO ] [internal.service.FeaturesServiceImpl] - Changes to perform:
2020-01-15 22:35:37.382 [INFO ] [internal.service.FeaturesServiceImpl] - Region: root
2020-01-15 22:35:37.384 [INFO ] [internal.service.FeaturesServiceImpl] - Bundles to install:
2020-01-15 22:35:37.386 [INFO ] [internal.service.FeaturesServiceImpl] - mvn:org.openhab.core.bundles/org.openhab.core.automation/2.5.0
2020-01-15 22:35:37.388 [INFO ] [internal.service.FeaturesServiceImpl] - mvn:org.openhab.core.bundles/org.openhab.core.automation.module.media/2.5.0
2020-01-15 22:35:37.390 [INFO ] [internal.service.FeaturesServiceImpl] - mvn:org.openhab.core.bundles/org.openhab.core.automation.module.script/2.5.0
2020-01-15 22:35:37.392 [INFO ] [internal.service.FeaturesServiceImpl] - mvn:org.openhab.core.bundles/org.openhab.core.automation.module.script.rulesupport/2.5.0
2020-01-15 22:35:37.394 [INFO ] [internal.service.FeaturesServiceImpl] - mvn:org.openhab.core.bundles/org.openhab.core.automation.rest/2.5.0
2020-01-15 22:35:37.397 [INFO ] [internal.service.FeaturesServiceImpl] - Stopping bundles:
2020-01-15 22:35:37.400 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.config.serial/2.5.0
2020-01-15 22:35:37.426 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.binding.zwave/2.5.1
2020-01-15 22:36:01.420 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.binding.telegram/2.5.1
2020-01-15 22:36:01.451 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.binding.mail/2.5.1
2020-01-15 22:36:01.516 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.binding.hue/2.5.1
2020-01-15 22:36:01.705 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.transport.serial.rxtx.rfc2217/2.5.0
2020-01-15 22:36:01.719 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.transport.serial/2.5.0
2020-01-15 22:36:01.747 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.transport.serial.rxtx/2.5.0
2020-01-15 22:36:01.780 [INFO ] [internal.service.FeaturesServiceImpl] - Installing bundles:
2020-01-15 22:36:01.783 [INFO ] [internal.service.FeaturesServiceImpl] - mvn:org.openhab.core.bundles/org.openhab.core.automation/2.5.0
2020-01-15 22:36:01.866 [INFO ] [internal.service.FeaturesServiceImpl] - mvn:org.openhab.core.bundles/org.openhab.core.automation.module.media/2.5.0
2020-01-15 22:36:01.887 [INFO ] [internal.service.FeaturesServiceImpl] - mvn:org.openhab.core.bundles/org.openhab.core.automation.module.script/2.5.0
2020-01-15 22:36:01.919 [INFO ] [internal.service.FeaturesServiceImpl] - mvn:org.openhab.core.bundles/org.openhab.core.automation.module.script.rulesupport/2.5.0
2020-01-15 22:36:01.946 [INFO ] [internal.service.FeaturesServiceImpl] - mvn:org.openhab.core.bundles/org.openhab.core.automation.rest/2.5.0
2020-01-15 22:36:02.036 [INFO ] [internal.service.FeaturesServiceImpl] - Refreshing bundles:
2020-01-15 22:36:02.039 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.binding.hue/2.5.1 (Should be wired to: org.openhab.core.automation/2.5.0 (through [org.openhab.binding.hue/2.5.1] osgi.wiring.package; resolution:=optional; filter:="(osgi.wiring.package=org.openhab.core.automation.annotation)"))
2020-01-15 22:36:02.041 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.binding.mail/2.5.1 (Should be wired to: org.openhab.core.automation/2.5.0 (through [org.openhab.binding.mail/2.5.1] osgi.wiring.package; resolution:=optional; filter:="(osgi.wiring.package=org.openhab.core.automation.annotation)"))
2020-01-15 22:36:02.044 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.binding.telegram/2.5.1 (Should be wired to: org.openhab.core.automation/2.5.0 (through [org.openhab.binding.telegram/2.5.1] osgi.wiring.package; resolution:=optional; filter:="(osgi.wiring.package=org.openhab.core.automation.annotation)"))
2020-01-15 22:36:02.046 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.binding.zwave/2.5.1 (Should be wired to: org.openhab.core.io.transport.serial/2.5.0 (through [org.openhab.binding.zwave/2.5.1] osgi.wiring.package; filter:="(osgi.wiring.package=org.eclipse.smarthome.io.transport.serial)"))
2020-01-15 22:36:02.048 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.config.serial/2.5.0 (Should be wired to: org.openhab.core.io.transport.serial/2.5.0 (through [org.openhab.core.config.serial/2.5.0] osgi.wiring.package; filter:="(&(osgi.wiring.package=org.eclipse.smarthome.io.transport.serial)(version>=2.5.0)(!(version>=3.0.0)))"))
2020-01-15 22:36:02.050 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.transport.serial/2.5.0 (Should be wired to: org.openhab.core.io.transport.serial/2.5.0 (through [org.openhab.core.io.transport.serial/2.5.0] osgi.wiring.package; filter:="(osgi.wiring.package=org.eclipse.smarthome.io.transport.serial)"))
2020-01-15 22:36:02.053 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.transport.serial.rxtx/2.5.0 (Wired to org.openhab.core.io.transport.serial/2.5.0 which is being refreshed)
2020-01-15 22:36:02.055 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.transport.serial.rxtx.rfc2217/2.5.0 (Wired to org.openhab.core.io.transport.serial/2.5.0 which is being refreshed)
2020-01-15 22:36:07.527 [INFO ] [internal.service.FeaturesServiceImpl] - Starting bundles:
2020-01-15 22:36:07.547 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.automation.module.script.rulesupport/2.5.0
2020-01-15 22:36:07.694 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.automation.module.script/2.5.0
2020-01-15 22:36:07.835 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Initialized a custom ScriptEngineFactory for jython (2.7.0): supports python (2.7) with file extensions [py], names [python, jython], and mimetypes [text/python, application/python, text/x-python, application/x-python]
2020-01-15 22:36:08.068 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Initialized a generic ScriptEngineFactory for Oracle Nashorn (1.8.0_222): supports ECMAScript (ECMA - 262 Edition 5.1) with file extensions [js], names [nashorn, Nashorn, js, JS, JavaScript, javascript, ECMAScript, ecmascript], and mimetypes [application/javascript, application/ecmascript, text/javascript, text/ecmascript]
2020-01-15 22:36:08.132 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Initialized a custom ScriptEngineFactory for Oracle Nashorn (1.8.0_222): supports ECMAScript (ECMA - 262 Edition 5.1) with file extensions [js], names [nashorn, Nashorn, js, JS, JavaScript, javascript, ECMAScript, ecmascript], and mimetypes [application/javascript, application/ecmascript, text/javascript, text/ecmascript]
2020-01-15 22:36:08.142 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Removed JythonScriptEngineFactory
2020-01-15 22:36:08.147 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Removed GenericScriptEngineFactory
2020-01-15 22:36:08.152 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Removed NashornScriptEngineFactory
2020-01-15 22:36:08.181 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Initialized a custom ScriptEngineFactory for jython (2.7.0): supports python (2.7) with file extensions [py], names [python, jython], and mimetypes [text/python, application/python, text/x-python, application/x-python]
2020-01-15 22:36:08.266 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Initialized a generic ScriptEngineFactory for Oracle Nashorn (1.8.0_222): supports ECMAScript (ECMA - 262 Edition 5.1) with file extensions [js], names [nashorn, Nashorn, js, JS, JavaScript, javascript, ECMAScript, ecmascript], and mimetypes [application/javascript, application/ecmascript, text/javascript, text/ecmascript]
2020-01-15 22:36:08.340 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Initialized a custom ScriptEngineFactory for Oracle Nashorn (1.8.0_222): supports ECMAScript (ECMA - 262 Edition 5.1) with file extensions [js], names [nashorn, Nashorn, js, JS, JavaScript, javascript, ECMAScript, ecmascript], and mimetypes [application/javascript, application/ecmascript, text/javascript, text/ecmascript]
2020-01-15 22:36:08.932 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.automation/2.5.0
2020-01-15 22:36:11.643 [DEBUG] [.AutomationResourceBundlesEventQueue] - Process bundle event 2, for automation bundle 'org.openhab.core.automation'
2020-01-15 22:36:11.659 [DEBUG] [.AutomationResourceBundlesEventQueue] - Process bundle event 2, for automation bundle 'org.openhab.core.automation.module.script.rulesupport'
2020-01-15 22:36:11.662 [DEBUG] [vider.AbstractResourceBundleProvider] - Parse rules from bundle 'org.openhab.core.automation'
2020-01-15 22:36:11.682 [DEBUG] [vider.AbstractResourceBundleProvider] - Parse rules from bundle 'org.openhab.core.automation.module.script.rulesupport'
2020-01-15 22:36:12.450 [INFO ] [me.storage.json.internal.JsonStorage] - Json storage file at '/var/lib/openhab2/jsondb/backup/1576456114079--automation_rules_disabled.json' is used (backup 1).
2020-01-15 22:36:12.463 [DEBUG] [e.automation.internal.RuleEngineImpl] - ModuleHandlerFactory added ScriptedCustomModuleHandlerFactory
2020-01-15 22:36:12.468 [DEBUG] [e.automation.internal.RuleEngineImpl] - ModuleHandlerFactory added ScriptedPrivateModuleHandlerFactory
2020-01-15 22:36:12.473 [DEBUG] [e.automation.internal.RuleEngineImpl] - ModuleHandlerFactory added ScriptModuleHandlerFactory
2020-01-15 22:36:12.478 [DEBUG] [e.automation.internal.RuleEngineImpl] - ModuleHandlerFactory added CoreModuleHandlerFactory
2020-01-15 22:36:12.482 [DEBUG] [e.automation.internal.RuleEngineImpl] - ModuleHandlerFactory added EphemerisModuleHandlerFactory
2020-01-15 22:36:12.487 [DEBUG] [e.automation.internal.RuleEngineImpl] - ModuleHandlerFactory added TimerModuleHandlerFactory
2020-01-15 22:36:12.491 [DEBUG] [e.automation.internal.RuleEngineImpl] - ModuleHandlerFactory added AnnotatedActionModuleTypeProvider
2020-01-15 22:36:12.784 [DEBUG] [e.automation.internal.RuleEngineImpl] - ModuleHandlerFactory added AnnotatedThingActionModuleTypeProvider
2020-01-15 22:36:12.794 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.automation.module.media/2.5.0
2020-01-15 22:36:12.869 [DEBUG] [e.automation.internal.RuleEngineImpl] - ModuleHandlerFactory added MediaModuleHandlerFactory
2020-01-15 22:36:12.902 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.automation.rest/2.5.0
2020-01-15 22:36:13.024 [INFO ] [internal.service.FeaturesServiceImpl] - Done.
2020-01-15 22:36:26.872 [INFO ] [zwave.handler.ZWaveControllerHandler] - Attempting to add listener when controller is null
2020-01-15 22:36:33.267 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2020-01-15 22:36:33.269 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2020-01-15 22:36:33.485 [INFO ] [me.core.service.AbstractWatchService] - Loading script 'javascript/core/000_startup_delay.js'
2020-01-15 22:36:34.188 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Added ScriptEngine for language 'js' with identifier: file:/etc/openhab2/automation/jsr223/javascript/core/000_startup_delay.js
2020-01-15 22:36:34.305 [INFO ] [jsr223.javascript.core.startup_delay] - Checking for initialized context
2020-01-15 22:36:34.410 [INFO ] [jsr223.javascript.core.startup_delay] - Context initialized... waiting 30s before allowing scripts to load
2020-01-15 22:37:05.553 [INFO ] [jsr223.javascript.core.startup_delay] - Complete
2020-01-15 22:37:05.560 [INFO ] [me.core.service.AbstractWatchService] - Loading script 'python/core/000_startup_delay.py'
2020-01-15 22:37:05.565 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Added ScriptEngine for language 'py' with identifier: file:/etc/openhab2/automation/jsr223/python/core/000_startup_delay.py
Another restart of Jython ScriptEngineFactory bundle gave:
2020-01-15 22:40:07.424 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Initialized a custom ScriptEngineFactory for jython (2.7.0): supports python (2.7) with file extensions [py], names [python, jython], and mimetypes [text/python, application/python, text/x-python, application/x-python]
