I have a Vantage Qlink system linked via a Serial port and I’m trying to get it fully integrated into OH 2.3.0.
Whenever I Switch / Dim a light, it outputs the new status like “LO 1 2 2 5 100”, “1 2 2 5” is the address, 100 is the load value (100 = Max, 0 = Off).
When I change a Dimmer Item in OH to let’s say 80%, a command “VLB# 1 2 2 5 80” is sent to Vantage Qlink.
I could craft pretty generic code to handle these cases (see below)
BUT, now my question, how can I avoid the 2 HasMaps with address → item and item → address?
I need similar code for 50+ inputs…
In java Apache world, there exist a BidiMap…
Any help is appreciated !
vantage.items
String Vantage "Vantage [%s]" { serial="/dev/ttyUSB7@19200" }
Group:Dimmer Spots "Spots"
Dimmer Keuken_Spots_midden "Blok" (Spots)
Dimmer Keuken_Spots_kookvuur "Kookvuur" (Spots)
Dimmer Keuken_Spots_plafond "Plafond" (Spots)
Dimmer Bureau1_Spots_plafond "Plafond" (Spots)
... and 60 more
vantage.rules
// Import minimal set (new since 2.2)
import java.util.HashMap
// Mappings
var HashMap<String, String> loadToItemsMap = newLinkedHashMap(
"1 2 3 6" -> "Bureau1_Spots_plafond",
"1 2 2 4" -> "Keuken_Spots_midden",
"1 2 2 3" -> "Keuken_Spots_kookvuur",
"1 2 3 1" -> "Keuken_Spots_plafond",
... and 60 more
var HashMap<String, String> itemsToCommand = newLinkedHashMap(
"Bureau1_Spots_plafond" -> "1 2 3 6",
"Keuken_Spots_midden" -> "1 2 2 4",
"Keuken_Spots_kookvuur" -> "1 2 2 3",
"Keuken_Spots_plafond" -> "1 2 3 1"
... and 60 more
rule "vantage Spots changed"
Member of Spots received command
then {
var myCommand = "VLB# "+itemsToCommand.get(triggeringItem.name) + " " + receivedCommand
logInfo("vantage", "Spots changed "+triggeringItem.name+" "+receivedCommand+" to Vantage => "+myCommand)
Vantage.sendCommand(myCommand+"\r")
rule "vantage changed event"
Item Vantage received command
then {
var String message = receivedCommand.split(" ")
var String master = new String(message.get(1))
var String enclosure = new String(message.get(2))
var String module = new String(message.get(3))
var String load = new String(message.get(4))
var String value = new String(message.get(5))
var String key = master + " " + enclosure + " " + module + " " + load
var MyItem = loadToItemsMap.get(key)
postUpdate(MyItem,value)
