- Platform information:
- Hardware: RPi4
- OS: Raspbian GNU/Linux 12 (bookworm)
- Java Runtime Environment: openjdk 17.0.13 2024-10-15
- openHAB version: 4.2.2
- Issue of the topic: After updating zigbee2mqtt and frontail, all files inside
/binand/usr/binare now owned byfrontail- alsosudo, so canät figure out way to fix this. Appreciate any tips?
UPDATE: Duplicate of this: Sudo not working any more - #2 by rlkoshak
Snippet of /bin
-rwxr-xr-x 1 frontail frontail 1984 Apr 10 2022 zcat
-rwxr-xr-x 1 frontail frontail 1678 Apr 10 2022 zcmp
-rwxr-xr-x 1 frontail frontail 6460 Apr 10 2022 zdiff
-rwxr-xr-x 1 frontail frontail 18020 Nov 6 14:48 zdump
-rwxr-xr-x 1 frontail frontail 29 Apr 10 2022 zegrep
-rwxr-xr-x 1 frontail frontail 29 Apr 10 2022 zfgrep
-rwxr-xr-x 1 frontail frontail 2081 Apr 10 2022 zforce
-rwxr-xr-x 1 frontail frontail 8103 Apr 10 2022 zgrep
-rwxr-xr-x 1 frontail frontail 173100 Feb 19 2023 zip
-rwxr-xr-x 1 frontail frontail 72392 Feb 19 2023 zipcloak
-rwxr-xr-x 1 frontail frontail 70193 Nov 25 2023 zipdetails
-rwxr-xr-x 1 frontail frontail 2959 Feb 19 2023 zipgrep
-rwxr-xr-x 2 frontail frontail 145368 Feb 19 2023 zipinfo
-rwxr-xr-x 1 frontail frontail 68112 Feb 19 2023 zipnote
-rwxr-xr-x 1 frontail frontail 72216 Feb 19 2023 zipsplit
-rwxr-xr-x 1 frontail frontail 2206 Apr 10 2022 zless
-rwxr-xr-x 1 frontail frontail 1842 Apr 10 2022 zmore
-rwxr-xr-x 1 frontail frontail 4577 Apr 10 2022 znew
openhabi-config log, at first you can see sudo has worked, but not anymore after update.
openhabian@openhab:/usr/local/bin $ sudo openhabian-config
2024-11-20_23:00:54_EET [openHABian] Checking for root privileges... OK
2024-11-20_23:00:54_EET [openHABian] Making sure router advertisements are available...
$ sysctl --load
net.ipv6.conf.all.accept_ra = 1
net.ipv6.conf.all.accept_ra_rt_info_max_plen = 64
OK
2024-11-20_23:00:54_EET [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2024-11-20_23:00:54_EET [openHABian] openHABian configuration tool version: [openHAB]{2024-10-25T10:35:12-06:00}(7d97bd8)
2024-11-20_23:00:54_EET [openHABian] Checking for changes in origin branch openHAB... OK
2024-11-20_23:00:55_EET [openHABian] Switching to branch openHAB... OK
2024-11-20_23:00:55_EET [openHABian] Checking openHAB Signing Key expiry.
2024-11-20_23:00:55_EET [openHABian] Checking expiry date of apt keys... OK
2024-11-20_23:00:59_EET [openHABian] Updating Linux package information... OK
2024-11-20_23:01:02_EET [openHABian] Updating Zigbee2MQTT...
$ cd /opt/zigbee2mqtt
$ systemctl stop zigbee2mqtt
$ sudo -u openhabian cp -R data data-backup
$ sudo -u openhabian git pull
Already up to date.
$ sudo -u openhabian npm ci
npm WARN deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
npm WARN deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
added 649 packages, and audited 650 packages in 49s
90 packages are looking for funding
run `npm fund` for details
2 vulnerabilities (1 low, 1 high)
To address all issues, run:
npm audit fix
Run `npm audit` for details.
$ sudo -u openhabian cp -R data-backup/configuration.example.yaml data-backup/configuration.yaml data-backup/database.db data-backup/state.json data
$ rm -rf /opt/zigbee2mqtt/data-backup
$ cd /opt
$ systemctl start zigbee2mqtt
OK
2024-11-20_23:02:03_EET [openHABian] Updating Linux package information... OK
2024-11-20_23:02:03_EET [openHABian] Installing Frontail prerequsites (NodeJS)...
$ nodejs_setup
2024-11-20_23:02:03_EET [openHABian] Adding required keys to apt... OK
2024-11-20_23:02:03_EET [openHABian] Adding NodeSource repository to apt...
$ apt-get update
Hit:1 http://deb.debian.org/debian bookworm-updates InRelease
Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
Hit:3 http://archive.raspberrypi.org/debian bookworm InRelease
Hit:4 http://raspbian.raspberrypi.org/raspbian bookworm InRelease
Get:5 https://deb.nodesource.com/node_18.x bookworm InRelease [4,586 B]
Hit:6 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable InRelease
Get:7 https://deb.nodesource.com/node_18.x bookworm/main armhf Packages [787 B]
Fetched 5,373 B in 2s (2,152 B/s)
Reading package lists... Done
W: http://deb.debian.org/debian/dists/bookworm-updates/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
W: http://security.debian.org/debian-security/dists/bookworm-security/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
W: http://archive.raspberrypi.org/debian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
W: http://raspbian.raspberrypi.org/raspbian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
OK
2024-11-20_23:02:10_EET [openHABian] Installing NodeJS...
$ apt-get install --yes -o DPkg::Lock::Timeout= nodejs
Building dependency tree... Done
nodejs is already the newest version (20.18.1-1nodesource1).
The following packages were automatically installed and are no longer required:
libc-ares2 node-busboy node-cjs-module-lexer node-undici node-xtend
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
OK
FAILED. Provide packageName.
OK
2024-11-20_23:02:14_EET [openHABian] Installing openHAB Log Viewer (frontail)... Removing any old installations...
$ npm uninstall -g frontail
removed 153 packages, and audited 1 package in 1s
found 0 vulnerabilities
$ frontail_download /opt
2024-11-20_23:02:17_EET [openHABian] Downloading frontail...
Update...
$ update_git_repo /opt/frontail master
2024-11-20_23:02:17_EET [openHABian] Updating frontail, master branch from git...
$ git -C /opt/frontail fetch origin
$ git -C /opt/frontail fetch --tags --force --prune
$ git -C /opt/frontail reset --hard origin/master
HEAD is now at 7ff8dc5 Merge pull request #2 from Gifford47/patch-1
$ git -C /opt/frontail clean --force -x -d
Removing node_modules/
$ git -C /opt/frontail checkout master
Already on 'master'
Your branch is up to date with 'origin/master'.
$ git -C /opt/frontail submodule update --init --recursive
OK
OK
$ npm audit fix --omit=dev
npm WARN old lockfile
npm WARN old lockfile The package-lock.json file was created with an old version of npm,
npm WARN old lockfile so supplemental metadata must be fetched from the registry.
npm WARN old lockfile This is a one-time fix-up, please be patient...
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
npm WARN deprecated uuid@3.3.2: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
added 139 packages, and audited 140 packages in 16s
1 package is looking for funding
# npm audit report
basic-auth-connect 1.0.0
Severity: high
basic-auth-connect's callback uses time unsafe string comparison - https://github.com/advisories/GHSA-7p89-p6hx-q4fw
fix available via `npm audit fix --force`
Will install basic-auth-connect@1.1.0, which is outside the stated dependency range
node_modules/basic-auth-connect
cookie <0.7.0
cookie accepts cookie name, path, and domain with out of bounds characters - https://github.com/advisories/GHSA-pxg6-pf52-xh8x
Will install cookie@1.0.2, which is a breaking change
node_modules/cookie
node_modules/cookie-parser/node_modules/cookie
node_modules/engine.io/node_modules/cookie
node_modules/express-session/node_modules/cookie
cookie-parser 1.0.1 - 1.4.6
Depends on vulnerable versions of cookie
engine.io 0.7.8 - 0.7.9 || 1.8.0 - 6.6.1
Depends on vulnerable versions of ws
socket.io 3.0.0-rc1 - 4.6.1
Depends on vulnerable versions of engine.io
node_modules/socket.io
express-session 1.0.1 - 1.18.0
request *
Severity: moderate
Server-Side Request Forgery in Request - https://github.com/advisories/GHSA-p8p7-x288-28g6
Depends on vulnerable versions of tough-cookie
Will install universal-analytics@0.5.3, which is a breaking change
node_modules/request
universal-analytics <=0.4.23
Depends on vulnerable versions of request
node_modules/universal-analytics
send <0.19.0
send vulnerable to template injection that can lead to XSS - https://github.com/advisories/GHSA-m6fv-jmcg-4jfg
Will install serve-static@1.16.2, which is outside the stated dependency range
node_modules/send
serve-static <=1.16.0
Depends on vulnerable versions of send
node_modules/serve-static
socket.io-parser 4.0.4 - 4.2.2
Severity: moderate
Insufficient validation when decoding a Socket.IO packet - https://github.com/advisories/GHSA-cqmj-92xf-r6r9
fix available via `npm audit fix`
node_modules/socket.io-parser
tough-cookie <4.1.3
Severity: moderate
tough-cookie Prototype Pollution vulnerability - https://github.com/advisories/GHSA-72xf-g2v4-qvf3
node_modules/tough-cookie
ws 7.0.0 - 7.5.9
Severity: high
ws affected by a DoS when handling a request with many HTTP headers - https://github.com/advisories/GHSA-3h5v-q93c-6h6q
Will install socket.io@4.8.1, which is a breaking change
node_modules/ws
13 vulnerabilities (5 low, 5 moderate, 3 high)
To address issues that do not require attention, run:
npm audit fix
To address all issues (including breaking changes), run:
$ npm update --audit=false --omit=dev
added 13 packages, removed 16 packages, and changed 81 packages in 13s
2 packages are looking for funding
$ npm install --global --audit=false --omit=dev
added 1 package in 826ms
OK
2024-11-20_23:02:52_EET [openHABian] Setting up openHAB Log Viewer (frontail) service...
$ chmod 644 /etc/systemd/system/frontail.service
$ systemctl -q daemon-reload
$ systemctl enable --now frontail.service
$ systemctl restart frontail.service
OK
2024-11-20_23:02:57_EET [openHABian] Adding an openHAB dashboard tile for 'frontail'... Replacing...
$ sed -i -e /^frontail-link-*$/d /etc/openhab/services/runtime.cfg
OK
2024-11-20_23:03:07_EET [openHABian] Checking for default openHABian username:password combination... OK
2024-11-20_23:03:07_EET [openHABian] We hope you got what you came for! See you again soon ;)
openhabian@openhab:/usr/local/bin $ sudo nano /etc/apt/sources.list
sudo: /usr/bin/sudo must be owned by uid 0 and have the setuid bit set
