Binding filtering selection list based on thing brand/model
I’m looking for a binding that filters the list for selection widget based on thing brand/model. I have a Denon DRA-100 device that has 9 source inputs and current denonmarant binding captures only 3 of them, but shows 40 in total. I want to make the binding more usable by showing only those inputs relevant to my model, not all possible options, most of them not working. The background info.
I could probably code it myself, but if there is an existing solution I’d be happy to copy it :grinning:
Alternatively if there is a typical openHAB solution that allows showing only the source inputs relevant to my thing model - please enlighten me :grinning:
Maybe a ConfigOptionProvider would be the solution?
Another solution would be to have different Thing-types for different models, and define the state options on the Channel for each model instead of on the Channel-type. But in either case it would mean you’d have to know the configuration of every different supported model (or have a generic Thing-type with all different inputs and add specific models as required).
If you think of config parameters for binding then there are several combinations you can use. First of call declare <context> in your parameter, then you can pick one of below values handled out of the box by main-ui:
Namely, if you declare parameter such as:
      <parameter name="referenceThing" type="text" >
        <label>Another thing</label>
        <context>Thing</context>
      </parameter>
You will get thing selection dropbox for that parameter when editing configuration.
Thank you both! I need to do more reading to fully understand your answers - I started playing with openhab a few days ago.
At the usability level: could I assume all currently supported models use all currently provided source inputs, and initially only my model (DRA-100) would get proper source input list? That would keep the functionality for all existing users at the same level (I mean: “here you have your 40 inputs”). Later on the new code could be used to improve the situation, if we have testers with other denon/marantz devices.
A little more to the story: It’s possible on many receivers to delete input sources - from the manual of my good old AVR-3808:
Source Delete
Remove input sources that are not used from the display.
Additionally, you can rename the corresponding texts, for example “DVR” → “Squeeze” etc.
So the ideal filtering would take this into account. For me, model-specific filtering would only be a slight improvement, since I would still have too many sources compared to the ones actually assigned and used. And I wouldn’t be able to remember their usages from the raw names printed on the back of the receiver.
So using the input source list in the current form directly in a UI seems not ideal or even intended. You will get better results from filtering in the widget, sitemap or other UI you are using.
I mis-interpreted the original request, I didn’t notice we are not talking about channel configuration but channel state.
I guess you can get the available texts from the device, correct? Then a StateDescriptionProvider would be the way to go. You add a new DenonStateDescriptionProvider (extending BaseDynamicStateDescriptionProvider), that is injected into handler factory and pass it to the thing handler (see e.g. deconz binding how to do that) . The thing handler then can set the available inputs for each channel (identified by the UID, so if you have different things, you can set different options per thing).
Thanks again for all replies!
My device doesn’t give the Source Inputs - it’s from the manual. I think the best would be allow user to select which one should show up - I have 9 inputs, but only 3 are in use.
I’ll try to code in the direction provided by Jan, we’ll se how far I can go :grinning:
