Can anyone explain me how can I use python script to control ADB set top box?
The Exec binding
or executeCommandLine actions
I recommend using the actions, particularly the one that takes a timeout parameter so you can see what gets printed when you execute the command.
val String results = executeCommandLine("python send_key2ncplus.py POWER", 5000)
logInfo("ADB", results)
Common things that trip up users of the Exec binding and executeCommandLine is that, assuming that OH was installed via apt-get, OH is running as a separate and non-privlidged user so permission problems tend to be the most common problem. This is why I recommend the actions because you will immediately see these permission problems whereas when using the Exec binding you do not.
Big thanks.
I will try it and give some feedback for others
HI,
Unfortunately no
BR
Michal
